MMFS Development and Support
Re: MMFS Development and Support
Post by hoglet » Thu May 19, 2016 12:09 pm
Hi Duikkie,
duikkie wrote:I think all together that a usb option is less electronics. The only thing is the usb exp. Board is not there yet.
As there are a lot of new people around (Andy is one of them), it might help to give some links to your USB project.
duikkie
Post by duikkie » Thu May 19, 2016 5:59 pm
I am so terrible in links and search maybe ch375b will give links to my projects?
hoglet wrote:Hi Duikkie,
Post by CMcDougall » Thu May 19, 2016 7:06 pm
duikkie wrote:I am so terrible in links and search maybe ch375b will give links to my projects?
viewtopic.php?f=3&t=11024#p136606 :wink:
Post by MartinB » Fri May 20, 2016 9:28 am
Dave wrote:...a 6522 interface, such as Martin Barr's EUP (Electron User Port)
I've been giving this some thought so I'll post a response on the EUP thread...
Budgie
Post by Budgie » Fri May 20, 2016 4:50 pm
So it looks like a time thing between perhaps waiting for an AP5 and whether Martin will be producing any PCB's for the EUP.
I've just bought an AP6 and ATI from Dave H which are working well. Just looking for a method to load stuff up. Happy to create a solution though if the EUP boards are now for sale.
Andy
Post by MartinB » Fri May 20, 2016 6:16 pm
I haven't managed to get home yet :roll: to explore the options such as Charlie's suggestion but I think yes, one way or another we will procure some more EUP pcb's....
Budgie
Post by Budgie » Fri May 20, 2016 6:25 pm
That's great Martin. I've added my interest to the EUP thread.
Andy
Budgie
Post by Budgie » Fri May 20, 2016 6:43 pm
Dave H & Duikkie
Thanks for posting your suggestions. Most helpful
Andy
richud
Post by richud » Thu Jun 16, 2016 2:19 pm
I have (Solidisk) DFS2.2 (IC88) and SuperMMC rom (IC100) and usually boot from floppy with shift-break and boot from SuperMMC with shift-m-break
I just burned MMFS rom (built from todays git) and swapped it out with SuperMMC chip - but I cannot seem to get anything from my SD card.
If I take the DFS chip out, MMFS boots fine with shift-break.
Should these be ok living together? Is there a shortcut similar to shift-m-break to boot MMFS?
I feel I am missing something simple....
Thanks for any help!
Post by sweh » Thu Jun 16, 2016 2:24 pm
I believe MMFS uses the "S" key, according to the comments :-)
richud
Post by richud » Thu Jun 16, 2016 5:38 pm
Hi Stephen,
Ah thanks I thought I had gone through all the letters but obv. not :)
However it now says 'Bad Sum'.
I just tried another DFS chip from another beeb (DFS 2.23) with it and same thing?
Cheers, R
Post by hoglet » Thu Jun 16, 2016 5:45 pm
richud wrote: Ah thanks I thought I had gone through all the letters but obv. not :)
Bad Sum typically means that two filing systems have trampled over each other's workspaces.
This seems to happen most when first loading Filesystem ROMs into sideways RAM, or when using *INSERT/*UNPLUG on the Master.
The quickest fix is to do:
*FX 200,2
followed by Control Break.
Try this and see if it helps.
richud
Post by richud » Thu Jun 16, 2016 6:08 pm
Hi Dave,
*FX 200,2
doesn't seem to change anything. (using a BBC B, no addons)
The only way I can get anything on the SD card with DFS chip oin is like this;
*MMFS
*EXEC !BOOT
Any suggestions appreciated - happy to do any debugging if it helps!
Post by hoglet » Thu Jun 16, 2016 7:12 pm
What exactly does "Shift-S-Break" break do?
Post by CMcDougall » Thu Jun 16, 2016 7:21 pm
^ a bit like Shift-Z-Break to get a 1770FDC to emulate a 8271FDC
or Shift-T-Break to get a tape
so, 'forces' the MMFS to be the first FS
Post by hoglet » Thu Jun 16, 2016 7:42 pm
CMcDougall wrote:^ a bit like Shift-Z-Break to get a 1770FDC to emulate a 8271FDC
Thanks Col, I know what it's meant to do. :lol:
I was asking what it actually does on richud's system, i.e. what happens, or doesn't happen!
richud
Post by richud » Thu Jun 16, 2016 8:01 pm
hehe, ok
power on
BBC Computer 32k
DFS 2.2 M (1770)
Basic
Shift-S-Break
BBC Computer
Model B MMFS
Bad Sum_
Post by hoglet » Thu Jun 16, 2016 8:36 pm
Do you see the same Bad Sum with DFS 2.23 instead of the Solidisk DFS?
I can try to replicate this tomorrow.
richud
Post by richud » Thu Jun 16, 2016 8:56 pm
yep, Bad Sum on both DFS chips
Post by hoglet » Thu Jun 16, 2016 9:00 pm
Just a couple more questions, and I'll try to reproduce tomorrow.
- Are you using the latest version of MMFS (1.27?)
- Exactly what ROMs do you have in what slots?
Post by sweh » Thu Jun 16, 2016 11:24 pm
Another thing to try is to press shift-S while turning the machine on.
Another variation would be to change the order of the ROMs (so MMFS is higher priority than DFS).
richud
Post by richud » Fri Jun 17, 2016 7:27 am
MMFS 1.27 from git (16th Jun)
Have the two standard ROMS (O/S, BASIC), DFS and MMFS
Shift-S on power on is also Bad Sum_
duikkie
Post by duikkie » Fri Jun 17, 2016 8:30 am
was shift-s on break not something for SMART rom :) ? mmfs not for M ?
richud wrote:MMFS 1.27 from git (16th Jun)
Post by CMcDougall » Fri Jun 17, 2016 10:48 pm
at Richud,
Press S-Break first, then Shift-s-break, sorted 8)
richud
Post by richud » Sat Jun 18, 2016 7:42 am
@CMcDougall : ah yes, that works around it :)
Post by hoglet » Sat Jun 18, 2016 4:01 pm
Hi Guys,
I have a possible fix for the Bad Sum error:
https://github.com/hoglet67/MMFS/commit ... b2c58b9421
It turns out there was a path the code could take on soft autoboot where the drive mapping table was not initialized (or restored from workspace)
Here's an updated build:
mmfs_1_28_20160618_1653.zip
(1.17 MiB) Downloaded 50 times
I'm a little nervous this may have some other repercussions, so if anything seems broken then let me know.
I've also changed the the key for MMFS from "S" to "M" to avoid conflicts with SmartSPI and other SD Card filesystems. So it's Shift-M-Break now!
richud
Post by richud » Sat Jun 18, 2016 7:37 pm
great - will try on Wed when back at work and have UV lightbox :)
richud
Post by richud » Wed Jun 22, 2016 6:59 pm
@hoglet, just pulled git and flashed to EPROM and works with shift-m-break :)
Without the floppy connected, and powering on from cold, it hangs here though - beeb fault?
Post by hoglet » Wed Jun 22, 2016 7:04 pm
That's a bit strange....
Can you upload the file you actually programmed, and I'll check it against what I built?
15 other downloads, anyone else got 1.28 working (or not)?
Post by DutchAcorn » Wed Jun 22, 2016 7:10 pm
richud wrote:@hoglet, just pulled git and flashed to EPROM and works with shift-m-break :)
Perhaps it is just looking for a floppy? See this thread: viewtopic.php?t=6652#p68724
