danielj wrote:Do we have the "Mega" file disk?
Yes! At least, I think so. I just used the Utils menu and chose to generate the "example files" onto a blank .SSD in Drive 1 in BeebEm:
I believe the generated files need the ROM to load and run them. But perhaps you can also use the instructions that Phil uploaded earlier to generate standalone runnable games from them..?
EDIT: By using the "Create a game file" utils menu option and entering the details for the adventure named TINY on the "MEGA" games disc attached to this post, above, and after fiddling about a bit, I was able to generate a standalone game. See the attached disc image:
- TINY.ssd.zip
- TINY standalone adventure game program
- (6.04 KiB) Downloaded 44 times
Though the utils disc was originally meant to be used with an Electron with ADFS, I was doing all this on DFS in Model B mode (or B Plus mode, I forget which) in BeebEm, which may be why there were some oddities on the TINY disc I generated: the loader program TINYG appeared twice -- the two files were on different sectors of the disc, but both had the same filename! I renamed one of them to TINYG2 by manually editing the disc catalogue. Also, the loader program TINYG is corrupted at the end, though it still seems to work.
