Hmm.. was there ever an 8" floppy drive for the BBC?
Re: Hmm.. was there ever an 8" floppy drive for the BBC?
Post by Pernod » Tue Sep 10, 2019 6:21 pm
gtoal wrote:
Tue Sep 10, 2019 5:34 pm
Could some kind soul please extract the contents of D1000.IMG and D1000B.IMG from http://gtoal.com/bbc/ ?
Just rename them to .ssd and mount in BeebEm, then use Edit->Export Files from Disc.
The DNFS30 ROM image is the standard DNFS.
gtoal
Post by gtoal » Tue Sep 10, 2019 6:52 pm
I guess I could do that, but I have several hundred images to unpack and was waiting until I could find a command line program that I could script to do them all at once rather than each one manually through a GUI :-/
The 8in DFS code in that drive image takes the standard rom and patches it and writes out a new image. If I remember right, it disables the net part of the rom. I can't remember if it changes the filing system number or not to allow regular DFS to work at the same time - it's been a long time...
G
Post by davidb » Tue Sep 10, 2019 9:43 pm
I extracted the files from D1000.IMG but couldn't manage to do the same from D1000B.IMG. What kind of format is that using?
D1000.zip
(27.52 KiB) Downloaded 11 times
Post by BeebMaster » Tue Sep 10, 2019 10:40 pm
D1000B.IMG is a corrupt DFS disc image containing one file. The catalogue and map at the first two sectors have been overwritten with zeroes, then a BASIC file starts at sector 2 which is attached.
D1000B,ffb.zip
(1.42 KiB) Downloaded 10 times
Post by Coeus » Wed Sep 11, 2019 12:25 am
Check out SWH's beeb perl script: https://www.spuddy.org/Beeb/mmb_utils.html
gtoal
Post by gtoal » Wed Sep 11, 2019 2:39 am
Thanks DavidB and BeebMaster! So looks like everything is there that the folks who wanted to build an 8in drive need :-)
Here are the basic sources needed to build a DFS rom (with tube support of course) and a formatter.
http://gtoal.com/bbc/D1000/B.NEWPROC.txt
http://gtoal.com/bbc/D1000/B.NMIPROC.txt
http://gtoal.com/bbc/D1000/BUILD.txt
http://gtoal.com/bbc/D1000/Form77s.txt
http://gtoal.com/bbc/D1000/GRABBER.txt
http://gtoal.com/bbc/D1000/SENDER.txt
We only implemented the 8in support for fun back then, I don't think we ever had a practical use for it. As far as I remember the only 8in floppy we ever wrote contained the same files as that 5.25 image with the DFS and formatter :-)
G
gtoal
Post by gtoal » Wed Sep 11, 2019 4:56 am
That did the trick. A few images were corrupt but I found a lot that was useful. Will sort it out and post later.
G
Post by BeebMaster » Wed Sep 11, 2019 4:35 pm
It's interesting to learn about the history of the BBC micro disc interface. Until now I'd never really given any thought to the capacity difference between 8" and 5.25" discs, I think I'd always thought that an 8" BBC micro floppy disc, if one had ever existed, would just be 80T 200K in DFS like a 5.25" disc.
I think the fact that there was never a 77-track 8" DFS ROM or formatter officially released tells us that there weren't any 8" floppy drives envisaged for general use.
However if we compare and contrast the 1982 and 1985 editions of the service manual: the disc upgrade instructions in the 1982 version don't mention 5.25/8" at all, the only references to disc size are elsewhere, eg. in the link survey. By 1985 for some reason there are separate upgrade instruction sections for 5.25" interface and 8" interface - although the 8 inch one purely says do the 5.25" upgrade and then alter 3 links.
AndyF
Post by AndyF » Thu Sep 19, 2019 4:16 am
Judging by the text strings I see in the image, that is likely our 8 inch formatter and modified DFS.
(I'm not in a position to extract files from a disk image yet)
thanks
Graham
D1000 looks OK. D1000B appears blank (confirmed via examination with hexedit directly from Windoze)
View from BeebEm:
View from DiscExplorer:
Extract them to what format ? What did you need the "raw file+inf file" type ? :-? :) I'm assuming that is what you wanted as otherwise the .img would be fine as that is a complete disc. Not sure how to use it, I glanced at a couple of the programs on it:
d1000_extracted.zip
(29.39 KiB) Downloaded 5 times
Andy
vanpeebles
Post by vanpeebles » Thu Sep 19, 2019 8:04 am
Slightly random story, but when I did my school work experience at Durham County Hall in the mid 90s, they still had systems using 8" floppies, at depots and a museum. :lol:
Diminished
Post by Diminished » Sun Sep 22, 2019 4:38 pm
Alex van Someren mentioned in his talk at ABUG on Saturday that the Beeb was indeed first designed to use 8" drives (and rightly or wrongly I inferred that the original intent was exclusively for 8" drives, although this obviously ended up not transpiring).
Of course this doesn't answer the question of whether very many people actually used it in this configuration.
