Inferno
Inferno
Post by davidb » Tue Aug 04, 2020 11:55 pm
As mentioned in the Alternative 32-bit operating systems topic, the Inferno operating system apparently ran on the A7000 at some point. It would be interesting to see the sources for the port but it's possible that they no longer exist.
Anyway, I thought it would be interesting to try and port it again, though this time to the A7000+, using RPCEmu to begin with. Later, I may try and actually run it on the real hardware.
The sources can be found on Bitbucket for those curious enough to want to take a look. You need to know how to set up the build environment, but feel free to ask if it's not obvious what to do, and I'll probably start to write up some instructions in any case.
