Upgrading RISC OS 3.70
Post by BeebMaster » Thu Feb 27, 2020 2:05 pm
I've decided to look into upgrading RISC OS in my RISC PC 700 (Strong Arm). Currently it has 3.70 in ROM.
All I want is the following, if possible:
1. Support for directories up to 255 files (for Econet compatibility)
2. Maybe support or just better support of larger hard discs. Currently I have a 40GB disc in there but although the files only count up to 490MB, 4GB is marked as used due to wastage.
I "think" RISC OS 4 onwards supports larger directories. What do I do to upgrade? Must I change the OS ROMs or can I download it from somewhere (pretty sure I am going to have to pay) and add it to my boot sequence. Can I even have a boot choice of OS version?
Re: Upgrading RISC OS 3.70
Post by danielj » Thu Feb 27, 2020 2:47 pm
To get the larger directories you need the 4.x ROMs with the new filecore. You can have bigger drives than 500mb on RO 3.7 though.
Post by BeebMaster » Thu Feb 27, 2020 3:04 pm
Is this what I need then:
http://www.riscos.com/shop/products/103/index.htm
Or physical ROMs?
geraldholdsworth
Post by geraldholdsworth » Thu Feb 27, 2020 3:42 pm
Try and get some physical RISC OS 4.39 ROMs. Or, RISC OS 5 does run on a RiscPC and there are physical ROMs of that available too.
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
Post by BeebMaster » Fri Feb 28, 2020 1:47 pm
Now where's some clever bod who can make a RISC OS multi-OS board when you need one ??
Post by danielj » Fri Feb 28, 2020 1:59 pm
You need the physical ones. 4.0x can softload 4.39. Don't bother with 5 on a Risc PC.
Post by BeebMaster » Fri Mar 13, 2020 10:23 am
Is anyone selling RISC OS 4.02 ROMs? Or am I allowed to make my own (assuming I can) from an official download?
egel
Post by egel » Fri Mar 13, 2020 10:38 am
sirbod
Post by sirbod » Fri Mar 13, 2020 9:15 pm
You don't need to upgrade to 4.x to achieve what you're after, you can backport FileCore to earlier OS. take a look this thread where I detailed how I run every OS version available for the RiscPC by using a small boot drive. I think I also posted everything you need to do it.
Post by BeebMaster » Sat Mar 14, 2020 10:37 am
Great, I'll take a look at that as soon as I can. I thought it might be possible to upgrade the modules in RISC OS to do what I want, even if I didn't say so out loud.
The main requirement is to have 255 (at least) files in an ADFS directory, so I can copy from Econet server without having to run RAFS or do it within the Level 4 server. I discovered the other day that the Advanced Level 4 server won't even extend beyond 77 files, so it's less advanced than Level 2!!!!!
Post by IanS » Sat Mar 14, 2020 1:22 pm
Even with this option?
Post by BeebMaster » Sat Mar 14, 2020 1:52 pm
Yep, just crashed the file server when it got to 77, did it repeatedly. There wasn't even a dir full error, just no response at all and eventually a No reply error on the user station. It could be a curiosity with the RISC PC and Advanced Level 4 I suppose, plus I'm using the Econet module podule which has a few hacks to the Econet firmware.
I've reverted(?) to the Level 4 server which doesn't have that configuration option, but extends by creating on the local file system a directory called " " (space) when there's only one entry left.
myelin
Post by myelin » Mon Mar 16, 2020 1:06 am
It's on the to-do list for Arcflash to support A7000/Risc PC; right now I have a working adapter board, and have managed to run RO3.5/RO3.6/RO3.7/RO4.02 off it in my Risc PC, although I haven't gotten the bootloader working.
