Microcitec Cub 452 (Lack of) Display Issue
dhoggan
Post by dhoggan »
I've managed to pick up a Cub 1431 in reasonably good condition, but it seems to have a bit of an issue. It powers on but all I get is the following, whether or not I have the RGB cable plugged in.
The front
The front
What is interesting is that it has more options than other Cubs I've seen on the rear:
Rear with unusual connector options
I've tried the switch in both positions - not really expecting it to work, but to see if anything changes. IN the TTL position I get the above output, in the 75ohm position, just a black screen. I have tried generating some output (*HELP) to see if it changes the display, but nothing obvious.
I've read a couple of other posts on Cub monitor issues, but they were more about rolling pictures, not no picture!
Any ideas what this might be/is is repairable/where to start?
Model B Issue 7 - Dual Gotek/5.25"; IFEL Sideways board; RetroClinic Co-Pro; VideoNuLA
Master 128K - Gotek; RetroClinic Co-Pro, CF HDD & DualOS
Main interest: BBC computer languages
Re: Microcitec Cub 452 (Lack of) Display Issue
Post by 1024MAK »
The other inputs are analogue red, green, blue and sync inputs (all terminated at 75 ohm). When using with a Beeb, you can ignore them. When using the DIN socket, the switch needs to be in the TTL position.
I'm on a phone at the moment, so can't see the photo very well. Is it showing a bright horizontal line at the top, but with no other illumination of the screen?
Does this line disappear or go dimmer if the Beeb is switched off or disconnected?
dhoggan
Post by dhoggan »
Hi Mark,
There's no obvious change in the lines with the BBC on or off, or even unplugged. And yes, you've described it exactly. The slight glow on the screen is simply as I've upped the brightness a bit, but the display is two or three fines lines - not a single line. It appears that these are scrolling horizontally. I did manamge to get them to stop scrolling when I unplugegd the RGB cable, but a power off/on and they were scrolling agian.
I wIsh I had an analogue RGB source - that way I could test the 75ohm side - I'm guessing that would prove the tube is OK. Unfortunatley I don't have anything to use as a source.
Thanks,
Post by 1024MAK »
I don't think using the analogue inputs would make any difference. I think this fault may be a problem with the electron beam scanning system. It looks like the horizontal scan may be partly working, but it appears to me that vertical scan is not working.
Most CRT displays, when the brightness and contrast controls are cranked up to maximum, result in a glow across most of the screen. Sometimes this even works with no signal.
There are however other possible faults, but this looks most likely.
The good news is that the EHT circuit is working, as is the Tube, so this could well be repairable.
dhoggan
Post by dhoggan »
Ah, thanks. So, there is hope :-)
I guess the question then is: repairable by someone of average competence (me!) or by a specialist? As Microvitec no longer do repairs themselves (at least according to their web site), is there someone who repairs Cub monitors that anyone here could recommend?
Other than this it is in quite good condition, so it would be a shame to bin it.
Thanks,
Post by daveejhitchins »
dhoggan wrote:
Fri Aug 17, 2018 7:22 pm
You need to find one of the remaining TV repair shops that's run by an old guy who has the experience of CRT sets (very rare these days!). I'm fortunate, here in Newton Aycliffe, as we have just such a person that meets all those requirements - and has made the transition to LCD/Plasma TV repairs . . .
dhoggan
Post by dhoggan »
Hi Dave,
Thanks for the info and sounds like he might be a good place to start. Do you have an email address for him? I’m hoping he would be happy for me to ship it - assuming that he’d be intested.
Would have sent a PM, but that feature is still disbaled :-(
Thanks,
Kazzie
Post by Kazzie »
dhoggan wrote:
Sat Aug 18, 2018 12:28 pm
Hi Dave,
Thanks,
Click the "Contact Us" link at the bottom of the page and you can ask a moderator administrator to enable your PM abilities. They're usually very happy to do so for anyone who asks.
RiscPC 600 under repair
Thanks for the info and sounds like he might be a good place to start. Do you have an email address for him? I’m hoping he would be happy for me to ship it - assuming that he’d be interested.
Let me give him a ring on Monday . . . I'll report back here.
daveejhitchins wrote:
Sat Aug 18, 2018 10:19 pm
Sorry, I did ring . . . He's on holiday - just forgot to let you know :?
dhoggan
Post by dhoggan »
Hi Dave,
No problem - right now I’m in the middle of building a log cabin so all my attention is on that. But I will then actually have a place to permanently setup the Beeb, so happy to wait. It’ll just be good to know whether he’s willing out not so I can add it to my options.
Thanks,
