SpectROM - Speccy emulator for the Pi co-pro
Re: SpectROM - Speccy emulator for the Pi co-pro
Post by RobC » Sat May 19, 2018 3:06 pm
I've created a new version of SpectROM that fixes a few issues with the keyboard handling (thanks JGH!) and adds support for loading and saving .tap tape files. It also now works under MOS 3.50 on the Master (at least from my DC).
Enjoy!
spectrom.zip
Spectrum emulator
(63.72 KiB) Downloaded 25 times
marcusjambler
Post by marcusjambler » Wed May 23, 2018 5:41 pm
=D>
Confirming that it is running under 3.2 and 3.5 MOS from a folder on BeeSCSI mini ( RPIZero with EggEater rc0 ) .
Also, I used F1 and F3 to find and run SNA files in a sub folder. :D
I'll try TAP files at some point.
Marcus
Post by RobC » Wed May 23, 2018 6:50 pm
Thanks Marcus.
I think the MOS 3.50 issue was that I was using OSARGS to read the command line (from code taken from Sprow's ARMTDMI examples). I've now switched to using OS_GetEnv. I'll put the same fix into my other emulators at some point.
Post by jgharston » Wed May 23, 2018 7:06 pm
I investigated the command line issue on various ARM platforms and documented them on the WIki.
