Retro Hardware ARA III - Low Cost Writable ROM Cartridge - For the Electron and Master
Post by daveejhitchins » Tue Sep 04, 2018 11:35 pm
New ARA III - Advanced ROM Adaptor Mk III - This is a low cost writable ROM cartridge, for the Electron and Master, using a single 28C256 (EEPROM) and GAL16V8D with a PCB jumper for disabling/enabling write protection - a switch could be connected to this header.
When used with the Electron, JGH's New Plus 1 Support ROM Utilities work as listed in the User Guide. When used with the Master, MartinB's Utilities work just fine.
The board has been developed for Dave Moore (Arcadian) as a low cost Games Cartridge to be used at some of the shows he runs. As a result of trying to keep the costs down to an absolute minimum I'll be ordering more than Dave needs and I'll be making them available to everyone at just about cost price. You'll be able to order just a PCB (it will have gold plated edge connectors) or built PCB - both with a 3D printed case option.
The prototypes have one Mod. (see below for details) but work fine with the Mod. in place. They don't have gold plated fingers! I have 9 spare PCBs at £3.50 each which includes UK postage. I'll list the BOM and GAL file tomorrow. I can also provide a kit of parts or build them up if needed.
The Mod. involves cutting some tracks above the GAL placed in a way that makes hem easy to cut! Why . . . I read the datasheet (it's been a long time since I read it fully!) and followed these instructions:
The GAL16V8 input and I/O pins have built-in active pull-ups. As a result, unused inputs and I/O's will float to a TTL "high" (logical "1"). Lattice Semiconductor recommends that all unused inputs and tri-stated I/O pins be connected to another active input, VCC, or Ground. Doing this will tend to improve noise immunity and reduce ICC for the device.
Don't, as it seems to screw-up the operation of the device!
I'll post the 'production' pricing as soon as it's available.
Re: Retro Hardware ARA III - Low Cost Writable ROM Cartridge - For the Electron and Master
Post by MartinB » Tue Sep 04, 2018 11:52 pm
I’ll take one with a kit of parts Dave - let me know the price. Do my utilities also work with the cart in an Elk?
Post by Elminster » Wed Sep 05, 2018 12:28 am
I might take a blank board from you, I seem to have space gals :)
Add to my collect of ARA 27c only and tweaked ABR SRAM, 27c or 28c. Means I could have one board with a eprom, one with SRAM and one with eeprom all at the same time. Not sure why I want to do that. So if over subscribe then happy to let someone more needy have it. Otherwise can collect one at Cambridge?
Post by tricky » Wed Sep 05, 2018 7:40 am
I'll take two with parts (one if you have too many takers).
Post by daveejhitchins » Wed Sep 05, 2018 7:45 am
Martin: See listing below for what you need . . .
Re Your utilities - yes they do work - I do have issues, though! When used with the Master or Electron I think you may be 'corrupting' some workspace, as I've found it mandatory to Ctrl/Brk (just a Brk wont do!) between commands. I'm still not sure about your use of the inbuilt Lock! - It seem as though no matter what I do I always have to unlock first - I've never used your EEP32 LOCK xx command! Can the Lock/Unlock command be integrated with EELOAD?
Post by daveejhitchins » Wed Sep 05, 2018 7:49 am
@Tricky and Elminster . . .
I'll bring boards and components to Cambridge . . .
Post by daveejhitchins » Wed Sep 05, 2018 8:44 am
ARA III BoM - (as at 05-09-18):
PCB				£2.50
28C256				£1.63
GAL 16V8 (programmed)	        £1.05
28 pin IC socket (std)		£0.41
28 pin IC socket (LP)		£0.62 - Needed for 3D printed case
20 pin IC socket (std)		£0.32
20 pin IC socket (LP)		£1.00 - Needed for 3D printed case
Resistor (10K or 12K)		£0.02
2 x 100n Capacitor (X7R)	£0.20
Right angled header		£0.04
Jumper				£0.05
3D printed case			£3.16
Note: You don’t really need IC sockets!
P&P to UK at cost
Just let me know what you actually need!
Edit: Cap price updated.
Last edited by daveejhitchins on Wed Sep 05, 2018 9:08 am, edited 1 time in total.
Post by daveejhitchins » Wed Sep 05, 2018 8:52 am
GAL16V8D - WinCUPL - Drop-in text file:
Name     ARA_III_V1 ;
PartNo   16L8 ;
Date     23-08-18 ;
Revision 01 ;
Designer D.E.J.Hitchins ;
Company  Retro Hardware ;
Assembly Advanced ROM Adaptor III ;
Location IC2 ;
Device  g16v8a ;
/* *************** Revision History *************************************/
/* *************** INPUT PINS *******************************************/
PIN 1   =  NOE                     ; /* Not-Output Enable               */
PIN 2   =  ERNW                    ; /* Electron Read/Write - Master CS */
PIN 3   =  QA                      ; /* Page latch LSB                  */
PIN 6   =  T2                      ; /* CPU clock phase 2               */
PIN 8   =  MADET                   ; /* Master detect - Low if Master   */
PIN 9   =  MRNW                    ; /* Master Write - Electron N/U     */
/* *************** OUTPUT PINS ******************************************/
PIN 12  = !NCS                    ; /* Not-Chip Select                  */
PIN 13  = !OE                     ; /* Not-Output Enable on Read Only   */
PIN 19  = !RNW                    ; /* Low output Read Not-Write        */
/* *************** LOGIC EQUATIONS  *************************************/
NCS =    MADET & !NOE & T2                      /* Electron             */
      # !MADET &  ERNW & T2;                    /* Master               */
OE  =    MADET & !NOE & ERNW                    /* Elk nOE Only on read */
      # !MADET & !NOE & MRNW;                   /* MAS nOE Only on read */
RNW =   !MADET & !MRNW                          /* Master write         */
      #  MADET & !ERNW;                         /* Electron write 2     */
Post by daveejhitchins » Wed Sep 05, 2018 11:25 am
And . . . The final schematic:
And a .pdf
Retro Hardware ARA III - 05-09-18.PDF.zip
(74.61 KiB) Downloaded 26 times
Post by Elminster » Wed Sep 05, 2018 11:37 am
As I have been trying to get my head around this Electronics thing. Isn't the GAL a bit of an over kill for what you are doing with it, couldn't you use a few 74LSHCTs? As thete is plenty of real esate left. Or would that work out more expensive?
Post by davidb » Wed Sep 05, 2018 12:02 pm
It's good to see something like this - the low cost nature of it is one of the aims I had for my cartridges.
Thinking about saving pennies here and there, how about using the SST39SF010A-70-4C-PHE-ND Flash ROM instead of the 28C256? I know it's a larger components and much of its capacity would be wasted in a simple 32K ROM configuration but it's potentially quite a bit cheaper.
Post by Elminster » Wed Sep 05, 2018 12:07 pm
Could you still get the 28pin 28c256 to work electrically in the 32pin holder? For some reason I cant see the datasheet.
People already have a lot of 28c256s floating about. Well I do, some in Electron, some in master, some in RC2014 etc. None of which would work with a 32 pin part.
Post by 1024MAK » Wed Sep 05, 2018 1:05 pm
Hi Dave :D
I am interested in buying two ARA III kits if possible.
I'm happy to have the prototype boards or if you have run out of those, the 'production' boards.
PCB				£2.50
28C256				£1.63
Jumper				£0.05
Also I would like to buy these parts:-
UM6502CE, QTY=2
R6522, QTY=4
AT28C256, QTY=2 (in addition to the two required for the ARA III)
If you can bring to Cambridge later this week, that would be good. If not, sending by post would be fine (I'm not in a rush).
Post by davidb » Wed Sep 05, 2018 2:01 pm
Not without some pin remapping which would probably involve clipping legs off the IC and using jumper wires, as far as I can tell. :(
Post by tricky » Wed Sep 05, 2018 5:54 pm
No sockets for me, collection from Cambridge would be great.
Post by daveejhitchins » Wed Sep 05, 2018 6:01 pm
I started off trying to do it the TTL way, but soon found that as a minimum it would be two parts and most probably three (there's a challenge!) - The GAL16V8D that I have, at £1.05, does the job in one part - and it's not too much of a squeeze - keeps the board size down and only 20 pins to solder. Of course there's the added advantage that if I'd made a cock-up of the logic - it's easily re-programmable.
Last edited by daveejhitchins on Thu Sep 06, 2018 8:25 am, edited 1 time in total.
Post by daveejhitchins » Wed Sep 05, 2018 6:11 pm
So it is - Several problems: Slightly bigger IC socket needed (if you use sockets, that is) : I'd want to use the whole capacity, somehow :oops: : I don't have them in-stock, so it would have meant more cash layout! Also, does MartinB's Utilities work with it?
Post by daveejhitchins » Wed Sep 05, 2018 6:17 pm
I'll get everything ready for you, Mark . . .
Thanks - Dave H :D
guddler
Post by guddler » Wed Sep 05, 2018 6:37 pm
Could I take one with a 3D case please? I don't need it soldered or anything as I'm fine with that but I probably don't have any low profile sockets. I probably have a GAL, I'd need to check. I have a box of them, just need to check which ones they are.
In summary probably a kit please :)
PS: Have you made any kind of cutout in the case for a switch?
Post by daveejhitchins » Wed Sep 05, 2018 10:44 pm
PM sent . . . Re the switch - Watch this space :wink:
Post by tricky » Thu Sep 06, 2018 7:20 am
I was also thinking about a switch, but to swap the two 16K slots over (not ROM_QA/A14 I guess).
I'm happy to make a few mods if necessary, and I guess there is a spare pin on the GAL that could provide it.
The reason is that when my games are loaded as utility ROMs, they will "auto-boot" if they are in SLOT 0 (untested on HW).
The idea is two have two 16K games and be able to swap which one boots if the cartridge is in the far slot (may be of interest to Dave).
I guess that these cartridges are really good value and this isn't really necessary :roll:
I was actually planning on making a more basic cartridge with just a 32KB EPROM, cap, transistor and switch; but that is a story for another thread.
Post by davidb » Thu Sep 06, 2018 11:43 am
Using the whole capacity would mean using jumpers or switches if we were keeping it inexpensive; otherwise it would need the paging logic of the MGC or my Multi-ROM cartridge. It's programmed in the same way as the 28C256 so I think MartinB's utilities would work with it.
Post by Elminster » Thu Sep 06, 2018 1:39 pm
I wonder if it would be feasible (but maybe not cheap). To put a 32 pin socket on and then use a jumper and more of the GAL so select what signals go where. Best of both worlds then.
Post by 1024MAK » Sat Sep 08, 2018 6:27 pm
Is this drifting into feature creep territory!
guddler
Post by guddler » Sat Sep 08, 2018 7:17 pm
Does that perhaps mean we might be able to connect the jumper to the gal instead of using a switch or something like that??
[EDIT] Never mind - having just looked at the schematic and the GAL logic I think I may have misinterpreted the intention of the switch :D
Post by CMcDougall » Sat Sep 08, 2018 7:23 pm
^seems that way Mark 8)
next folk will want a build in Blu-Ray player & full 4k TV :lol:
nice little gizmo Dave ,
PS your tape & extra eprom is with Postman Pat :wink:
guddler
Post by guddler » Sat Sep 08, 2018 9:55 pm
Happy to report that mine is all built and working - many thanks, one happy chappy here :D :D
I'll let someone else snag one of these cheap pre-production ones but when they go into production then I think I'll grab another for slots 2 / 3.
Post by daveejhitchins » Sun Sep 09, 2018 9:39 am
Thanks and thanks Col . . . :D
p.s. I'm planning to modify the case to take a small switch for the write protection. I had planned to hack a case here at Cambridge, however, I don't think I can do it neatly enough - hence a small mod to the case design. But that's for when I get back from holiday . . .
Post by jgharston » Mon Sep 10, 2018 7:06 pm
Forgot to ask at ABUG, but would a AQR version of this be do-able? 16 banks of 16K of persistant storage, selectable with the *AQRPAGE command already in the AP6 support ROM.
Edit: and regarding our chat about the 2x16K memories, make the paging register at &FCFC readable as well as writable! :)
Post by daveejhitchins » Wed Sep 12, 2018 9:58 pm
The AQR is on the list. I actually bought the memory for it ages ago - chance purchase. I plan to have 2 x AQR in the same case - But not RAM - So, I would think, all of the old software wouldn't work without extensive rework - even then the printer buffer and RAM disc would be out!
It would be nice to have one half RAM and the other EEPROM - but . . .
