Unix on the Beeb
Re: Unix on the Beeb
Post by hoglet » Fri Nov 10, 2017 3:25 pm
RobC wrote:I've been looking at building the PDP11 emulator for the native Pi copro and have now figured out how to build C executables for it and have the stubs library connected up.
Unfortunately, the emulator needs more than the current limit of 2MB as it is complaining that it can't allocate enough memory for its buffers. (I had similar issues on the Matchbox ARM2 core).
How are you determining the current amount of available memory? OS_GetEnv?
It should be pretty easy to make 16MB available, just by changing this line and recompiling:
https://github.com/hoglet67/PiTubeDirec ... ive.c#L195
Would 16MB be enough?
Post by RobC » Fri Nov 10, 2017 4:54 pm
Thanks - 16MB should be more than enough as it runs on the 4MB ARM 2 core.
I'll have a look at recompiling it with 16MB.
EDIT: Thanks to Dave's suggestion, I now have the Pi CoPro reporting 16MB from BAS135. Still can't get the PDP-11 emulator working though as it's now hanging when trying to boot the disk image. I'll try to do some debugging later today rugby watching permitting!
Post by RobC » Wed Nov 15, 2017 4:20 pm
I've now got this working on the native Pi co-pro. It needs the changes implemented in the Diamondback dev release but seems to be running happily on my 1GHz Pi Zero.
As expected, it's much faster than the ARMTDMI and certainly feels comparable to my recollections of using Unix on a mainframe in the early 90s.
I'll do some more testing over the next few days and will post up the binary. I'll also bring it along to ABUG if anyone wants a play...
fordp
Post by fordp » Wed Nov 15, 2017 5:39 pm
RobC wrote:I've now got this working on the native Pi co-pro. It needs the changes implemented in the Diamondback dev release but seems to be running happily on my 1GHz Pi Zero.
Cool!
FordP (Simon Ellwood)
Post by Coeus » Wed Nov 15, 2017 7:04 pm
So, if I understand correctly we have a PDP emulator running on a real ARM in the form of Pi Tube Direct. In all of that do we have a portable (e.g C) PDP emulator or is it in ARM assembler?
Post by jgharston » Wed Nov 15, 2017 7:16 pm
Coeus wrote:So, if I understand correctly we have a PDP emulator running on a real ARM in the form of Pi Tube Direct. In all of that do we have a portable (e.g C) PDP emulator or is it in ARM assembler?
There's a portable PDP Emulator here, written in BBC BASIC. :)
Currently, single memory space, no MMU, but all Unix TRAPs are implemented.
Post by RobC » Wed Nov 15, 2017 7:56 pm
Yes.
Coeus wrote:In all of that do we have a portable (e.g C) PDP emulator or is it in ARM assembler?
It's based on the Sanos PDP11 SimH emulator which is in C:
http://www.jbox.dk/sanos/pdp11.htm
It only needed a few minor changes to get it to work on the Arc, RiscPC and matchbox ARM 2 copro using the Norcroft compiler. I had to add some ARM assembler (for startup and newlib stubs) to get it to work under gcc for the ARMTDMI and native Pi copros.
