Duncan, if you want me anything to Cambridge, let me know.
With regards to the mice, keep in mind there are two slightly different pin-out / connection schemes for user port mice / track balls. Some software supports both, some, only one. All mice that connect to the user port are "bus" mice. So with a suitable passive adaptor lead, Atari ST, Amiga, Archie or the very rare IBM compatible PC bus mice can all be connected and used. Or in theory, any of the modern PS/2 or USB active adaptors (although some modern USB mice may have too good a resolution, so may not work very well in practice).
