Is software for 32bit Acorn hardware dead?
Naomasa298
Post by Naomasa298 » Sun May 24, 2020 12:40 pm
Most of the programming talk on the forum is about 8-bit software.
Is software for 32 bit Acorn hardware (i.e. Risc OS) dead? Has everyone move on to Raspberry Pis?
dp11
Re: Is software for 32bit Acorn hardware dead?
Post by dp11 » Sun May 24, 2020 12:52 pm
No Software isn't dead. just most 32bit people live : https://www.riscosopen.org/content/
sirbod
Post by sirbod » Sun May 24, 2020 1:39 pm
As pointed out, 32bit folk live over on the ROOL forum. Posts here are generally about Archimedes through to RiscPC.
The forum channel names are a bit misleading in this respect, in that ARM2/3 which are the bulk of the discussions here are a 26bit address bus, it's only the registers and data bus that are 32bit. In Acorn community terms, they're generally referred to as 26bit Acorns to save confusion.
Admittedly things get more confusing with the RiscPC and A7000 which are 32bit capable, in which case we go by the OS bitness - everything pre RISC OS 5 including RISC OS 6 is 26bit. RISC OS 5 is 32bit and has its own forums over on ROOL.
Site Admin
Post by Arcadian » Wed May 27, 2020 3:24 am
We could easily rename our 32-bit forums to 26-bit if folks think that would be helpful?
Post by daveejhitchins » Wed May 27, 2020 4:31 am
My take from the posts I've seen and made, FWIW, is that any posts to our 32 bit sections are generalised to the Archimedes range and are not specific to the bit count!
I don't think changing the number from 32 to 26 would make any difference and may even confuse!
Interested to hear other opinions . . .
philpem
Post by philpem » Thu May 28, 2020 1:23 am
26-bit didn't even become relevant until the Iyonix turned up, and to most people the ARM platform is 32-bit because that's how wide the data bus, ALU and registers are.
I'm inclined to agree that it's confusing for newcomers... it's only really relevant if you're running RO on a modern platform like a Pi, and even there you have a bunch of CPU-specific gotchas related to unaligned loads and stores.
"32-bit pre-Iyonix, Beagleboard and Pi" is possibly a better distinction to make, if you have to make one.
Post by davidb » Thu May 28, 2020 9:41 am
One distinction would be between Archimedes era machines and the Risc PC era and later. The A-series machines can only run 26-bit code, as I understand it. The later machines can run 32-bit code if there is OS support for it. Am I remembering that correctly?
Alternatively, it could be between original/retro RISC OS and "modern" RISC OS since that will also determine whether you can run 32-bit code. So, maybe between pre-/post-RISC OS 5, though there is the ROOL forum for the modern stuff.
Naomasa298
Post by Naomasa298 » Thu May 28, 2020 10:49 am
Is RISC OS 5 still a thing?
Post by davidb » Thu May 28, 2020 11:18 am
Yes it is. RISC OS 6, not so much.
AJW
Post by AJW » Mon Jun 01, 2020 6:33 pm
What's the best platform to run RISC OS on?
Post by BigEd » Mon Jun 01, 2020 8:11 pm
If you don't already have a suitable Acorn machine, a Raspberry Pi is probably most convenient. There's a laptop, the ARMbok.
But you might well be asking about the best retro machine?
AJW
Post by AJW » Mon Jun 01, 2020 9:54 pm
Thanks. Would be nice to see RISC OS again but I expect there are huge incompatibility issues with earlier Arc /RPC software. presumably you'd need another emulator within RISC OS 5 to run the older games. I notice RISC OS still seems not to multi-thread.
sirbod
Post by sirbod » Tue Jun 02, 2020 4:25 pm
You could use emulation, but a better option would be to use ADFFS and download games JASPP has the rights to release via PackMan.
Update RISC OS on your Pi, as per the Pi requirements for ADFFS 2.72 and add the following URL to PackMan:
http://www.jaspp.org.uk/packages/release
Either manually extract and run ADFFS, or let PackMan download it when you install the first game - just make sure you run it before launching a game.
I'm probably somewhat biased, but I think games run more accurately on a Pi than on the original machines as timing and sample rate issues are no longer an issue and you can use USB Joysticks. All the games on the YouTube channel in my signature are running on a Pi with ADFFS.
AJW
Post by AJW » Wed Jun 03, 2020 1:26 pm
You're advising to get a Pi?
I tried RPCemu on Imac but didnt get far. Probably because the installation was confusing.
