Non-working floppy drive
courseddent
Post by courseddent » Sat Aug 01, 2020 7:05 pm
I recently bought a "working" Cumana CS100 floppy drive off ebay, and just got round to trying it and it doesn't work:
https://www.youtube.com/watch?v=lG6KAHNIPYI
The stepper motor seems to be struggling to move the head, although the head can be freely moved manually. Any ideas how to fix this? First thing that sprung to mind was a recapping, but couldn't see any significant large ones on the board.
Re: Non-working floppy drive
Post by danielj » Sat Aug 01, 2020 7:47 pm
Don't buy into the "all faults are bad capacitors" story as perpetuated by various retro-communities! (there are good reasons to replace in certain circumstances but those revolve around non-working PSUs, having an Amiga 600 or 1200, or a ZX Spectrum 48k).
Check the wires and connection to the stepper? Looks like poor contacts. Can you take a picture of the PCB properly? Cumana used many different makes of drive in their boxes.
Wheel_nut
Post by Wheel_nut » Sat Aug 01, 2020 8:42 pm
Is that a video of your drive? What make is the bare drive in the enclosure? Cumana used many different bare drives in their enclosures so pictures of the maler's label and the top side view would help.
vanekp
Post by vanekp » Sat Aug 01, 2020 10:32 pm
do you have any jumpers set on your keyboard for drive stepping speed maybe its trying to step too fast.
Peter.
courseddent
Post by courseddent » Tue Aug 04, 2020 4:17 pm
Didn't think of that - good suggestion. I went and tried various different timings, but unfortunately the problem remained.
courseddent
Post by courseddent » Tue Aug 04, 2020 5:08 pm
Yes - the video is the actual drive. I've attached some more detailed pics of it, looks like a Mitsumi D501?
courseddent
Post by courseddent » Tue Aug 04, 2020 5:26 pm
Hehe, yes - it's very easy to jump to the capacitors causing all the ills of the world conclusion! I had a look at the stepper cable, and reseated the connector - all looked in reasonable shape, although can't test continuity of the cables as they disappear into the stepper.
vanekp
Post by vanekp » Tue Aug 04, 2020 10:04 pm
Does the head carriage move up and down freely (taking into consideration the resistance the stepper motor put on it)?
a lot of carriages get very stiff as the lubrication drys up and they get a build up of dirt on them.
Peter.
Post by Coeus » Tue Aug 04, 2020 10:22 pm
Don't buy into the "all faults are bad capacitors" story as perpetuated by various retro-communities! (there are good reasons to replace in certain circumstances but those revolve around non-working PSUs, having an Amiga 600 or 1200, or a ZX Spectrum 48k)....
Hehe, yes - it's very easy to jump to the capacitors causing all the ills of the world conclusion! ...
Personally, I don't like doing needless work or paying to replace components that are working so I am reluctant to indulge in the "replace bits until it works" approach whether it is capacitors or anything else. When swapping parts around is easy, and you already have spares, then fine but even then having some kind of method is good.
Otherwise trying to think logically, runs tests where you can, and asking for help on here seem like much better approaches.
retroclinic
Post by retroclinic » Wed Aug 05, 2020 3:46 pm
What FDC do you have? If it's a 1772, then no speed setting will be slow enough for that drive.
Thanks, Mark.
retroclinic
Post by retroclinic » Wed Aug 05, 2020 3:50 pm
..as for cap replacement, on a motherboard generally I agree, if it ain't broke, don't try and fix it, but for Power supplies, especailly the Model B ones, it's a MUST. This PSU and it's caps looked perfect from the top, it was only on dismantling....
courseddent
Post by courseddent » Wed Aug 05, 2020 7:00 pm
After discussing this with Retroclinic, it sounds like this drive is too slow to work with the 1772 chip in my BBC Master, so may actually be working fine, just not compatible.
Post by Kazzie » Thu Aug 06, 2020 6:30 am
That's quite possible (I have some ancient full height single-sided Olivetti FD501s that are too slow for a 177x), but I wouldn't have expected a drive with such a small circuit board, and all the control circuitry integrated into a single IC, to be that "old and slow" .
Sadly, I can't find any further details on the D501 online. Are there any markings that could be a datecode (on the PCB chips, or labels) that could give an idea of when this was built?
RiscPC 600 under repair
