Raspberry Pi to 1MHz bus interface
dp11
Post by dp11 »
I've designed a small PCB to connected a Raspberry Pi to the 1MHz bus . It is designed to fit under and Beeb or a master with a PiZero.
It is designed to be easily assembled and so only uses through hole parts, just resistors and diodes and connectors.
I might in future think about putting together a kit of parts.
I'm just about to get a batch of PCBs made on a reasonably quick turn around. If you want to be a very early adopter let me know and I'll up the order size. Blank PCBs are £2 + postage.
At this stage this is untested , and I may never actually complete the Pi code.
Re: Raspberry Pi to 1MHz bus interface
Post by hoglet »
Put me down for one please.
Post by Elminster »
I can put one together on my next mass solder day. Put me down for one please. I am good as breaking stuff in testing, which is what you want ?
fordp
Post by fordp »
I will take one please.
FordP (Simon Ellwood)
IanB
Post by IanB »
Put me down for 5 please.
marcusjambler
Post by marcusjambler »
Please put me down for two boards :)
Post by paulv »
I'd be interested in two please.
myelin
Post by myelin »
Please put me down for two. Thank you!
SW/EE from New Zealand, now in Mountain View, CA, making Beeb/Elk/Arc hardware projects for fun.
Most interesting: Arcflash, POST Box, Ultimate Electron Upgrade
Post by RobC »
I'd like two if possible please.
Post by BeebMaster »
What does it do? I mean, will the Pi be used to emulate 1MHz bus devices like hard discs, Teletext adapter, Music 500 etc?
dp11
Post by dp11 »
It doesn't do anything yet. But it should be possible to emulate 1MHz bus devices in the Pizero.
Post by hoglet »
dp11 wrote:
Mon Oct 15, 2018 8:08 pm
This, of course, is left as an exercise for the interested reader. :lol:
Beyond me I think, but hopefully somebody will! And as a vote of confidence in the ability of others, put me down for 4 of the interfaces please!
dp11
Post by dp11 »
I do a few plans , but don't want to over sell it at this moment.
IanB
Post by IanB »
You do realise if we keep going on this way, the beeb will have a Raspberry Pi stuck in every port :lol:
I'm sure a Raspberry Pi floppy disc is a possibility...
tom_seddon
Post by tom_seddon »
Sign me up for two please!
--Tom
Post by paulv »
BeebMaster wrote:
Mon Oct 15, 2018 10:14 pm
Technically, that's been done using Linux as a server on the Pi and a bit of custom jukebox server code with a hacked DFS and custom user port to USB cable that emulates a SCSI type system to pull data over the cable. IIRC.
It was done around the same time as UPURS and put out as an open source project so is entirely reproduceable.
TBF though a Gotek does a better "less fuss" job these days and leaves the user port free for other things.
dp11
Post by dp11 »
PCBs are due back next week. I'm just about to buy the connectors etc . For an extra £2.00 I will supply all the bits except the cable and connector to get +5v to the board .
dominicbeesley
Post by dominicbeesley »
One for me please too...
rharper
Post by rharper »
OK, I'll try one please
Ray
Raycomp
Post by paulv »
dp11 wrote:
Sun Oct 28, 2018 4:25 pm
That sounds like a plan. :D I'll definitely take you up on this.
Post by tricky »
I'll take a couple with bits please.
fordp
Post by fordp »
A bit quiet round here #-o
dp11
Post by dp11 »
Sorry life has got in the way. 1st PCB assembled and tested on a Master. Code written to emulated Acorn Paged RAM expansion and http://www.sprow.co.uk/bbc/ramdisc.htm . I now have 16Mbytes on the 1MHz bus with a PiZero. :)
fordp
Post by fordp »
Sorry I just noticed this. Anything I can do to help, I have quite a few ideas for this board ;)
dp11
Post by dp11 »
Sorry for the delay. Lots of life got in the way.
I'm just getting ready to do a release.
Just to give you a hint of what is coming. The supported RAM via JIM is now 480MBytes ! hopefully that will be enough ( like 640K !) This RAM can also be preloaded from SDCARD.
dp11
Post by dp11 »
Music 5000 is also now supported. Even plays through the Beebs internal speaker.
If you use a RPI3B+ you can use the headphone jack for audio and get 992Mbytes of RAM to play with.
KenLowe
Post by KenLowe »
If you've still got any spares, a couple of full kits is definitely something I'd be interested in.
Ken.
dp11
Post by dp11 »
Now also emulates an ADFS harddisc. Read performance is about 100K/sec
