myelin’s Econet Hub
lcww1
myelin’s Econet Hub
Post by lcww1 » Sat May 05, 2018 4:31 pm
A little while ago myelin very kindly sent me one of his Econet Hub pcbs - viewtopic.php?f=3&t=8000&p=199657&hilit ... ub#p199657
the project is described here: https://github.com/google/myelin-acorn- ... /README.md
the hub combines a clock, line biasing, 5 Econet sockets, and a usb socket to provide power.
I’ve finally found some time to get this soldered up:
myelin’s Econet Hub
Now I just need to program the ATTINY and give the thing a test! :D
Thanks to myelin for sharing this!
lcww1
Re: myelin’s Econet Hub
Post by lcww1 » Sun May 06, 2018 12:49 pm
So, I made a rookie error with the smd micro usb connector for the hub - I somehow managed to use a reversed usb socket, and in consequence I allowed the magic smoke to escape from the attiny when I powered up the hub for the first time #-o
However, myelin had the foresight to send me two of his econet hub pcbs :D so I proceeded to built up the second board. This time, I’m powering the board via a couple of pin headers via an arduino. The hub is now working very nicely, and I’ve successfully programmed the attiny, and used it to form an econet between my BBC Master and my RiscPC (fitted with my glorious econet module podule :oops: as described here http://www.stardot.org.uk/forums/viewto ... 60#p202469).
This hub is a really neat and efficient way to quickly set up an Econet, combining as it does the clock, terminators, and hub in one. If there was an Econet solution for the Raspberry Pi :?: , then a Pi together with this hub would make a very portable Econet solution........
Second attempt at myelin’s Econet hub......
Here’s JGH’s natty Talk Econet conferencer running on the RiscPC to chat with my Beeb:
Econet Talk
Post by 1024MAK » Sun May 06, 2018 3:20 pm
Your workspace is just as tidy as mine! :lol:
Shame you let the magic smoke out. Has to be said, I'm not a fan of all the small form factor USB connectors :(
Give me the 2.1mm/5.5mm power connectors any day.
myelin
Post by myelin » Sun May 06, 2018 7:51 pm
Nice work! This is the first successful econet setup using my hub design, as I haven’t gotten my own one working yet :)
That module podule (which I thought had to be a typo at first, before taking a look and finally understanding the joke :) ) looks very nice also.
lcww1
Post by lcww1 » Sun May 06, 2018 10:05 pm
1024MAK wrote:Your workspace is just as tidy as mine! :lol:
I’m congenitally messy, alas! And my tendency to do too many things at once doesn’t help ......... :?
myelin wrote:module podule (which I thought had to be a typo at first, before taking a look and finally understanding the joke :)
I’m afraid that I couldn’t resist that bit of silliness :D
myelin
Post by myelin » Mon May 07, 2018 12:07 am
1024MAK wrote:Shame you let the magic smoke out. Has to be said, I'm not a fan of all the small form factor USB connectors :(
I feel that micro USB is becoming the new standard for powering stuff at 5V thanks to ubiquitous USB power supplies, but I can see if I can fit a barrel jack on the next version of the board :)
ask_nz
Post by ask_nz » Mon May 07, 2018 7:52 am
What a great idea - Kiwi ingenuity ;)
Ade
Post by 1024MAK » Mon May 07, 2018 8:15 am
myelin wrote:I feel that micro USB is becoming the new standard for powering stuff at 5V thanks to ubiquitous USB power supplies...
Yes. It's okay for low power electronics which is what the intended purpose was. But from a power engineering point of view, it's all a bit of a mess. Low voltage distribution meaning that for any significant amount of power you need higher currents. USB cables made with thin conductors causing voltages losses. Small connectors with small contacts that further increase voltage losses. Hard for the consumer to tell cheap USB power only cables from USB data cables...
myelin wrote:...but I can see if I can fit a barrel jack on the next version of the board :)
That would be much appreciated :wink:
I'd be interested in buying a new board :mrgreen:
lcww1
Post by lcww1 » Mon May 07, 2018 8:59 am
1024MAK wrote: I'd be interested in buying a new board :mrgreen:
I’d like to build a couple of these hubs, and add some casing to provide protection and longevity - I’m thinking that one easy solution would be to wire up panel mount DIN sockets rather than using pcb mounted sockets (just like in the Acorn Econet bridge), and then put the thing together in the same way as the retro-kit Econet socket box shown here https://www.retro-kit.co.uk/page.cfm/co ... ocket-Box/. In building the hub this way, one could then happily provide power via a panel mount jack socket wired to the board, without needing to change the pcb :D
myelin
Post by myelin » Mon May 07, 2018 4:39 pm
1024MAK wrote:I'd be interested in buying a new board :mrgreen:
lcww1 wrote:I’d like to build a couple of these hubs, and add some casing to provide protection and longevity
I believe I have 7 more PCBs, and I doubt I'll want to make more of them for myself, because I have less than 5 Econet capable machines, so if either of you would like, I can post you a couple (a couple more, in Liam's case) PCBs.
I'm pretty sure I'm going to do a second version of this board in any case, so feel free to throw in suggestions here! So far my own notes are:
- add mounting holes
- fix the attiny85 footprint and make more room around it for soldering/desoldering when the Econet sockets are mounted
- barrel jack power input
- maybe add another two sockets (stretching the board out another 20mm or so)
Liam -- are the holes for the PCB-mount sockets big enough that you could use them to wire up panel mount sockets? If not, there are two headers on the top left of the board that are wired into the Econet signals, so you could use those for two sockets. I could also just resize the board to exactly fit a case, or a case could be 3D printed to match the board, which would give you a nice solid fit.
lcww1
Post by lcww1 » Mon May 07, 2018 5:51 pm
myelin wrote:so if either of you would like, I can post you a couple (a couple more, in Liam's case) PCBs.
That is a most generous offer Phil! I’d be very happy to have a couple more of these pcbs, now that I’ve figured out how to build the hub! :oops:
But, I don’t want to stand in the way of anyone else that may like one. So, if there are other takers, then I could happily wait on your revised version :)
myelin wrote:are the holes for the PCB-mount sockets big enough that you could use them to wire up panel mount sockets?
Yes, I think the holes are fine as they are for soldering in some hookup wire to DIN sockets.
Resizing the board to fit an existing case would be great, but a 3D printed case would give me an excuse to get a 3D printer.......
ask_nz
Post by ask_nz » Fri May 11, 2018 8:24 am
I would love one - if that's possible? Would you mind posting to NZ?
Ade
Ade
myelin
Post by myelin » Fri May 11, 2018 8:31 am
I’ll absolutely post to NZ :) PM me your address (Mark, can you do that too?) and I’ll drop one in the mail for you!
myelin
Post by myelin » Fri May 11, 2018 9:03 pm
I've just packed up two for Liam, two for Mark, and one for ask_nz (who still needs to send me an address). There are only two PCBs left now, so anyone else who wants one should get in quick :) (I'll do another board order in a bit, but if you want one now, PM me...)
lcww1
Post by lcww1 » Fri May 11, 2018 9:48 pm
Many thanks Phil :D
simoni
Post by simoni » Sat May 12, 2018 7:06 am
I'm assuming that the ATTiny is still running my Econet clock firmware? It's been really cool to watch this evolve from my "I need a Econet clock!" moment , all the way to an all-singing, all-dancing Econet solution. Nice work chaps :)
lcww1
Post by lcww1 » Sat May 12, 2018 7:36 am
Hi Simon,
Apologies, I should have made it clear in my first post that the Econet hub runs a modified version of your Econet clock 2 firmware - Phil modified your code to allow for the absence of the clock speed DIP switches, so the clock speed is fixed at the rate defined in the firmware - by default it’s set at 5us clock period, 1us mark
The modified code is on myelin’s github -
https://github.com/myelin/EconetClock2/ ... onetClock2
Your clock, and this hub, open up some really interesting possibilities for further Econet development and fun :D
myelin
Post by myelin » Sat May 12, 2018 7:38 am
simoni wrote:I'm assuming that the ATTiny is still running my Econet clock firmware? It's been really cool to watch this evolve from my "I need a Econet clock!" moment , all the way to an all-singing, all-dancing Econet solution. Nice work chaps :)
Yep! It's running your code, with a small modification (here's the diff) that fixes the clock to the 1us+4us (200kHz) setting, because I didn't think to put DIP switches on my board for speed selection :)
simoni
Post by simoni » Sat May 12, 2018 9:10 am
Very cool stuff :)
As a thought, you might want to put solder bridge pads on your next revision to set the speed. Just a couple of closely spaced SMD pads that you can drag solder across. It's a very cheap DIP switch :) There are two types in KiCAD, one open and the other has a small link which you can slice with a small knife (depends if you want the default to be on/off).
That way it's possible for the user to mod the board speed without a programmer (and you don't get to add an expensive DIP switch).
simoni
Post by simoni » Sat May 12, 2018 9:13 am
That wasn't what I was after - the code is open-source and you are welcome to use it in anyway you like (following the GPL of course) - I don't need a mention every time; I'm not *that* vain :D I was just curious!
marcusjambler
Post by marcusjambler » Thu May 24, 2018 1:04 pm
Hi
I'm interested in an econet hub if/when they are available.
Marcus
ask_nz
Post by ask_nz » Thu May 24, 2018 7:54 pm
myelin wrote:I've just packed up two for Liam, two for Mark, and one for ask_nz (who still needs to send me an address). There are only two PCBs left now, so anyone else who wants one should get in quick :) (I'll do another board order in a bit, but if you want one now, PM me...)
Many thanks Phil - mine arrived today :D :D :D
A.
Ade
markusher
Post by markusher » Wed Aug 22, 2018 11:49 am
Mine also arrived. Many thanks. It will be a few weeks before I am back in the UK with my econet setup.
-Mark
lcww1
Post by lcww1 » Sat Sep 29, 2018 9:48 am
I finally found some time to build up my remaining Econet Hub PCB, and fit it into an enclosure, along the same lines taken for the Econet socket box described on the retro-kit site here.
I decided to use a 2.1mm panel mount jack plug socket to power the Hub via a jack plug to usb cable. This Hub is now a very neat and portable Econet solution, combining into one the clock, socket box, and terminators. It’s been working flawlessly on my small single room Econet linking BBC B, BBC Master, A3000, A4000, A5000, and a RiscPC.
Cases Econet Hub
myelin
Post by myelin » Sun Sep 30, 2018 12:05 am
Nice work Liam!
myelin
Post by myelin » Sun Apr 28, 2019 1:52 pm
I was just looking through my uncommitted changes in my github repository and spotted this... I just pushed the latest changes, which fix the ATTINY85 footprint and move it slightly to give a bit more room.
https://github.com/google/myelin-acorn- ... econet_hub
If there's interest, I can also make the board a bit bigger to make room for mounting holes and maybe another couple of Econet sockets. Most of my time is going into Arcflash right now but I remember the plan for this board was to design a box to 3D print...
markrwj
Post by markrwj » Fri Jun 21, 2019 1:26 pm
Myelin,
I am getting close to trying to set up an econet between my 2 beebs, a master and an A3000 and would like to have a go at building one of these boards. Do you have any bare PCBs left or are you planning another run of boards based on the recent commits?
myelin
Post by myelin » Fri Jun 21, 2019 4:33 pm
I *thought* I had some more, but I must have sent them all off. If you're in a hurry, feel free to order a run of PCBs at JLC using the attached zip (which is the current build from GitHub, although I haven't pushed it yet because I don't typically do that until I actually place an order). If you're more than a month from needing boards, let me know, and I'll kick off an order myself and will have boards to post out in about three weeks :)
econet_hub_v2.zip
(105.51 KiB) Downloaded 10 times
markrwj
Post by markrwj » Sun Jun 23, 2019 7:28 am
Hi Myelin - I've never ordered PCBs before so that was a first. Got a decent discount as a first time order so I have 5 PCBs on the way to me in the Netherlands via DHL for EUR 11. Extremely reasonable! I'll let you know how I get on once I get it made. Thanks.
