RISC iX - Cloned!
Related forum: adventures
ajw99uk
Re: RISC iX - Cloned!
Post by ajw99uk » Sun Oct 01, 2017 1:25 pm
dangardner wrote:Unlike my A410/1, my A5000 does actually seem to like the taste of UNIX! This makes me very happy! :-)
Mine did not, throwing an address exception, so I removed everything except the SCSI card, sorted out sync to get a working monitor and am now looking at X desktop.
adfsls returns "Floppy 0 hung
adfsls: Cannot open /dev/rfdf1024" so apparently no floppy support, unsurprisingly.
33MHz ARM3 with FPA11, 8MB RAM, Wizzo5 ROM in 5th column but modules unplugged. It usually also contains CC Gold, EtherH and a 486 podule, which I will have to add back one by one to see what breaks.
UPDATE from Sunday afternoon: fully repopulated and still booting, single user at least, from the 4corn image (now cloned to another disk). Huzzah!
ajw99uk
Post by ajw99uk » Mon Oct 02, 2017 3:23 pm
dangardner wrote:
DutchAcorn wrote:Any suggestions to get this one step further? It has been a lot of fun so far but :D
What happens if you drop to the CLI and run this?
*filer_opendir Riscixfs:$
Also see if you can boot into RISC iX using *BOOT. I discovered the *filer_opendir at https://groups.google.com/forum/#!msg/c ... TjxS_jy5MJ which also has some interesting background information on RISCiXFS.
Indeed.
The info about the partition map and the RISCOS section appearing as partition 6 (or "sdNg") caught my eye. Most mkdisktab output I have seen gives pa, pb and ph for Root, Swap and whole disc (plus pc, pd etc if defined) but not pg - except one, from my Compaq-branded Fujitsu, which happens to be the same drive showing initialisation problems and the disktab I have created most recently. Looking at /etc/disktab from an R260 installation, there is a "pg" entry for the Conner CP3100 and for "whitbred" (ca. 100MB Winchester), E40s1, E60s, "CDC" Winchester (ca. 170MB) and a Nomai 540MB cartridge drive. But "pg" is missing from a mkdisktab output for a NEC 1700S (ca. 1.7GB). I'd guess it's a matter of different versions of scsidm and/or RISCiX.
ajw99uk
Post by ajw99uk » Mon Oct 02, 2017 5:15 pm
SarahWalker wrote: Not sure why the border colour keeps cycling though, it's a little distracting!
I think this may happen when the network is not configured. I get a flashing border (in monochrome) if I start X without having first done "ifconfig et0 ..." - single user mode not doing this for me, but no flashing if startx is issued after ifconfig/route commands.
timw
Post by timw » Mon Oct 02, 2017 6:12 pm
The flashing border normally indicates that the contents of one of the (other) virtual terminals has changed. Use <Break> and the cursor keys to toggle between them (see R140 Operations Guide page 37). You can press N on the menu screen to disable the border flashing.
ajw99uk
Post by ajw99uk » Tue Oct 03, 2017 9:36 am
timw wrote:The flashing border normally indicates that the contents of one of the (other) virtual terminals has changed. Use <Break> and the cursor keys to toggle between them (see R140 Operations Guide page 37). You can press N on the menu screen to disable the border flashing.
Thank you. Operating in single user, I had thought there was only one terminal and, with only 4MB RAM, just one X screen. I really must read the guide through, as though written for 1.1x the bits I have looked at for specific issues seem to remain useful for 1.2x.
Boydie
Post by Boydie » Tue Oct 03, 2017 10:45 am
It actually works at all on an A5000?
I was formerly under the impression that it couldn't cope with IOEB (which didn't exist at the time) and would die horribly. Presumably, floppy and ide won't work; I'd always assumed podules wouldn't either.
Now I'm going to have to give it a try, and see if I can add a fifth riscix machine to the fold (good thing I've got a spare scsi drive).
Wonder if A4000 is a chipset step too far...
SarahWalker
Post by SarahWalker » Tue Oct 03, 2017 5:45 pm
I doubt any of the RISCiX compatible SCSI podules are available in an A4000-friendly 8-bit minipodule form.
ajw99uk
Post by ajw99uk » Wed Oct 04, 2017 12:19 am
Boydie wrote:It actually works at all on an A5000?
I tried ages ago and it did fail, so I had the same impression (short of find a version with a tweaked kernel etc).
But seeing that success with an A5000 had been reported here, I had another go. Same SCSI drive booted fine in A540, R140 and A5000, using the 4corn installation.
AKA32 in the A540/A5000 and AKA31 in the R140, all with version 1.10 of the SCSI modules and all with RISC OS 3.1.
As previously reported, floppy does not work. I have not tried serial/parallel in the A5000 (nor on the Arcs come to that).
Boydie
Post by Boydie » Wed Oct 04, 2017 9:46 am
SarahWalker wrote:I doubt any of the RISCiX compatible SCSI podules are available in an A4000-friendly 8-bit minipodule form.
Oh, yeah. I'd have noticed that... Eventually! #-o
ajw99uk
Post by ajw99uk » Thu Oct 05, 2017 10:46 am
ajw99uk wrote:I already had a couple of other kernels from an R260 donated to Bletchley Park, and thought it may be down to kernel differences that prevented booting with the SCSI card in slot 1 rather than 0 in my past experience. However, experiments this morning show that slot 1 seems fine, and better for keeping the SCSI card cool (I can see why the A680 reportedly had problems with is onboard SCSI overheating, and now regret not having kept a short ribbon cable). Slot 0 perhaps mandatory for RISCiX 1.xx in the R140, per notes in the old boot file).
Humph - slot 1 not working again. Same kernel but different HD. Other difference being arrangement of other podules, trying to get best fit for backplane position vs length of podule. But I noticed that podules are reported in slot order, after the test for m/b ST506. Previously slot 0 unoccupied so SCSI card seen first. With Ether1 in slot 0, panic. Move Ether1 to slot 2, boots ok. Hypothesis that the SCSI card needs to be highest priority else boot fails.
Interested so hear if that chimes with others' experience. And wondering if a third party podule would have the same effect (though no time to test that just now). If RISC iX has no driver for a podule in slot 0, it may still treat the SCSI in slot 1 as "top priority".
Boydie
Post by Boydie » Fri Oct 06, 2017 8:13 am
My R140 and A540 run fine for riscix with ethernet in slot 0 and scsi in slot 1. I've not checked how I've arranged them in the A4xx, but I suspect it will be the same (more direct cable run from slot 1), and that's fine with riscix too.
On boot-up, the kernel (either vanilla 1.21 or nsict #10) declares it's booting from scsi, then identifies and lists the podules in slot order.
ajw99uk
Post by ajw99uk » Sat Oct 07, 2017 11:12 am
Boydie wrote:My R140 and A540 run fine for riscix with ethernet in slot 0 and scsi in slot 1. I've not checked how I've arranged them in the A4xx, but I suspect it will be the same (more direct cable run from slot 1), and that's fine with riscix too.
Thanks, Boydie, seems worth investigating other causes here, such as the HD.
Which Ether podule (s) are you using? Ether1, which is the only RISC iX option I have, has no podule ROM so I wonder if that was skewing things. If you have Ether1 working in slot 0 that would rule out that theory.
Any chance you could share the #10 kernel? I don't think it's a matter of kernel version but useful to rule out with a known-good.
Ultimately I can live with a slightly longer cable rather than lose a podule slot, but thanks again for your info.
Boydie
Post by Boydie » Sat Oct 07, 2017 7:03 pm
You'll have to ask crj about a copy of #10 kernel - it's his build. He may also remember the differences. Unfortunately, I can confirm that version doesn't work on an A5000. Not in a position to test the 4corn version atm, so don't know if it's my hardware.
The A420 (technically an A480) also has ether slot 0 and scsi slot 1 and riscix is happy.
Ether card wise, I'm running one AKA25, and a pair of AEH50s (Ether 1 and Ether 2 respectively, I think).
ajw99uk
Post by ajw99uk » Sat Oct 07, 2017 9:02 pm
Boydie wrote:You'll have to ask crj about a copy of #10 kernel - it's his build. He may also remember the differences. Unfortunately, I can confirm that version doesn't work on an A5000. Not in a position to test the 4corn version atm, so don't know if it's my hardware.
Thanks, let's see what crj says.
Boydie wrote: The A420 (technically an A480) also has ether slot 0 and scsi slot 1 and riscix is happy. Ether card wise, I'm running one AKA25, and a pair of AEH50s (Ether 1 and Ether 2 respectively, I think).
Yes, Ether1 = AKA25, so I'll have to look elsewhere for my glitch. Ho hum.
Post by RobC » Sun Oct 08, 2017 8:29 am
ajw99uk wrote:Yes, Ether1 = AKA25, so I'll have to look elsewhere for my glitch. Ho hum.
My R260 used to give random panics due to track corrosion. They only went away when I patched up the worst affected tracks with kynar wire.
Might be worth cleaning contacts and checking connectors?
SteveBagley
Post by SteveBagley » Sun Oct 08, 2017 2:11 pm
This seems to be the best place to ask about RISX iX — there'll probably be a few more questions coming as I intend to upgrade one of my Arcs and install it for a play (I wonder if it’ll be the first A305 upgraded to be able to run Risc iX ;-))
But, I was reading about the Acorn R225 diskless Unix workstation which apparently netbooted off an R260. I was wondering how this booted? The potential options I can see where a specific RISC OS variant, modules added to the network card's ROM, or perhaps even using Econet to bootstrap things?
Anyone have any documentation on how this worked (or can point me to the bits I’ve missed)?
Steve
ajw99uk
Post by ajw99uk » Sun Oct 08, 2017 4:57 pm
SteveBagley wrote:But, I was reading about the Acorn R225 diskless Unix workstation which apparently netbooted off an R260. I was wondering how this booted? The potential options I can see where a specific RISC OS variant, modules added to the network card's ROM, or perhaps even using Econet to bootstrap things?
Steve
A R225 had a ROM podule with enough (on top of RISC OS 2.01) to find the boot server and bootstrap. Sorry, not sure which modules etc. I believe TNMoC has one.
crj
Post by crj » Sun Oct 08, 2017 10:56 pm
As I recall, it only contained two relocatable modules.
The first was the TCP/IP module pared down to do UDP, not TCP. (For all I know it was the same one used for AUN?) The second was a netboot module, which could use bootp and tftp to load a kernel.
Once the kernel was in RAM, and had been passed supplementary bootp parameters, RISC OS's job was done.
ajw99uk
Post by ajw99uk » Mon Oct 09, 2017 5:12 pm
ajw99uk wrote:Looking at /etc/disktab from an R260 installation, there is a "pg" entry for the Conner CP3100 and for "whitbred" (ca. 100MB Winchester), E40s1, E60s, "CDC" Winchester (ca. 170MB) and a Nomai 540MB cartridge drive. But "pg" is missing from a mkdisktab output for a NEC 1700S (ca. 1.7GB). I'd guess it's a matter of different versions of scsidm and/or RISCiX.
Another scsidm / mkdisktab query - what determines the blocksize? I have two outputs for the same drive, one is 4096 and the other is 8192. Looking at other entries, there seems little rhyme or reason unless again it's a version thing (scsidm as supplied with 1.1x using 8192 and scsidm as supplied with 1.2 using 4096?)
TimoHartong
Post by TimoHartong » Wed Feb 26, 2020 4:18 pm
Hello this is an old thread I have the following setup:
-Acorn R260
- SCSI AK31 card
- 12 Mbyte setup
- SCSI2SD
I downloaded the zip from : https://www.4corn.co.uk/articles/riscix121c/ . Extracted the zip on this R260 and copied it to an IDE podule with solid state from Ian ( I think )
Used the basic program it says on the end something in the line succesull. The discicon shows <unnamed> and when I try to access it I get an error message Disc not understood etc.
Did I miss something ?.
Post by DutchAcorn » Wed Feb 26, 2020 7:35 pm
The file you get if you decompress the zip file is a SCSI disc image. From your post it is not clear if you used the scsi writer program to write the image to the SCSI2SD connected to your SCSI card? :?
Writing the image file to an IDE disc is not enough, unless you subsequently use a scsi writer program to write that disc image to a scsi device.
TimoHartong
Post by TimoHartong » Wed Feb 26, 2020 9:56 pm
I used the provided scsi writer program to write it to the scsi harddrive.
Tomorrow I will try some things
TimoHartong
Post by TimoHartong » Fri Feb 28, 2020 10:18 am
A small update : I was able to 'clone' my RiscIX to a SCSI2SD disk. Unfortunately no luck with the image. Procedure more or less described in :
http://sink.me.uk/RISCiX/riscix_clone.htm
SteveBagley
Post by SteveBagley » Fri Feb 28, 2020 10:22 am
I've successfully written the RISCiX disk image (on 4corn) to an SD card for a SCSI2SD -- just use the same mechanism you would for writing an SD Card for a raspberry pi and then pop it in the SCSI2SD.
It should then be recognised by the Arc and you can configure it as necessary -- although I've found (both in Arculator and on my A310) that it doesn't seem to like running with RISC OS 3.11 installed but is fine with RISC OS 2… Not sure why.
Steve
TimoHartong
Post by TimoHartong » Fri Feb 28, 2020 11:41 am
That is important information because my R260 and also the A410/I run RO3 ( of course ). Did you do the writing also on an RO2 machine ?.
SteveBagley
Post by SteveBagley » Fri Feb 28, 2020 11:51 am
No -- I wrote the SD card using dd on my Mac. I've just done some testing with Arculator and it seems to be something to do with the CMOS values since I've now got it booting from RO3 (by forcibly replacing the CMOS values with those from a working RISC OS 2 setup)…
It's weird, the RISCiX kernel obviously boots and briefly prints something (see below -- it's up for about one frame) but then the screen stays blank before eventual rebooting.
Steve
dangardner
Post by dangardner » Sat Feb 29, 2020 9:41 am
There are some RISC iX floppies up on eBay at the moment: https://www.ebay.co.uk/itm/RISC-BBC-ACO ... 4190048250
TimoHartong
Post by TimoHartong » Sun Mar 01, 2020 11:05 am
It looks like an older version but looks interresting
SteveBagley
Post by SteveBagley » Wed Mar 04, 2020 12:39 pm
Think I've found what the problem is -- it doesn't seem to like booting RISCiX if automatic monitor detection is turned on.
Steve
Post by IanS » Wed Mar 04, 2020 10:31 pm
Nice find. That's very non-obvious.
