soviet wrote: ↑Mon Oct 14, 2019 6:44 pm
Thanks rob for the information, how do you load the doom rom on sideway ram ?.
I usually use the *SRLOAD command in DFS but I don't think it's available in MMFS. That disk image is from my ADFS hard drive so I've only used it with ADFS. I think tricky wrote a little assembler routine to do it for the recent meet-up - I'll see if I can knock something up for you (unless tricky can remember his code).
Also i see in the hard drive image there what seems a gameboy emulator that works for real ?
I'm afraid not. It's just something that I've been thinking about porting for a good while. I'm pretty sure it's viable (at least with VideoNuLA for scrolling) but I haven't got round to getting it running. I was seriously looking at it before Doom came along but parked it. Not sure why I put the source code on my Master though
Unfortunately, I've got loads of projects like this that are half started/finished. I did a lot of work on a port of
Elite TNK a while back but haven't got anything to show yet.
The ZX81, Jupiter ACE, ZX Spectrum and Amstrad CPC emulators should all work though. I've also got a working PDP-11 emulator running UNIX but I don't think it's on that image. Doom is nearly finished but I need to get sound working, fix a few bugs and sort out the palette stuff so it'll run any WAD.
