Scans of Microfilm Circuit Diagrams
Post by danielj »
OK - so, this is as good as I can get them. If it's looking OK and useful, I'll continue through the whole batch?
Let's start with the PET...
2015-10-05-0002.tif
2015-10-05-0002.tif (125.95 KiB) Viewed 2686 times
Re: Scans of Microfilm Circuit Diagrams
Post by IanS »
Hmm, you can almost read some of the pin numbers.
Is the limitation the microfilm or your scanner?
Post by daveejhitchins »
Daniel:
Better than I achieved . . . I wonder what they look like through a high powered magnifier, with a good light source**? This would tell you the actual quality of the negatives. There would be no point in trying to get better than the actual negatives themselves.
**Maybe a look at the numbering around the ICs would give a good indication.
paulv
Post by paulv »
At almost 1200 dpi, it must be the resolution of the original slide that's the limiting factor. With some effort it would be possible to recreate a modern version of the circuit diagram from that scan which would be useful.
Do all the slides look like they have hand written aspects to them?
Post by danielj »
I'm at the limit of the scanner, it's doing them at 4800dpi (that's its optical resolution). The only thing I can think of doing is asking the digital services guys in the University Library whether they can help out. I suspect they might be able to...
Post by danielj »
Power Supply (this one's less legible)...
2015-10-05-0003.tif
2015-10-05-0003.tif (56.96 KiB) Viewed 2686 times
paulv
Post by paulv »
danielj wrote:it's doing them at 4800dpi (that's its optical resolution)
Are you shrinking them down for the site or is there some form of scaling going on with the scanner software? IrfanView is reporting them as being 1175dpi...
Post by danielj »
Probably because I said the output size should be A6... (it'll just be the physical size the TIFF thinks it is rather than any more/less pixels scanned)...
Post by danielj »
Just tried a few more and it's really pushing it - I'll pop across to the library tomorrow lunchtime and see what I can do - it looks like they have the relevant kit: http://www.library.manchester.ac.uk/ser ... -scanning/
Post by danielj »
It's amazing what using the right gear can do...
teaser.zip
(549.08 KiB) Downloaded 132 times
paulv
Post by paulv »
Wow! That's quite amazing! :shock:
=D> =D> =D>
I know it's a black and white scan but the dithering would suggest that you may get even better results if you do a grey scale version if it's possible. It may be worth a test scan at least.
paulb
Post by paulb »
What gear did you use in the end? I could only find instructions for conventional multi-purpose scanners on that UoM site. Do they have something much nicer?
Post by danielj »
They have a fairly highfalutin microfilm and microfiche viewer which has a scanner built into it. I think it was one of these: http://kmbs.konicaminolta.us/wps/portal ... s6000-mkii
Unfortunately you have to stick the thing in the reader, go over to the computer, press scan, go back to the reader, move it, go back to the computer, press scan etc, etc. Each card needed 6 scans. I did them at max zoom, 800dpi.
I'll give myself a couple of days off and go back and see if I can tweak the settings a bit, as I just basically burnt my lunch hour doing all of them. :D
Post by danielj »
I should say, if anyone wants to have a go at stitching, drop me a PM...
paulb
Post by paulb »
danielj wrote:They have a fairly highfalutin microfilm and microfiche viewer which has a scanner built into it. I think it was one of these: http://kmbs.konicaminolta.us/wps/portal ... s6000-mkii
Your efforts are appreciated! =D>
Short of your equipment discovery, I was going to suggest options involving magnification, as opposed to trying to get the best out of a flatbed scanner or similar apparatus. Every now and again, I read discussions about slide copying using lashed-up rigs of cameras and macro lenses, although I'd really want to be sure that the resolution delivered does actually exceed what you'd normally get. Otherwise, it's just a great way of doing stuff the hard way. :)
Post by danielj »
Bit rough and ready - this one needs re-doing,missed the edge... I should say that this is probably the "largest" I can do them as whole files. The full sized images are MUCH bigger, but the board can't take a 70mb TIFF...
Post by hoglet »
We should probably start a new thread discussing how the PET tester was designed to work.
The connectors are interesting.....
SK1 (top/left) looks like it's designed to plug into an Atom PL7 connector, or maybe a System bus connector - I think they are the same.
Anyone any idea how the other connectors attached to the Beeb?
station240
Post by station240 »
No one seems to really know the connections for the PET, hence the need to get the circuit.
best guess however considering how the pins are wired.
PL6 1Mhz bus
PL5 Printer port
PL4 User port
PL3 unknown (not wired correctly for a Disc Drive)
PL2 Tube???
http://chrisacorns.computinghistory.org ... n_PET.html
dp11
Post by dp11 »
Pl1 clips on top of the 6502 I think.
Post by danielj »
I think Mark (retroclinic) has one. I haven't seen a copy of the ROM anywhere - that would probably go some way to explaining what's what?
Post by danielj »
Today we have an early FIT...
paulv
Post by paulv »
Wow. considering this is the only other version of that schematic that I know of...
http://www.computinghistory.org.uk/pdf/ ... st-Jig.pdf
I think you've done exceptionally well up to now! Keep up the good work!
Post by danielj »
Thanks Paul, it's really nice to know these are "unseen" and improving what's been archived!
Another one:
Post by 1024MAK »
Well worth it =D> =D> =D>
Daniel:
Thanks for persevering and producing great scans - and again . . . thanks to all who contributed, appreciated.
Post by danielj »
Teletext adaptor!
Post by DutchAcorn »
hoglet wrote:We should probably start a new thread discussing how the PET tester was designed to work.
There is a PET tester on ebay now. Seller only posts to UK so not for me but I don't mind chipping in if it helps getting this in capable hands.
Post by hoglet »
DutchAcorn wrote: There is a PET tester on ebay now. Seller only posts to UK so not for me but I don't mind chipping in if it helps getting this in capable hands.
I'm not completely clued up on this, but there were three types of tester:
- A Progressive Establishment Tester (PET) - http://chrisacorns.computinghistory.org ... n_PET.html
- A Final Inspection Tester (FIT) - http://chrisacorns.computinghistory.org ... n_FIT.html
- A Port Tester (PT) - not seen a picture of this
I think the eBay item is a port tester, because it looks different to the other two.
Wouter Scholten
Post by Wouter Scholten »
Port tester? What is that supposed to do?
There is a 3rd tester that I know of and which I have: An econet test box. I have the PET and FIT testers too, and software and manuals. Today I finally read in the EPROMs FIT 1.00 [ 2532 ], PET 4.00 [ 2732 ], then for the BBC micro itself, FIT test ROM 1 (201 639-02) [ 27128 ], FIT test ROM 2 (201 640-02) [ 27128 ]. Next week perhaps trying it out, finally. Who else has a PET/FIT tester and dumped the ROMs? I'd like some verification that the bits are still OK...
Post by hoglet »
A "Port Tester" is mentioned here:
http://chrisacorns.computinghistory.org ... gNews1.pdf
and here:
viewtopic.php?t=9637
and the BBC Model B+ Service Manual says:
A PORT tester is available for the microcomputer. This is an uprated
version of the old FIT tester. It will check the DRAMs, and all the
I/O ports on the microcomputer: disc, printer, user, 1MHz bus, TUBE,
UHF, video, RGB, RS423, cassette, A to D, and ECONET. To use this
tester, the microcomputer must at least have the CPU running and the
MOS/BASIC ROM working and sane of the
RAM working.
Full operating instructions are supplied with the equipment.
