yellowdog77
Post by yellowdog77 »
I understand, thank you very much for the information.
fordp
Post by fordp »
FordP (Simon Ellwood)
Post by hoglet »
Thanks for that link Simon.
Adrian does seem quite pleased with the end result....
I'm keeping track of the various video here:
https://github.com/hoglet67/RGBtoHDMI/w ... ube-Videos
Ian, did you have to give Adrian much help creating the profile?
IanB
Post by IanB »
hoglet wrote:
Sat Jun 05, 2021 10:11 pm
No, he did that himself.
BTW the double pixel problem on the Mac output in integer scaling is a rounding error in the Pi's hardware scaler when using an odd numbered horizontal scaling value like x3 or x5. I found a workaround which fixed that by adding a 1 pixel overscan to the output resolution, see: https://github.com/hoglet67/RGBtoHDMI/c ... 54a3c51d90
Here's another one from Adrian using it with the Laser 128 + custom palette:
https://www.youtube.com/watch?v=DHooJIb4xeE
(Starts at about 15:30)
Retro Recipies installing a c0pperdragon Amiga board with Vampire board:
https://www.youtube.com/watch?v=Xz1_W0oKH14
There is a brief followup video demonstrating the solution I added to switch off the HDMI output when the Amiga displays a grey screen to allow the auto switching to work but it hasn't been made public yet.
adriancblack
Post by adriancblack »
Another video on using the C64 with RGB2HDMI (C0pperdragon as well) from Retro Hack Shack:
https://www.youtube.com/watch?v=oo_gWjK-gGw
But yeah the Mac worked out great! People seem to be pretty excited about it -- I think what might temper their excitement a little is the general unavailability of the hats at the moment. The Mac video is a bit old so I haven't had a chance to test Ian's fix yet.
I'll be doing the Apple IIc video next, comparing it to the Apple //C VGA adapter (FPGA based) ... spoiler alert: the RGB2HDMI blows that thing away and of course is cheaper and much more versatile. Ian's has been putting in a ton of work getting the latest releases working incredibly well with the IIc. (And this is using the digital connection, not over composite.)
I can't say how great this project is for the community!
IanB
Post by IanB »
I've updated the wiki to document the changes over the last few months:
Wiki
Changes include:
Supported Computers
Quick Start Guide
Reference Guide
Cables
Gallery of Screencaps
I've also added a new section on measuring the lag using an oscilloscope and a HDMI to VGA converter:
Lag Measurement
Also Sam Coupe support was added recently which had an unusual 7 bit TTL output (2 bits each RGB + Intensity)
Here's a screencap of it running lemmings:
Lilwashu
Post by Lilwashu »
Does anyone know if it would be possible to get digital video out of an Apple II/II+/IIe (no external RGB port without unobtanium video card) by grabbing the signals from somewhere on the motherboard like the Amiga version?
yellowdog77
Dear IanB!
Hoglet said you're already involved in development, so I want to ask, you would do the 3x8 bit mode? If this is not possible, it would be good to have either 3x7 bit (2097152 colors) or 3x6 bit (262144 colors) mode.
Thank for your help!
IanB
Post by IanB »
Lilwashu wrote:
Tue Jun 08, 2021 6:41 pm
It should be possible but I haven't tested it.
You need to pick up the SYNC, GR, SEROUT, GND and +5v signals which are available internally on the 80 column expansion connector in the IIe (not sure about the II or II+) and use the Apple IIc TTL profile as they are the same signals as the connector on the IIc.
The quality will be identical to using the analog version connected to the composite output except that the 4 lines of text in mixed modes will stay white and not have any artifacts.
See the Apple IIc connection in the Cables section and the Gallery of Screencaps for a comparison of TTL connection with composite connection.
IanB
Post by IanB »
yellowdog77 wrote:
Tue Jun 08, 2021 9:22 pm
No, it isn't possible to increase the bit depth that much with the current design which has reached it's limits. It might be possible to increase to 5+6+5 bits for full 16 bits per pixel but even that would require a larger CPLD with more pins and a non trivial redesign so it would be probably be better to do a complete redesign from scratch using the camera input which would likely work at 24bpp and maybe support audio as well although I don't know what sort of lag such an arrangement would have. Such a redesign would require a much larger CPLD or FPGA which probably wouldn't fit in the footprint of the existing 'hat' pcb.
yellowdog77
Ok, thanks for your reply.
aotta
Post by aotta »
IanB wrote:
Tue Jun 08, 2021 11:01 pm
I can confirm working on my IIe PAL (with PAL switch OFF).
Here's the pick-up point i used:
GR -> IOU pin 2
Sync -> IOU pin 39
SEROUT -> 166 pin 1
GND -> ROM pin 14
and here are a couple of screenshots:
but i couldn't test the "Mixed mode" because... i haven't an integer language card and i'm not an Apple users... i don't know how to get the screen demo test.
IanB
Post by IanB »
aotta wrote:
Thu Jun 10, 2021 9:54 am
Thanks for testing this on a PAL IIe
It looks like you have already tested mixed mode as the "32MB" colour image has clean white text at the bottom so that must be using one of the mixed modes. That text would have coloured artifacts when using the composite output.
aotta
Post by aotta »
IanB wrote:
Thu Jun 10, 2021 4:59 pm
Thank you Ian, and i think the GR command in basic it's for the "mixed mode" you're talking about:
of course, the RGBtoHDMI output with this TTL input is the same with PAL switch in ON or OFF position, but i had to change the ntsc phase to 270° to have the right colours:
Lilwashu
Post by Lilwashu »
GR -> IOU pin 2
Sync -> IOU pin 39
SEROUT -> 166 pin 1
GND -> ROM pin 14
This is great, thanks - My IIe is also PAL so as soon as I get hold of a board I will give it a try.
aotta
Post by aotta »
Lilwashu wrote:
Fri Jun 11, 2021 8:55 am
Anyway, I found the pickup point on IIe schematics, I think they are the same for both pal and ntsc version
