Beeb FPGA port to Spectrum Next
Post by hoglet » Fri Dec 08, 2017 8:19 am
Hi all.
Continuing on from here...
Attached is the current UCF file:
specnext_ucf.txt
(13.53 KiB) Downloaded 36 times
Is there any documentation on how multiple cores co-exist on the Spectrum Next?
Does Spectrum Next make use of Xilinx multi-boot (i.e. multiple cores in the same flash ROM)?
Is there any kind of an audio DAC present, or it is just a 1 bit digital output and an R/C low pass filter?
Is there a serial port?
Will the 7x2 pads near the FPGA take a standard JTAG Connector?
fordp
Re: Beeb FPGA port to Spectrum Next
Post by fordp » Fri Dec 08, 2017 9:43 am
I am hoping this is going to be my favourite thread ever. My first computer was a Spectrum, my second a BBC B, my next toy after that a 32016 Second Processor.
The Spectrum Next should be able to do all of that ;)
Are you a backer Dave (hoglet) ?
FordP (Simon Ellwood)
fordp
Post by fordp » Fri Dec 08, 2017 9:47 am
From what I read they seem to have some system for loading cores from the MicroSD card.
I have no idea how that could work however :(
Post by BigEd » Fri Dec 08, 2017 10:05 am
Yes, I did wonder if it was worth downloading one of their card images and having a look at the magic file.
northernbob
Post by northernbob » Fri Dec 08, 2017 10:54 am
not much info on the official forum.
https://www.specnext.com/forum/viewforum.php?f=10
tbh this has been a low priority for the dev team, as they conc on tbblue core.
thre was info on the fbk page, but its like a churning sea that grp! info comes into view then sinks to the depths....
Post by hoglet » Fri Dec 08, 2017 11:50 am
northernbob wrote:not much info on the official forum.
Could you possibly take some high res photos of the board (both sides)?
And a close up of the FPGA, so I can see what speed grade and package it is?
Post by hoglet » Fri Dec 08, 2017 4:06 pm
Here's a first cut of the Spec Next port:
https://github.com/hoglet67/BeebFpga/bl ... c_next.vhd
And the corresponding Xilinx Project file:
https://github.com/hoglet67/BeebFpga/bl ... _next.xise
It's functionally complete and builds, but there are quite a few things I'm a bit uncertain about, so I expect some debugging will be required.
At the moment it's hardwired to VGA mode, and there is no composite or HDMI output.
It includes the following features:
- Master 128 mode and Model B mode (including ROM images for both)
- the ICE T65 debugger (with AVR supervisor core), wired to the Tx and Rx pins on the esp8266 connector
- the 65C02 Co Processor
- Beeb SID
- Music 5000
This uses about 60% of the LUTs, so things are not particularly tight yet.
There don't seem to be any DIP switches or LEDs, so that makes mode selection a bit tricky. At the moment, holding down the M1 button for 1 second will toggle between Master and Model B modes.
It should be possible to route all the tube signals to the Pi connector, and then make use of Pi Tube Direct on a Pi Zero. I've not made these connections yet, as I don't have the pin assignments for the Pi connector.
Post by BigEd » Fri Dec 08, 2017 4:43 pm
hoglet wrote:It includes the following features:
- Beeb SID
- Music 5000
Bravo! Plenty of room in an LX16 then!
Post by hoglet » Fri Dec 08, 2017 5:27 pm
Some information that we need to complete this....
- How are accel_io(27 downto 0) wired to the 40-pin connector? (Knowing this will let us add support Pi Tube Direct)
- Is csync_o connected to the VGA connector? Or to somewhere else? It seems the RGB usage of the VGA connector is not well documented: https://www.specnext.com/forum/viewtopic.php?f=6&t=820
- What are i2c_scl_io and i2c_sda_io connected to? The DS1307 RTC chip (not fitted)?
- What does audioint_o do?
- Why is mic_port_o an output and ear_port_i an input. This seems the wrong way around.
- What does joysel_o do? I'm guessing it controls a multiplexer to select between the two joystick ports.
- What does joyp7_o do?
- Which chip select should be used for the main SD Card? sd_cs_n_o or sd_cs2_n_o?
- How are the ram_cs_o routed to the RAM chips? i.e. which chip select should is used for the RAM that drives ram_data_io (7 downto 0).
- Are there really no LED driven from the FPGA?
- What's the part number of the 8-pin Winbond? FLASH?
Post by hoglet » Fri Dec 08, 2017 5:57 pm
BigEd wrote:Yes, I did wonder if it was worth downloading one of their card images and having a look at the magic file.
I've just had a poke around the SD card image:
https://www.specnext.com/next-sd-card-v0-1/
There is nothing in there that's large enough to be an LX16 bitstream (464,318 bytes).
What's interesting is this screen shot:
does show a file (TBBLUE.TBU) thats the right sort of size, but that's not included in the ZIP.
Here's a short description of the boot process:
https://www.specnext.com/boot-system/
And of the update process, that mentions TBBLUE.TBU:
https://www.specnext.com/updater-module/
Post by BigEd » Fri Dec 08, 2017 6:07 pm
I reckon it's the 96k-sized *.FW file - the firmware - which does the job of reading the *.TBU bitstream file and updating the EEPROM. But is this a Z80 application, or something else?
northernbob
Post by northernbob » Fri Dec 08, 2017 7:12 pm
hoglet wrote:Some information that we need to complete this....
asked the questions.....got this so far....
"Dean Woodyatt Cross reference the FPGA pin tags with TKPIE?"
Post by BigEd » Fri Dec 08, 2017 7:28 pm
Post by BigEd » Fri Dec 08, 2017 7:33 pm
BigEd wrote:I see a number of resistors and resistor networks near the edge connector - I'm interested to find out how 5V-compatible it is.
It seems there are those who have doubts as to how safe the resistor network approach is, while the Spectrum Next people believe they've done adequate testing:
https://www.specnext.com/forum/viewtopi ... 5702#p5702
Post by hoglet » Fri Dec 08, 2017 7:37 pm
BigEd wrote:(That would be https://gitlab.com/victor.trucco/TK-Pie I guess?)
I'd already looked at that, and the schematic uses GPIO numbering directly, rather than accel_io.
I guess we could always beep out a board. But this does all seem rather painful for a board originally marketed as "open source". Is it really that hard to post a PDF of the schematic? Does anyone understand what the issue actually is here with releasing information?
Post by BigEd » Fri Dec 08, 2017 7:42 pm
I'd certainly be happy to see a fully open source release - especially as I'm a backer, and it was described as such.
northernbob
Post by northernbob » Fri Dec 08, 2017 10:13 pm
ok obtained some pics for ya. tbh wasnt quite sure what you wanted.
got 14, but herre are the best ones, hope they of some use.
Post by BigEd » Fri Dec 08, 2017 10:19 pm
(Thanks for the photos northernbob! I'm tempted to say that I see relatively few capacitors by the FPGA and the SRAMs - let's see what more experienced eyes see.)
Post by hoglet » Fri Dec 08, 2017 10:21 pm
Great, thanks, just what I needed to confirm a few things (like the FPGA speed and package)
Can you read the markings on U13?
northernbob
Post by northernbob » Sat Dec 09, 2017 9:18 am
few more questions answered...
- Is csync_o connected to the VGA connector? Or to somewhere else? It seems the RGB usage of the VGA connector is not well documented: viewtopic.php?f=6&t=820
Most probably, some unused pin on the VGA connector, but the pinout has not been disclosed yet.
Northernbob wrote: ↑Fri Dec 08, 2017 6:56 pm
Yes, that is the I2C bus.
It's the connection to the internal (not fitted) speaker.
No, it's actually right. MIC is an output on the original Spectrum and EAR, an input. On 48K models, both functions share the same pin, but on later 128K models, there were two different pins from the ULA.
My guess is that it should be sd_cs_n_o
Post by hoglet » Sat Dec 09, 2017 9:27 am
Thanks for that info, I'll update the design accordingly (mostly just a matter of changing the comments).
northernbob
Post by northernbob » Sat Dec 09, 2017 10:04 am
u13...
winbond
25Q128JVSQ
1720
northernbob
Post by northernbob » Sat Dec 09, 2017 10:45 am
there could be movement from t he top....just spotted this on the next grp...
Henrique OlifiersGroup admin https://www.specnext.com/next-accelerator-files-v0-1/
Next Accelerator files v0.1 – ZX SPECTRUM NEXT
Next Accelerator files v0.1 December 9, 2017 Carlos…
SPECNEXT.COM
Like · Reply · 2 · 7 hrs
HO: `Actually, this is no longer working, it has been a while since we last updated it. It shows an image, border works, but not functional. Use the github source code as a reference until we have the time to update this and make it functional again. I've unpublished the article`. https://gitlab.com/victor.trucco/TK-Pie/
so i have no idea what they are about to come out with!
dp11
Post by dp11 » Sat Dec 09, 2017 11:47 am
A quick look at the pictures doesn't give me much confidence of a reliable system, especially if in the future the FPGA contents is changed and pushed to the limits. The spartan6 LX16 FT256 documentation recommends 24 capacitors. Now this is over the top , but I think 4 caps is going a bit too far. What I assume are LDOs for the 1.2v rail and 3.3v rail look as though they might get a bit warm if the FPGA is run hard.
I'd love to see a fully loaded up board pass emc testing as is should to get a CE mark and be sold in europe.
Post by hoglet » Mon Dec 11, 2017 1:55 pm
I've been looking at the code here:
https://gitlab.com/victor.trucco/TK-Pie ... /video01.c
I think there's a good chance accel_io[27:0] connect directly to gpio[27:0] on the 40-pin Pi Header.
(You would have to be a crazy hardware designer not to connect them directly!)
What threw me initially was the pin table I usually refer to:
http://www.coocox.org/wiki/images/markd ... pi_pin.png
This doesn't include GPIO0 and GPIO1, but reading around a bit it seems these connect to pins 27 and 28 (and are reserved for connecting to a serial EEPROM on each hat).
fordp
Post by fordp » Mon Dec 11, 2017 2:41 pm
That diagram does include 0 and 1 for earlier pi's they had to do some swapping about for later pi's and I think it was i2c ports that got swapped.
Post by hoglet » Mon Dec 11, 2017 3:50 pm
With a view to making good use of the Spec Next accelerator port, I've just had a go at adding an external tube connection to Beeb FPGA:
https://github.com/hoglet67/BeebFpga/co ... 0bcc1d?w=1
This was mostly a case of just plumbing the right signals out of the core.
As a proof of concept, here's a Pi Zero wired up directly to the DE1. Everything is 3.3V, so no level shifters required.
Shame the 40 pin connectors are not directly compatible, due to the fixed placement of power pins...
And it worked first time!
Post by hoglet » Mon Dec 11, 2017 5:09 pm
I've now added support for Pi Tube Direct as an external coprocessor / accelerator in the Spec Next build:
https://github.com/hoglet67/BeebFpga/co ... 8c04596247
This is assuming accel_io(27:0) map directly to gpio(27:0)...
I've also added a pull down on D0, so the Model B boot doesn't hang if the Pi is missing.
All completely untested, as is everything else at the moment.
northernbob
Post by northernbob » Mon Dec 11, 2017 8:37 pm
afraid am gonna be slacking a bit, this week. its crazy party season going on here! am booked up for the next 7 days (well 6+1 star wars film)
` an external tube connection`
am a bit confused with your wording there. thats an actual circuit in the fpga?
btw, with regard to cores....is there a master core made up? how much larger would that be?
does the model b core inc any vram ? i believe tbblue has 128k of vram in the core.
surely the model b isnt vastly bigger than the z80 core, there must be some free fpga space to add, little extras?
AM rusty on bbc architecture in the 1988-1995 era. I played with a acorn pc in 1995, owned by one my computer lecturers at uni.
Which version of risc os, would that have run? v3?
which is the smallest risc cpu that can run risc os? I mean i guess the cpu from ` The A3010 model ` is too large for the fpga in the next?
btw am just thinking out loud/forward here!
Is the ARM250 an open core? is there something like this that would fit on the next.
WOuldnt a risc based cpu, be easier to accelerate, than a z80. I suspect am asking the wrong question there )
basically, which is the most advanced risc cpu, that fits on the next fpga, that can be accelerated to the `highest level` ? using the copro lever/crowbar!
dp11
Post by dp11 » Mon Dec 11, 2017 9:13 pm
A Pi zero will beat any FPGA core.
