Orion by Minerva software
subjects relating to classic games for the archimedes and risc pc
aerobaticant
Post by aerobaticant » Thu Mar 19, 2020 5:04 pm
Does anyone have a working ADF image of Orion by Minerva Software?
I'd like to have a reliable backup for use on my Gotek drive (FlashFloppy) with real Archimedes hardware.
Using Greaseweazle to image the disc and create an hfe file for FlashFloppy, the game still detects that it's not the original floppy and freezes, laughing, after a couple of minutes. :roll:
I have seen that a, presumably cracked, version is available legally on JASPP as a .jfd file, but not having ADFFS on my A310 I haven't been able to convert it.
Can anyone help?
Original Orion disc
sirbod
Re: Orion by Minerva software
Post by sirbod » Thu Mar 19, 2020 10:04 pm
Let's clear one point up straight away, the floppy images on JASPP are all digital copies of the originals with the protection intact and are unaltered in any way.
aerobaticant
Post by aerobaticant » Thu Mar 19, 2020 11:09 pm
OK, that's fair enough. I read a comment on another board that implied some images had protection removed.
My question still stands: has anyone made an image that will work from a Gotek with FlashFloppy?
aerobaticant
Post by aerobaticant » Fri Mar 20, 2020 1:20 pm
OK - I've now got a working solution!
I created an empty 800K floppy using HxC with the following settings, and then saved it as a .HFE image.
Then I used "Archive Disk Copier" on the Archimedes itself to do a sector copy of the original floppy to the Gotek using the .HFE image.
As the .ADF file can't properly have unformatted sectors it didn't work. The .HFE though, appears to be working:
Return to “32-bit acorn software: classic games”
