Disc rot on 5 1/2” disc
Lardo Boffin
Post by Lardo Boffin » Mon May 21, 2018 11:42 am
I received a disc today and unfortunately it looks like this:-
The rot (I assume it is rot) is not isolated. Anything I can do about it? I don’t want to chuck the discs.
BBC Master
vanpeebles
Re: Disc rot on 5 1/2” disc
Post by vanpeebles » Mon May 21, 2018 12:01 pm
You can clean it with a cotton bud and distilled water. I have a load to clean I keep putting off :lol:
Post by 1024MAK » Mon May 21, 2018 12:12 pm
I strongly recommend that you remove your jacket.
Lardo Boffin
Post by Lardo Boffin » Mon May 21, 2018 1:06 pm
1024MAK wrote:I strongly recommend that you remove your jacket.
I’m assuming a very sharp knife is involved in this! What is the best way to reseal it afterwards?
BBC Master
vanpeebles
Post by vanpeebles » Mon May 21, 2018 2:11 pm
Maybe he meant smoking jacket? :lol:
Lardo Boffin
Post by Lardo Boffin » Mon May 21, 2018 2:31 pm
vanpeebles wrote:Maybe he meant smoking jacket? :lol:
Never!
BBC Master
jonb
Post by jonb » Mon May 21, 2018 4:58 pm
Nasty..
Take the disc out of the jacket as Mark says. You will probably find the inner sleeve is covered in mould. I've recently been swapping disks and jackets over to good effect - the secret with the sleeves is to try and cut where they are joined (by the fold opposite the head slot), then you can unfold, remove, refold.
Seal along the fold with black insulation tape, but you needn't bother, especially if you are recovering the data to copy to fresh disks.
Lardo Boffin
Post by Lardo Boffin » Mon May 21, 2018 7:27 pm
jonb wrote:Nasty..
Thanks - I hope to try not to destroy them as they are original copies of Wasteland for the C64 and *ahem* not very cheap. I will get some practice in first - I have a few discs that won’t read so will try on them first.
BBC Master
Post by 1024MAK » Mon May 21, 2018 7:36 pm
<in a wonderful world where new disks are readily available> Discard any jackets that are affected / have the rot. Carefully clean any affected disks. I heard that plain soap helps, but not tried this. Once the disk is clean, allow to dry. Then, once completely dry, put in new jacket. Copy data off onto a new disk using a suitable disk coping system. Check new disk works. Discard old disk...</in a wonderful world where new disks are readily available>
If using a 'cleaned' disk for normal use, your mileage operational time may vary... You should try to only use such disks in a drive where the magnetic heads have resin in/over the gap, instead of heads that just have an air gap. As crud from the disk will accumulate in the gap and clog it up...
Lardo Boffin
Post by Lardo Boffin » Mon May 21, 2018 9:39 pm
Thanks. I suspect these may be ‘for display only’ then. The data is already out there so there is no pressing need to extract it.
BBC Master
