Post by danielj » Wed Nov 27, 2019 7:17 pm
=D>
-B-
Post by -B- » Fri Nov 29, 2019 11:47 am
Have you tried the QL yet, with its famous overscan in monitor mode?
IanB
Post by IanB » Fri Nov 29, 2019 6:36 pm
Unfortunately I don't have a QL but it looks like it has a standard RGB TTL output so it should work, it's just a matter of creating a profile.
Does anyone here have a QL?
-B-
Post by -B- » Fri Nov 29, 2019 7:10 pm
I have a couple but I’m not in the UK.
I will be for Christmas though, so if you’d like me to lend you one....
Neil.
IanB
Post by IanB » Fri Nov 29, 2019 11:12 pm
That might be useful. I can probably create a profile with just some tech info although it would have to be connected to a real machine for the final tweaks.
Do you know what pixel clock frequency the QL uses? (It seems to be 10Mhz from online info)
Also how many clock cycles are there in a video line? (This should be around 640 but may vary 1 or 2 either way)
-B-
Post by -B- » Fri Nov 29, 2019 11:35 pm
This might help...
ZX8301.pdf
(376.68 KiB) Downloaded 19 times
Neil.
IanB
Post by IanB » Sat Nov 30, 2019 12:26 am
This might help...
ZX8301.pdf
Thanks, it was 10Mhz & 640 clock cycles so I created a new profile based on that, you can try it when the new software is released.
IanB
Post by IanB » Sat Dec 14, 2019 2:16 pm
Got my new issue 2 combined RGB and YUV boards back from JLC so I can now use it for analog RGB sources, 6847 YUV type sources and monochrome sources.
Here it is working with the Amstrad CPC:
And an Atom:
It even works with the beeb / electron:
(It isn't require of course as they will work on the raw TTL inputs but it does mean you can swap between supported machines without having to remove the analog interface)
Here's a closeup of the new board:
(It's connected via a test harness so I can do signal measurements)
There are still a few issues to sort out as the software really doesn't like noise in the sync input and that can happen when setting up the sync levels but once the profiles is setup it seems to work very smoothly.
-B-
Post by -B- » Sat Dec 14, 2019 2:34 pm
Excellent stuff!
IanB
Post by IanB » Sat Dec 28, 2019 3:36 pm
I've added support for a few more machines:
Camputers Lynx:
This one has a 3 bit TTL output like the beeb.
Colour Genie:
This one uses TTL connections picked up internally.
Tandy Micro Color Computer: (MC-10)
This one uses the new RGB/YUV interface with YUV signals picked up internally and that should also work with the Tandy color computers 1 & 2.
Interestingly this has quite different settings to the Dragon 32 as the PAL Tandy color computers use a slightly different clock frequency for the 6847.
The Dragon 32 also works with the RGB/YUV interface (previously mentioned in the Aom thread).
As it has a composite output I was able to do a side by side comparison with the RGBtoHD output: (composite on the left, RGBtoHD on the right)
Composite doesn't actually look that bad in the photo but here are a couple of closeups:
This is composite using a Retrotink 2X converter:
This is RGBtoHD using the RGB/YUV addon interface:
aotta
Post by aotta » Mon Jan 20, 2020 2:15 pm
excellent!
but when the new ttl version will be published? on github rgbtohdmi i found nothing about...
Post by hoglet » Mon Jan 20, 2020 2:18 pm
excellent!
All the work in the last 12 months has been happening in the dev branch:
https://github.com/hoglet67/RGBtoHDMI/tree/dev
aotta
Post by aotta » Mon Jan 20, 2020 2:44 pm
thank you hoglet, i missed the dev branch! i'll order a pcb asap!
