Removing Master Modem board
kieranhj
Post by kieranhj » Sun Jan 17, 2016 6:25 pm
Hey all,
My Master has a Master Modem installed which I would like to remove. The screws are easy but the white ribbon cable connecting it to the main motherboard is not budging and I don't want to break anything. Do I require any specific tools or am I doing it wrong? ;)
Picture attached to illustrate. Any and all advice gratefully received!
Thanks,
Kieran
kieranhj
Re: Removing Master Modem board
Post by kieranhj » Sun Jan 17, 2016 6:30 pm
poink
Post by poink » Sun Jan 17, 2016 8:36 pm
kieranhj wrote:Do I require any specific tools or am I doing it wrong? ;)
Looking I've always assumed that there's a clip which you'd have to pull before you could remove the cable; locking clips in general are fairly common on flat cables.
The installation section (page 11) of the Beebug Master Modem Manual seems to confirm there's a clip you have to pull up.
Post by RobC » Sun Jan 17, 2016 8:49 pm
Yes - I had to lift the clip up to fit the cable from the SCSI board on my Master AIV.
