Level 4 - Econet & Ethernet simultaneously
Post by 8271 »
Hopefully this is me having a senile moment - I am struggling to get my level 4 server (running on an A310) to respond to both econet and ethernet requests. Econet works fine for the BBCs, but the ethernet side is problematic.
The A310 has an Ether3 (Atomwide) podule running 10Base2, it is configured with uniboot and is running access. I can see and share / mount discs on the ethernet side without any problems both from and to the A310; this is whilst concurrently running Level4 as well. Econet works and shares files too. However, the AUN element doesn't work to the A310.
I have installed Level4 on an A4000 and all the ethernet clients can access/share files (Raspberry PI / RiscPC etc) to the A4000 so I know the AUN section is working fine on the clients; suggesting that the problem is with the A310 configuration. (Interestingly, I ran Level 4 on both the A310 and A4000 and had the log window open - When the clients were logging on to the A4000, the log file on the A310 was also being populated (I.e. I could see the same log on both the A310 & A4000, suggesting that the broadcast elements of AUN appear to be getting through (such as *I AM etc). The A310 is the only risc-os machine with both Econet and Ethernet - hence the plan to make it the server for both networks,
I have set up the AUN mapping file to be
192.168.1.0 0 (my local network address and the local ethernet) - Should this be
192.168.1.0 128 (as I think Iremember reading that the ethernet clients all start with 128 as the net number?)
I am not running !Gateway (I have tried configuring it but it keeps address exception when I run it)- Is this necessary for a single server system?
Serial computer hoarder & econetophile
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
richw
Re: Level 4 - Econet & Ethernet simultaneously
Post by richw »
It should certainly be possible.
I had an A5000 with Econet (to Beebs and Arcs) and Ethernet (Arcs only, of course). I ran Level 4 OK. I think I ran the GateWay app, although it wasn't necessary as machines from either side did not need to talk to each other.
Sadly I cannot remember much detail, but it should work.
Does the Ethernet side work OK on the A310 if you remove/disable the Econet? And vice-versa?
Post by 8271 »
Hi Rich- I have disconnected the econet cable, but the response is still the same (I haven't tried removing the econet card yet).
I think it has something to do with the mappings, the IP stack on all machines works fine as I can ping all the ethernet stations and vice versa. ShareFS runs on all ethernet machines without problems - It just seems that the Level4 software is not responding / binding to calls on the ethernet card. I am not sure if there is a config file in level 4 beyond the exports file?
Post by BeebMaster »
I'm sure it must be possible. I have something similar, but on RISC PC (also done on A7000), and not using AUN.
Am I right in thinking that you have shared a RISC OS based storage space (on RPi, A4000 etc) via Ethernet so that you can access it on the A310, and you want to share that with the L4 file server?
The Exports file is a bit fussy, although there's a special syntax for network based shares, everything else must be addressed as if it's a local filing system even if it isn't.
My "Ethernet share" is in fact my RPi4 running Raspbian with NFS shared directories, which I can access on RPC or A7000 using !Sunfish. However to get these to export with the L4 file server, I have to point to a locally stored "Sunfish mount save" file as if it is a local directory. So "BML4" is a Sunfish config file on my hard drive:
ADFS	ADFS	4	$.ISW.BML4.BML4	BML4
which makes /media/BML4/BML4 (I couldn't share the partition root which is "/media/BML4", I could only share a sub-directory of the root, hence the additional "BML4") shared from my RPi4 appear as an accessible location to the L4 file server.
I think though that the L4 file server won't start if it can't process the Exports file. I had to add a bit of a bodge to the boot to check whether the Sunfish shares exist and then use a Sunfish or non-Sunfish version of the Exports file before starting the L4 server.
If you turn on the L4 file server Log file, does that give any error messages or other pointers?
Post by danielj »
Did we ever manage to get the L4 user guides scanned and uploaded?
Not that I know of - my flatbed scanner won't work with Linux, so I'd have to run it in a VM. I think I'd be best lending some of these 32-bit manuals to someone with the right kit to unbind the wire binding without destroying the books.
matt_nottm
Post by matt_nottm »
There are a couple of scans here:
viewtopic.php?f=29&t=7285&p=200276&hilit=lcww1#p200648
viewtopic.php?f=29&t=7285&p=219408#p206819
I'm happy to help with any future scanning of networking related material.
Post by 8271 »
Not quite- although in the future this might be something as I could share my NAS with the BBCs!
I am just looking to have my A310 running as a L4 server for econet, but also for the ethernet section too. I have access running on the ethernet so I can move files around but wanted to ideally have one dedicated machine as a server rather than using peer to peer. I am also looking to replace the A310 with an A5000 if I can find one at a reasonable price (as that can host both econet and ethernet).
I just cannot get the A310 to respond to AUN requests on the ethernet, In the log file I see the incoming *I AM requests, but nothing else happens and the client station times out. It is almost as if L4Server software on the A310 is unable to 'send' data on the ethernet side but can receive. I will have a fiddle with the AUN mapping files again to see if a few reboots are needed. Also, I don't know if AUN works simultaneously with Econet or whether you need to have !gateway running - The manual is a bit vague about this point.
Post by 8271 »
After playing around for a while it is now working.
The AUN Map needs the entry in the following format
0- 127 for Econet clients
128 - 254 for Ethernet clients.
Everything is now working hunky-dory Access & AUN are happily co-existing with the econet - Hooray!
Now to get !Mailman to work .....
Excellent...I know I had to faff about with internet settings in !Configure when I put an Ethernet NIC in the A7000 (and RISC PC I think), plus do some unplugging of system modules to make sure the podule modules were seen, but that was specifically so I could see my Linux share and go onto the Interweb.
Post by danielj »
8271 wrote:
Sun Jun 21, 2020 10:28 pm
Good work! Now, will that punt Econet over Ethernet across to an actual econet in proper gateway fashion?
