SpectROM - Speccy emulator for the Pi co-pro
Re: SpectROM - Speccy emulator for the Pi co-pro
Post by RobC » Sat May 19, 2018 4:06 pm
I've created a new version of SpectROM that fixes a few issues with the keyboard handling (thanks JGH!) and adds support for loading and saving .tap tape files. It also now works under MOS 3.50 on the Master (at least from my DC).
Enjoy!
spectrom.zip
Spectrum emulator
(63.72 KiB) Downloaded 53 times
marcusjambler
Post by marcusjambler » Wed May 23, 2018 6:41 pm
=D>
Confirming that it is running under 3.2 and 3.5 MOS from a folder on BeeSCSI mini ( RPIZero with EggEater rc0 ) .
Also, I used F1 and F3 to find and run SNA files in a sub folder. :D
I'll try TAP files at some point.
Marcus
Post by RobC » Wed May 23, 2018 7:50 pm
Thanks Marcus.
I think the MOS 3.50 issue was that I was using OSARGS to read the command line (from code taken from Sprow's ARMTDMI examples). I've now switched to using OS_GetEnv. I'll put the same fix into my other emulators at some point.
Post by jgharston » Wed May 23, 2018 8:06 pm
I investigated the command line issue on various ARM platforms and documented them on the WIki.
aotta
Post by aotta » Sun Nov 11, 2018 10:53 pm
i tried to launch zxspec, following instruction displayed with !boot on ssd spectrom, but i get "bad command" error with MOS 3.2 in my Master (@RobC: i take off for the moment one of my 2 videonula from other BBC... but i hope to get my 3rd vnula soon! ;) ).
*zxinit let screen a bit darker, and *zxscreen show some coloured pixel in the top of screen... my doubt is if my videonula is update for speccy emulator, or if i miss something else
Thank you for any help
Edit: solved! Error was invoke arm before loading sprom! 😜
Post by RobC » Mon Nov 12, 2018 10:17 am
Glad you got it working. I'm currently developing an Amstrad CPC emulator - most of it is working but I've got a stubborn scrolling bug to iron out and haven't added sound yet...
aotta
Post by aotta » Mon Nov 12, 2018 10:22 am
Good news! It's incredible what you can squeeze out from a bbc & vnula! Good luck for your debugging!
Post by tricky » Mon Nov 12, 2018 11:07 am
... I'm currently developing an Amstrad CPC emulator - most of it is working but I've got a stubborn scrolling bug to iron out and haven't added sound yet...
Are you thinking of using the 6845 for Amstrad 6845 stuff, or I guess more likely going with the speccy way for now.
You would also need the NULA scrolling/offset for Edge Grinder, but I guess that isn't your first targeted game :lol:
Post by RobC » Mon Nov 12, 2018 11:49 am
Thanks - I'm not sure how far I'll be able to take it but it's fun seeing the Beeb boot up as a CPC :D
I'm converting writes to the CPC's 6845 into writes to the Beeb's R12/R13. This is all working correctly (or seems to be!) but it looks like I've got an error in one of my screen plotting routines. Whole row plotting works fine with scrolling but plotting blocks of pixels sometimes shows corruption :x
I'm still only messing about with the CPC's BASIC so haven't thought about R3 tricks yet! However, it should be possible to replicate them with the NuLA's horizontal scrolling as you suggest...
Post by RobC » Tue Nov 13, 2018 10:11 pm
Finally found the scrolling bug and have now got it loading snapshot files.
It plays Bomb Jack really well :D
CPC Bomb Jack intro screen
CPC Bomb Jack Level 1
I also tried Pacland and it plays fine but it's doing a palette switch mid-frame which I've not implemented yet so there's an annoying colour flicker on the sky :(
VectorEyes
Post by VectorEyes » Tue Nov 13, 2018 10:30 pm
My God... If ever there was an excuse to get a Pi CoPro, I think this was it!
aotta
Post by aotta » Tue Nov 13, 2018 10:33 pm
..and to get a Videonula! =D>
marcusjambler
Post by marcusjambler » Tue Nov 13, 2018 10:45 pm
=D> =D> =D> =D> =D>
Rob this is another outstanding project... wow
aotta
Post by aotta » Wed Nov 14, 2018 4:10 pm
Rob, can you confirm the emu you are working on doesn't need update to vnula's board, since cpc colors are the same vnula already supports?
We are all waiting for your release... :D
Post by RobC » Wed Nov 14, 2018 4:29 pm
Yes - no update required as VideoNuLA already supports the CPC's colours as you suggested.
Just to set expectations, there's still quite a lot of work to do on this and I'm a bit short of time at the moment as my mother has been quite seriously ill and so I'm currently doing a lot of visiting etc. I've also been working on something else NuLA-related so am dividing my time between the two projects.
aotta
Post by aotta » Thu Nov 15, 2018 6:14 am
Best wishes to your mother, and happy you are getting something new about vnula from your magic hat!
Post by RobC » Thu Nov 15, 2018 9:15 am
Many thanks. She had a heart attack last week but is now home and hopefully over the worst.
vanpeebles
Post by vanpeebles » Thu Nov 15, 2018 10:50 am
Heartfelt best wishes to you!
Post by tricky » Thu Nov 15, 2018 11:59 am
Best wishes rob, my dad had one 20 years ago and had to be jump started, he has had two since, one with 45minutes CPR at the roadside from a nurse on her way home; that needed a jump too. He now has a pacemaker with built in defib' but fortunately hasn't needed the extra functionality.
I eagerly await your new announcement.
Post by RobC » Thu Nov 15, 2018 1:39 pm
Thanks so much guys - I really appreciate it.
I managed to sort out the rest of the CRTC registers (apart from R3) this morning so it can now handle non-standard screen sizes. I hadn't realised that the CPC's CRTC uses horizontal units that are double those of the Beeb's :oops:
Anyway, it'll now play Rainbow Islands and Commando:
Rainbow Islands on a Beeb!
Commando
trixster
Post by trixster » Thu Nov 15, 2018 2:54 pm
This is bonkers! :o
VectorEyes
Post by VectorEyes » Thu Nov 15, 2018 3:31 pm
Totally agree that this is amazing! I find myself wondering what the limits are. Can it can handle the more extreme abuses of the CPC hardware, e.g. recent demos such as still rising (https://youtu.be/dDVAzMjA7bM) or phX (https://youtu.be/6wBwbRYL-F4)
[And by the way, I know it's unrealistic (possibly: literally impossible) to expect them to work. Just curious how far you can push a system like this before it hits fundamental limits! But that's for later. Hope your Mum continues to get better!]
trixster
Post by trixster » Thu Nov 15, 2018 4:40 pm
Good question. That CPC Batman demo is incredible, as is the Pinball Dreams work in progress; if either of those work on this WITCHCRAFT then I’ll eat my beanie! It’s an incredible accomplishment already without further wizardry!
Post by RobC » Thu Nov 15, 2018 5:26 pm
Those demos are amazing but anything that uses interrupts to do clever tricks won't work at the moment. Pacland doesn't work properly yet because it seems to be doing a palette switch mid-frame and I think Paperboy is doing a mode change mid-frame which is messing up the display.
I'm hoping I can sort out some of this by generating a 300Hz interrupt on the Beeb - I did something similar on the Spectrum emulator to ensure border colour changes happened at roughly the right time. However, anything that uses very precise timing is very unlikely to work properly.
My aims in doing these emulators are two-fold: a) to learn more about other 8-bit machines & b) to play games that didn't get released on the Beeb but I don't really have the skills to write something that pushes the concept to its limit...
Post by RobC » Fri Nov 16, 2018 6:14 pm
Not much progress today as I've been trying to track down an annoying bug which caused the screen mode to change at random. Finally tracked it down to the Beeb's OS coming in and setting the ULA thinking it needed to update the flashing colours. Thought I'd stopped this by using my own vsync interrupt routine but evidently not :(
Anyway, I did manage to get Ghosts 'n' Goblins running:
Zombie slaying on the Beeb!
I played this loads in the arcades but was always terrible at it!
Post by tricky » Fri Nov 16, 2018 9:37 pm
I thought that flashing was on the 100hZ interrupt , but now I'm not sure :lol:
Post by RobC » Fri Nov 16, 2018 10:09 pm
Looking at the OS 1.2 disassembly at &DD15 onwards, it seems that it's done when looking for the vsync (CA1) interrupt.
However, I guess this explains why I was seeing this sort of very occasional behaviour. I'd enabled the ADC and T1 interrupts (for joystick and keyboard) and was letting the OS deal with them. If vsync went off just as the OS was going through this code, it would deal with it before reaching my vsync code.
I'll probably move to handling all of the interrupts in my code so that the OS doesn't get a look in.
dominicbeesley
Post by dominicbeesley » Fri Nov 16, 2018 10:26 pm
Hi Rob,
I've had this problem myself, it doesn't matter which vector you hang off i.e. IRQ1V is called before the mos routines there's always the chance that the relevant bit in the interrupt flags register could get set between your routine and the mos one and then the mos code would handle it.
However, in this case I think you just want the mos to not do the flash handling, in which case setting the flash period to 0 should do the trick?
D
Post by RobC » Fri Nov 16, 2018 10:31 pm
Yes - that what I did by setting the flash counter at &251 to zero. However, I'd like to make sure I catch every vsync so I'll look at doing everything in my code and shutting out the MOS.
