Cheap SD/MMC Readers
Post by danielj » Mon Oct 23, 2017 8:26 am
This is a placeholder post for the latest versions of SmartSPI and MMFS. These are bugfixed and more up-to date file system ROMs that work with Martin Mather's MMC reader design, the TurboMMC hardware, and the cheap SD Card Readers available on ebay.
Latest version of SmartSPI: viewtopic.php?f=2&t=9208&start=150#p129221
Latest version of MMFS: https://github.com/hoglet67/MMFS/releases
With MMFS, you need to use the correct ROM version - see: https://github.com/hoglet67/MMFS/wiki/Release-structure
Wiring for SD reader to userport: viewtopic.php?t=1919&start=330#p99449
sirmorris
Re: Cheap SD/MMC Readers
Post by sirmorris » Mon Oct 23, 2017 8:47 am
If you don't want to solder or otherwise build your own adapter then a compatible inexpensive reader is offered for sale in the trading topic, other inexpensive compatible readers are available ;)
(Feel free to delete this post if inappropriate)
Post by danielj » Mon Oct 23, 2017 8:55 am
No, that's fine :D
Post by lurkio » Mon Oct 23, 2017 9:40 am
danielj wrote:Latest version of SmartSPI: viewtopic.php?f=2&t=9208&start=150#p129221
If it helps, here's the current latest version (1613) of the SmartSPI ROM-image as a raw data file (inside a zip file) -- and not on a .SSD disc-image:
(Scroll down to attachments to first post.)
Post by steve3000 » Sat May 12, 2018 5:11 pm
I'm setting up a mmc interface for a friend's beeb and thought I'd download a fresh copy of the "beeb.mmb" file pre-filled with games discs, but I'm really struggling to find where I can download this from...
I've tried searching the forum and google without success, the download link which I'm sure I used in the past on this thread appears to be dead, and the beeb.mmb file mentioned here doesn't seem to have a download link at all. Am I missing something obvious?
Post by lurkio » Sat May 12, 2018 5:18 pm
steve3000 wrote:I've tried searching the forum and google without success, the download link which I'm sure I used in the past on this thread appears to be dead, and the beeb.mmb file mentioned here doesn't seem to have a download link at all. Am I missing something obvious?
No, it is quite tricky trying to wade through the forums to track down a copy of BEEB.MMB. For now, try this one:
Post by hoglet » Sat May 12, 2018 5:30 pm
Post by steve3000 » Sat May 12, 2018 5:56 pm
Ahh, brilliant, I'm not going mad then :)
Thanks both for those links!
Post by CMcDougall » Sat May 12, 2018 6:10 pm
steve3000 wrote: tried searching the forum and google without success, the download link which I'm sure I used in the past on this thread appears to be dead
it's not dead :roll:
if you look after the first few edits, then my text, then a further 4 edits below this, the first one is from member 'duikkie'
which still works (222+ other folk must know!! :lol: ), as on the forum, not an old upload site #-o
duikkie
Post by duikkie » Sun May 13, 2018 6:38 am
i uploaded my beeb.mmb a few times by now.
it has not change that much in time because
i don't play games.
and i think most not running games are fixed
for the beeb !!
SmellyGeekBoy
Post by SmellyGeekBoy » Mon Nov 19, 2018 12:20 pm
It didn't seem worth starting a new thread for this so I thought I'd try tacking it on here - I don't suppose anyone could burn the latest MMFS ROM for me? I have a very basic user port MMC interface that I'm using with my Model B but the ROM is 3 years old now and it seems there's been a lot of active development in this area. Unfortunately I don't have an EEPROM programmer or I'd do it myself!
Thanks!
Hey, hey, 16K, what does that get you today?
