RGB to HDMI using a Pi Zero and a small CPLD
Re: RGB to HDMI using a Pi Zero and a small CPLD
Post by hoglet » Wed Jun 13, 2018 4:50 pm
tricky wrote:
Wed Jun 13, 2018 4:31 pm
Having the option is good and we might be able to sneak a feature or two in when Hoglet isn't looking.
One "feature" I was thinking about was a poor-mans Video NuLA, because the Pi's palette allows each of the eight colours to be redefined.
I've also got a simple OSD-Menu system working, so that does make it easier to access this kind of feature.
Now, if we can only get the GPU working as well!
Post by Elminster » Wed Jun 13, 2018 5:11 pm
john_A3000 wrote:
Wed Jun 13, 2018 4:00 pm
HDMI will never look as good as a CRT. These machines were not designed with HD in mind, so will look awful when stretched on a big HDTV.
Not used a CRT for 15 years myself. Don’t have luxury of space that others have. I think I meantioned above my beebs are generally not even connected to a monitor but go through series of converters, beamed across tcp/ip and appear on a Mac. So connected directly to a pi will be an improvement for me.
Budgie
Post by Budgie » Wed Jun 13, 2018 5:45 pm
I think its great just to have the option. Without this your into expensive bulky alternatives !
john_A3000
Post by john_A3000 » Wed Jun 13, 2018 6:12 pm
Expensive ? Hardly.
Most of my CRT TVs and monitors were less than £20 each.
Acorn BBC Model B, 32k, Turbo MMC, 9-Pin Joystick adapter.
Acorn BBC Master 128k, IDE + 2Gb CF Card, Multi-OS selector.
Acorn Archimedes A3000, 25Mhz Arm3 upgrade, 4Mb, IDE + 2Gb SDCard, PS/2 Mouse.
Acorn AKF30 RGB Monitor.
Post by Elminster » Fri Jun 15, 2018 10:02 am
To late to add optional scanline generator features I wonder. e.g.
https://www.arananet.net/pedidos/produc ... generator/
Post by BigEd » Fri Jun 15, 2018 10:34 am
Never too late with a software-based solution! Which is not to say that anything is possible, because there are timing constraints with updating the Pi's framebuffer.
Post by hoglet » Fri Jun 15, 2018 3:27 pm
Not all all....
All you need to do is comment out this line:
https://github.com/hoglet67/RGBtoHDMI/b ... _fb.S#L273
I'm sure we could make it a UI configurable option.
I'll add this to the TODO list, which is looking like:
- continue to tweak auto calibration code
- add "feature" OSD menu
- add palette changing to "feature" menu
- add scan line enabling to "feature" menu
- also make all the features (and the default samping points) configurable through the cmdline.txt file on the SD card
Also, I just had this email from Seeed:
My first professional PCB!
Post by Elminster » Fri Jun 15, 2018 4:25 pm
Great. Now about the feature to direct beam the video feed into my brain ......
Post by Elminster » Tue Jun 19, 2018 10:22 am
Added to hardware list, that means you have no choice but to make it work now. No pressure.
Post by hoglet » Thu Jun 21, 2018 1:06 pm
I've been doing a bit more work on the firmware this morning and now have the following implemented:
- add "feature" menu to the OSD
- add palette changing to feature menu (together with a selection of palettes, including a 3-bit monochrome scale)
- add scan line enabling to feature menu (mode 0..6 only)
- add mux control to feature menu (mainly used for older Elks)
- add debug control to feature menu
- make all the features (and the default sampling points) configurable through the cmdline.txt file on the SD card
I do hope the boards work when they come back...
Post by hoglet » Tue Jun 26, 2018 7:15 pm
The boards are now on their way. I'm expecting they will take ~8 days to get here.
Post by hoglet » Fri Jul 06, 2018 3:27 pm
Well, a bit more than 8 days, but the boards have arrived in the UK now.
It should take Royal Mail 2 working days to deliver them, so hopefully early next week.
Post by hoglet » Sat Jul 07, 2018 11:12 am
Or even today!
Lets get building......
:D :D :D :D :D
Post by hoglet » Sat Jul 07, 2018 12:06 pm
Getting there, just a cable to make up now....
[-o< [-o< [-o< [-o< [-o<
Post by hoglet » Sat Jul 07, 2018 1:13 pm
Cable made:
And lo and behold....
(this was on an Issue 4 Elk)
Post by tricky » Sat Jul 07, 2018 1:46 pm
That's great news. =D>
Has anyone volunteered to build them?
They don't look too difficult, but I recon I would get about 50/50 working :oops:
Post by hoglet » Sat Jul 07, 2018 1:55 pm
Not yet... The first board took me about 90 minutes (I'm slow at SMT stuff).
There's still a bit more work to do, on both the software and possibly the hardware:
- On the Elk the output is error free in all modes
- On the Master the output is error free in all modes
- On the certain Beebs I'm still seeing some sampling issues that the calibration doesn't eliminate, resulting in a small number of twittering pixels
This is the same level of fidelity that I saw with the prototype. I was hoping the shorter connections and better grounding would have sorted this, but it hasn't, which is a shame.
Anyway, it's a good opportunity to play with the new super-fast scope!
Post by Elminster » Sat Jul 07, 2018 2:34 pm
Happy to build one for myself, but doing SMDs for more than a couple of boards would take me forever.
Post by danielj » Sat Jul 07, 2018 2:51 pm
=D> Great work Dave - I'm happy to build a couple. Anything but beebscsis :D
Post by BigEd » Sat Jul 07, 2018 3:44 pm
Very neat indeed!
Post by hoglet » Sat Jul 07, 2018 5:17 pm
Thanks to the new scope I'm getting to the bottom of why on certain model Bs there is a problem with twittering pixels that can't be eliminated with the calibration.
One of the problem letters is the upper-case K:
There are two problem lines, marked above, where on some Beebs there is a twittering pixel.
And this scope shot shows why:
It seems there is insufficient time for the "off" pixel right in the corner of the K to properly reach the logic zero threshold. It's only going down as low as 1.2V. Both of my Model B's exhibit this problem to some extent. On the worst one, the pixel is actually always filled in. On the other one it twitters.
The root cause of this is the 6MHz clock being very asymmetric. The only answer I think here is to be able to shift the sampling threshold up to something like 2V. Which would mean lots more hardware (specifically a DAC and three very fast comparators). And even then there's precious little time to catch the pixel in it's off state.
dp11
Post by dp11 » Sat Jul 07, 2018 5:24 pm
You could move the sampling threshold voltage with two resistors. For a dac you can a pwm and and rc filter.
Post by hoglet » Sat Jul 07, 2018 5:57 pm
Interesting... How exactly?
dp11
Post by dp11 » Sat Jul 07, 2018 6:26 pm
Simply take the video input and feed it through a potential divider. E. G. Video input via R1 to Cpld input. At the junction of of R1 and the cpld connect R2. The other end of R2 could just go to ground but could goto a dac.
Post by tricky » Sat Jul 07, 2018 6:41 pm
I don't want to send you off down a rabbit hole, but, do you think this a design problem or maybe some tired beeb components?
If it is a simple short answer, why can't you just use some pull-up/downs - maybe some optional pots?
myelin
Post by myelin » Sun Jul 08, 2018 6:56 am
Nice work! Looking forward to building up a few of these so I can have more than one machine with a display at once :)
Post by hoglet » Sun Jul 08, 2018 11:39 am
I think I now have a fix for the Mode 7 video problems with the Model B.
For reference, here's the 6MHz clock circuit:
The filter formed by R119/C48 has quite a detrimental effect on the 6MHz clock, because rising edges experience far more delay through the filter than falling edges. So this changes the mark space ratio.
The fix is simply to remove C48 (e.g. by desoldering one side, or just snipping the lead).
According to the service manual, the purpose of R119/C48 is:
Glitches on this output are removed by R119 and C48 to produce the 6 MHz clock signal at Pin 8 of IC37.
I don't see any evidence of glitches after making this change.
Here's the before scope trace:
The top trace is the blue output in a Mode 7 screen showing a vertical column of "/" characters. The bottom trace is the 6MHz clock into the SAA5050.
Notice how the mark-space ratio of the 6MHz clock is very uneven, with the high pulses being shorter than the low pulses. As both edge of the clock are used, this results in very uneven pixel spacing.
Now with C48 removed.
You can see how the falling edge of the clock has been moved out, giving a much more even mark-space ratio.
If you look at the debug log from RGB to HDMI during calibration, you can see this makes a massive difference to the error counts:
Before:
INFO: Calibrating mode 7
INFO: offset = 0: metric = 25294
INFO: offset = 1: metric =   516
INFO: offset = 2: metric =  7059
INFO: offset = 3: metric =  3355
INFO: offset = 4: metric =  2187
INFO: offset = 5: metric = 51872
INFO: offset = 6: metric = 30841
INFO: offset = 7: metric = 22715
After:
INFO: offset = 0: metric =  2257
INFO: offset = 1: metric = 41182
INFO: offset = 2: metric = 30612
INFO: offset = 3: metric = 16186
INFO: offset = 4: metric = 24122
INFO: offset = 5: metric =     0
INFO: offset = 6: metric =     0
INFO: offset = 7: metric =     0
There are now three sample points that are error free, which is the same as I typically see on the Master.
The resulting image appears perfect.
Edit: I'm also finding (maybe not surprisingly) that removing C48 make a bit improvement to the image when using the SCART input of my LG LCD TV.
dp11
Post by dp11 » Sun Jul 08, 2018 11:46 am
If glitches do occur then a diode across R119 will speed up the rising edge. If the ls86 is socketed then replacing it with a 74hc86 could also work.
Post by tricky » Sun Jul 08, 2018 12:03 pm
Great news Hoglet, this was the sort of answer I was expecting/hoping from you :)
Off to see what difference it makes in my CRT.
Post by hoglet » Sun Jul 08, 2018 12:14 pm
IC38 (the LS86) is not typically socketted.
The first thing I did this morning was desolder it and fit a socket so I could try an HC version. The machine booted, but just gave a black screen in Mode 7. The 6MHz clock looked OK, but I guess there was just too much overall delay (the HC part being slower I think).
Interestingly, now I've removed C48, you no longer get a black screen with the HC variant.
