Raspberry Pi to 1MHz bus interface
IanB
Re: Raspberry Pi to 1MHz bus interface
Post by IanB » Wed Apr 17, 2019 9:01 pm
Got mine thanks.
Some time ago I bought a Pi style header socket with long pins hoping that when it was fitted to this board it would allow access to the HDMI port on the Pi which would be useful for a Prisma 3 emulator (assuming that can be done in a Pi zero).
It works well although I had to shorten the pins a bit:
The Pi is just clear of the desk when the Master is right way up.
The socket is RS stock no. 681-6794
As the power port is also accessible you could power it with a standard micro USB power supply
dp11
Post by dp11 » Wed Apr 17, 2019 9:10 pm
nice
dp11
Post by dp11 » Thu Apr 18, 2019 6:34 pm
Prebuilt images and source code are now on github. https://github.com/dp111/Pi1MHz . The average user just needs to copy the firmware directory to the root of an SDCARD.
Code needs some more comments and tidying ( help wanted)
If someone want to add extra peripherals and doesn't understand how to from the code please just ask. It is very simple I think
if you want to build it you will need the arm tools : https://developer.arm.com/tools-and-sof ... /downloads
I was hoping to use gitlab and may well move over in the future as it has free continuous integration, but I haven't mastered it yet.
I was thinking some kind person might put together an ADFS image which contains useful stuff e.g. M5000 , games , Tube code , econet server etc
512Mbyte LUNs is a lot of space.
Also does anyone want to try and port Bad Apple demo ? now that you can preload JIM RAM with 480Mbytes
pixelblip
Post by pixelblip » Fri Apr 19, 2019 3:45 am
I’ll buy a couple please. This is awesome. Music 5000 at last. Just awesome. =D>
JonC
Post by JonC » Fri Apr 19, 2019 7:16 pm
Coulod you put me down for a couple if kits if there's any left? Cheers!
Jon
th3bar0n
Post by th3bar0n » Tue Apr 23, 2019 6:17 pm
Please put me down for one if not too late.
Thank you!
andrewvideo
Post by andrewvideo » Wed Apr 24, 2019 12:43 pm
Can I have one please but I would like a ready built. I can’t solder to save my life. I want it for my bbc master.
Thank you
Post by RobC » Wed Apr 24, 2019 1:30 pm
If Dominic doesn't have one ready made, I have a couple of these that I've made up. Happy to bring one to Wakefield on Saturday for you and then get another kit off Dominic when they're available.
SpaceFlightOrange
Post by SpaceFlightOrange » Wed Apr 24, 2019 6:01 pm
Wow!, this is ace!
Can I have one if still available? built or kit is fine with me.
Thanks!
James
BBC Model A Issue 3 (Upgraded to Model B, had it since I was a kid), Opus Dual 40/80 FDD, Watford Mouse, Voltmace delta 14/B, Gotek, IFEL ROMRAM-B4, Pi-Zero CoPro
Master 128, VideoNuLA, Gotek
andrewvideo
Post by andrewvideo » Wed Apr 24, 2019 6:41 pm
Excellent. 😊😊
dp11
Post by dp11 » Wed Apr 24, 2019 9:37 pm
Sorry for the silence . I'll be ordering some bits soon. I have no plans to make assembled boards, I have no issue in someone else assembling boards.
I've been busy with some other things. I can confirm my SDCARD has a read performance of 93KB/s . Write speed is much slower 33KB/s. This could possibly be improved, but will need a bit of work. I hope to release a new filesystem speed test soon.
During speed testing I did corrupt the ADFS FSmap while probing the Pizero with the scope probe. If anyone is good with recreating Harddisc FSMAP I would be interested to hear from you.
KenLowe
Post by KenLowe » Wed Apr 24, 2019 11:30 pm
I don't know if this might help...
viewtopic.php?f=3&t=2022&p=13964#p13964
Edit: Link updated 2x!
andrewvideo
Post by andrewvideo » Thu Apr 25, 2019 10:06 pm
Thank you very much.
andrewvideo
Post by andrewvideo » Thu Apr 25, 2019 10:12 pm
Is any plans to have access to ADFS harddisk other WiFi?
BobsBoard
Post by BobsBoard » Fri Apr 26, 2019 7:06 pm
Hi Dominic,
Could you kindly put me down for a couple of boards and a set of parts once they are in (and life is not in the way). I keen to have the sounds of the M5000 up and running.
may thanks,
Roger
BBC-A Series 3, upgraded to B by me in 1984), with Watford 13 Rom Board and 8271 DFS. BBC B Series 4 (8271) with 4x28c256 mod. BBC Series 7 with 1770DFS all running SPI-MMC
RC6502 Apple 1 Replica, Z80-MBC2 and building an FPGA 6502.
dp11
Post by dp11 » Mon Apr 29, 2019 6:00 pm
I've just updated the code on Github. This fixes an issues where the FIQ handler could be evicted from the cache on Pizero, which then meant it might not respond quickly enough if other internal bus activity was occuring.
I would recommend everyone to upgrade , especially if they are using the harddisc emulation.
courseddent
Post by courseddent » Wed May 01, 2019 4:39 pm
Hi, could I also be put down for a kit/board if this is still possible? Many thanks!
KenLowe
Post by KenLowe » Tue May 07, 2019 4:09 pm
dp11 wrote:
Wed Apr 10, 2019 7:55 pm
I'm just getting ready to do a release.
KenLowe wrote:
Thu Apr 11, 2019 5:16 pm
If you've still got any spares, a couple of full kits is definitely something I'd be interested in.
Ken.
Have I missed out on this, or is it still a work in progress?
Ken.
dp11
Post by dp11 » Tue May 07, 2019 4:53 pm
Sorry been a bit snowed under. Should hopefully get back on to it at the weekend.
dp11
Post by dp11 » Mon May 20, 2019 8:23 pm
It is clear to me that I'm a bit slow at ordering and sending out hardware kits . Does anyone want to support / take over that hardware supply? I still want to support this and future projects. If someone could take the load off me I can focus on development work.
myelin
Post by myelin » Tue May 21, 2019 8:26 pm
Can you post the gerbers / PCB design? I'd be happy to order and post out a few of them, and write up instructions for how to get the components.
Post by Elminster » Fri Jul 05, 2019 7:00 pm
Started building this and noticed in Dave’s pictures there seems to be a resistor not populated?
Also the job2.pdf opens blank for me, anyone else having that issue?
Post by RobC » Fri Jul 05, 2019 9:18 pm
That's correct - can't remember what it's for though (possibly the audio across the 1MHz bus?)
Only if I try to view the pdf in a browser. It's okay in Acrobat reader.
Post by Elminster » Fri Jul 05, 2019 9:36 pm
Just checking. Probably forget and solder it in anyway.
Doesn't open on Macs build in PDF viewer either, very rare that. Only a handful of pdf in the last decade. Must be something odd like a secret adobe feature that on;y works on acro reader.
dp11
Post by dp11 » Fri Jul 05, 2019 9:54 pm
The no fit resistor is part of a voltage divider that turned out not to be needed.
The pdf contains a 3d image that you can rotate so you need real acrobat.
Post by Elminster » Fri Jul 05, 2019 11:47 pm
Ah I see. I have built it without the resistor, will test it once I get chance, wading through backlog of soldering projects.
Looks like I avoided installing any adobe products this time around.
courseddent
Post by courseddent » Sat Aug 24, 2019 3:38 pm
I'm still really interested in getting one of these - is anyone here up for getting a kit version or finished one together? More than happy to pay for time and parts.
marcusjambler
Post by marcusjambler » Mon Aug 26, 2019 8:47 pm
I finally got round to building mine today :D
=D> =D> =D>
ADFS is working great... booting into DOS+ no problem.
I've got the M5000 running from a system disk I downloaded..
"{filename}" LOAD RUN is working with the AMPLE disks.
One thing is the level of background noise whenever the unit is plugged in.
I'm thinking that it is a consequence of injecting the audio back onto the bus.
Is that the case?
Marcus
Post by Elminster » Tue Aug 27, 2019 8:39 am
I built mine last week, it didn’t work first time but before I could diagnose issue I dropped the sdcard down the back of a cupboard. Need to find another sdcard now so I can debug issue. Hopefully next week I my get time.
dp11
Post by dp11 » Tue Aug 27, 2019 9:08 am
Audio via the 1MHz bus is a bit noisy, but does make M5000 nice and easy to try. One of the bigger Pis with an audio jack gives stereo and better quality.
I'm sorry I will get around to sorting out the email/ PMs I have from people.
