Monitors
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 2:24 pm
So, here's the video output to AV (yellow to yellow): providing a relatively crisp
image with no colours (suits me for teaching BBC BASIC):
similarly, video output to SCART: providing a relatively crisp
image with no colours:
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 2:28 pm
Here's the UHF out that involves tuning tellies:
Well, you do get colours: but at a crappy low standard.
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 2:30 pm
Here's the Retro Clinic RGB DIN to SCART:
By far the best {and that's even visible even when my hand was wobbling].
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 2:32 pm
During the week I'll play silly buggers with the TVs and my BBC Master Compact.
Looking forward to Andro's arrival with the "Yellow" to VGA connectors on the 20th.
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:03 pm
white is all the colours RGB together :)
try mode 2 for colour
or in mode 7
vdu129, or vdu130,131,132,133 enz
if colours are not the right one maybe reverse colours ?
or burst is not good :)
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 6:15 pm
I was just running MODE 5 as a rough guide.
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:21 pm
try mode 7
vdu 129 return
type text
vdu 130 return
type text
enz,enz
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:28 pm
is your monitor a colour monitor ?
richmond62
Re: Monitors
Post by richmond62 » Sun Jun 10, 2018 6:33 pm
Look at my photographs before you ask me questions like that. :D
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:42 pm
your pictures are in colour but :D
what happens with
vdu129 in mode 7
then text ?
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:48 pm
mode 7
vdu 130 return
text
vdu132 return
text
duikkie
Re: Monitors
Post by duikkie » Sun Jun 10, 2018 6:53 pm
allso do this
with
uhf out on tv
richmond62
Re: Monitors
Post by richmond62 » Wed Jun 20, 2018 10:52 am
What a "bother" !
"The Boy" arrived last night with the RCA to VGA converters, and they just
do NOT seem to pick up a signal from either the Model B or the Master Compact.
Would be most grateful for a few "pointers' if possible.
Richard Russell
Re: Monitors
Post by Richard Russell » Wed Jun 20, 2018 11:50 am
RCA to VGA converters, and they just do NOT seem to pick up a signal from either the Model B or the Master Compact.
Are you sure they are for 625-lines (PAL) rather than 525-lines (NTSC)? The term 'RCA' for a baseband composite video connection is probably more commonly used in the USA.
richmond62
Re: Monitors
Post by richmond62 » Wed Jun 20, 2018 12:04 pm
To be honest I'm not sure if they are anything:
Connected to the Yellow & White Output sockets of a television that can manage
PAL, SECAM & NTSC I get NO signal on my VGA monitor.
BUT that is probably because I ordered 3RCA to VGA cables (which is what is marked on the outer packets):
but the inner packets are labelled "VGA to 3RCA": so I have been cheated.
Re: Monitors
Post by danielj » Wed Jun 20, 2018 1:30 pm
How exactly are those cables wired? I don't know of any VGA monitors that will accept a composite signal on their inputs, especially not one with a horizontal frequency of 15KHz like the beeb puts out?
You need something to actually electrically convert the signal from composite to VGA, e.g.:
https://www.amazon.co.uk/dp/B00MV1GVZY/ ... ZY53307509
richmond62
Re: Monitors
Post by richmond62 » Wed Jun 20, 2018 1:53 pm
I dinnae ken, and I'm not going to see my way clear til opening them up to see.
This is the label on the envelope of what I ordered:
AND here is what was marked on the inner bag:
AND here is a film poster:
What they sent me were VGA to RCA (just checked by sending a PC signal out through an old telly).
Almost inevitably I start thinking of the phrase "Long Pork."
Re: Monitors
Post by danielj » Wed Jun 20, 2018 6:34 pm
Weeelll - I don't think it's going to work for you. You definitely need something to convert the signal.
richmond62
Re: Monitors
Post by richmond62 » Wed Jun 20, 2018 7:05 pm
Notwithstanding that, I shall still send Amazon.co.uk a distinctly negative feedback note re those cables.
Ha, ha, ha; Amazon would not publish my review, presumably because I stated that I had been cheated.
