RobC wrote:Elminster wrote:Any on ehazard a guess how much that would have added to the costs dpings it 80s style in the 80s?
As a point of reference, the Palettemate was advertised for £99 in October 1986. Assuming it replaced the original ULA, you'd recoup some of the cost.
Had Acorn decided to do it, it would have needed a slightly larger PCB and a bigger ULA - the original ULA implementation is about 1/3 the size of the full VideoNuLA. Or they could have just put out the flash bit and used an off the shelf RAMDAC. Anyone know what a 16 x 12-bit RAMDAC cost?
It depends when it was brought out, prior to VGA I suspect real RAMDACs were too expensive.
I was thinking about this a while back, before I decided to cheat and use a VGA RAMDAC, three 74XX189's (around £3 a pop in 1985, or 82S25 at around £2) and a couple of 8 bit latches would probably do the trick but only just, timing wise. Palette writes would have to occur during DISEN=0. I suspect the palette RAM itself takes up a lot (most?) of the ULA space, whether your other funky (attributes, smooth scroll) effects would all fit is another matter...
This would have added a fair chunk to the cost of course! Also, analogue composite/UHF generation circuitry would need to have been added though I suspect that the beeb's chroma circuit could be much simplified...
D
