Bit Shifting in BASIC?
JohnH
Post by JohnH » Wed Aug 24, 2016 9:41 pm
Hiya,
is there an easy way to rotate the lower nibble of a byte left and right?
I don't want to shift bit 4 to bit 5, I want it to wrap round to bit 1 and vice versa for shifting right.
A simple divide by 2 works for a right shift but you lose bit 1 I think. Maybe if you read bit 1 first (with byte AND 1?) and then right shift and somehow set bit 4 if bit 1 was set before the shift?
Same for left shift, a *2 seems to work but how to move bit 5 to bit 1 position after the shift? Some kind of AND to check if it's set before the shift and then another operation to set bit 1 after the shift if needed.
Am I on the right lines? I was thinking I might end up doing it in assembler but if I can just do it in BASIC it would simplify it a lot.
MartinB
Re: Bit Shifting in BASIC?
Post by MartinB » Wed Aug 24, 2016 10:17 pm
I win! :D
Byte to play with is N% in line 10
   10 N%=&B9
   20 NB%=N% AND &F
   30 B3%=(NB% AND 1)*8
   40 B0%=NB%/8
   50 RL%=((NB% AND 7)*2)OR B0%
   60 RR%=(NB%/2)OR B3%
   70 NRR%=(N% AND &F0)OR RR%
   80 NRL%=(N% AND &F0)OR RL%
   90 PRINT"RIGHT ";~NRR%
  100 PRINT"LEFT  ";~NRL%
jms2
Post by jms2 » Wed Aug 24, 2016 10:21 pm
MartinB beat me to it, but as I've typed this anyway, I'll post it. :lol: My way is different actually, how about this for a right shift:
DEF FNright(byte%)
=(byte% DIV 2) + (byte% MOD 2)*8
I have not tested this, just dreamed it up so it may be wrong! However I hope it will give you some ideas.
Left shifting is more difficult. ..
DEF FNleft(byte%)
=(byte%*2) AND &0F + ((byte% AND &08) DIV 8)
Please try them out and let me know if they work! :D
Post by lurkio » Wed Aug 24, 2016 10:56 pm
Just to add to the melee...
DEF FNror(b%)
LOCAL n%
n%=b% AND &F
=(b% AND &F0)+(n% DIV 2)+8*(n% MOD 2)
DEF FNrol(b%)
LOCAL n%
n%=b% AND &F
=(b% AND &F0)+2*(n% AND 7)+((n% AND 8) DIV 8)
EDIT: If you want to throw away the higher four bits of the byte b%, then delete the string "(b% AND &F0)+" from both functions.
MartinB
Post by MartinB » Wed Aug 24, 2016 11:01 pm
Fact of life guys - nobody ever remembers who came second... \:D/ :lol:
(...even if yours do make mine look like it was written by a five year old :wink: )
Post by jgharston » Wed Aug 24, 2016 11:58 pm
JohnH wrote:is there an easy way to rotate the lower nibble of a byte left and right?
Presuming you mean bit 0, etc... what I use is, assuming A% is already 0-255:
LSR A% - A%=A% DIV 2
ASL A% - (A%=A%*2) AND 255
ROR A% - A%=(A% DIV 2) OR 128*(A% AND 1)
ROL A% - A%=((A%*2) OR (A% DIV 128)) AND 255
So, reducing these to manipulate A% as a 4-bit number, assuming A% is already a 4-bit number:
ASL A% - (A%=A%*2) AND 15
ROR A% - A%=(A% DIV 2) OR 8*(A% AND 1)
ROL A% - A%=((A%*2) OR (A% DIV 8 )) AND 15
You can expand these up to any data size, but it gets fiddly with 32-bit numbers as the arithmetic treats bit 31 as a sign bit:
LSR A% - A%=(((A%+(A%<0))DIV2)AND&7FFFFFFF) :REM The same as A%=A% >>> 1 in BASIC V.
ASL A% - A%=(A% AND &3FFFFFFF)*2 OR (&80000000 AND (A% AND &40000000)<>0) :REM A%=A% << 1 in BASIC V
ROR A% - A%=(((A%+(A%<0))DIV2)AND&7FFFFFFF) OR (&80000000 AND (A% AND 1)<>0)
ROL A% - A%=(A% AND &3FFFFFFF)*2 OR (&80000000 AND (A% AND &40000000)<>0) OR ((A%<0)AND1)
(I'm not at home atm, so I've retyped these from memory from first principles)
JohnH
Post by JohnH » Thu Aug 25, 2016 6:32 am
Woah! a plethora of replies, that's awesome guys.
I'll give some of those a tryout and play around with tonight after work.
Good to know from looking at them quickly that I was heading in the right direction. :D
