Combining sprites in RiscOS
Post by DutchAcorn » Sat Oct 13, 2018 11:18 am
Inspired by the ray traced spheres thread I took a look the animated ray traced spheres program my brother made in the late eighties on an A310. I found it and it works but it produces individual sprite files which can be shown using a separate play program. The play program however expects a single sprite file containing the individual sprites. It uses *SCHOOSE to select the correct screen dump.
I can't remember how to combine individual sprite files into a single file, and the user guide is not much help. Does anyone here know how to do that, preferably using the command line?
So I have 19 individual sprite files named SCR1 - SCR19 that I want to combine into a single "ALLSCREENS" file, using *SCHOOSE to select a sprite..
Re: Combining sprites in RiscOS
Post by IanS » Sat Oct 13, 2018 12:18 pm
Command-line, no idea.
Easy enough to do using the GUI, open one file, open another, then save the sprite from file 2 into file 1, using the menu, there is a "Sprite <x>"->Save option, drag the icon onto the first file (may need to ensure the sprite name, not the file name, is unique). You can the accumulate all the sprites within one container file.
Post by RobC » Sat Oct 13, 2018 1:31 pm
I think Ian's suggestion is the simplest but think you can merge sprites with the system sprite area by using *SMerge and then save out the whole area to a file with *SSave.
Post by DutchAcorn » Sat Oct 13, 2018 2:23 pm
Thanks guys, that really helped. The code I used:
 *SLOAD SCR1
 *SRENAME SCREENDUMP SCR1
 FOR N=2 TO 19
   OSCLI("SMERGE SCR")+STR$(N)
   OSCLI("SRENAME SCREENDUMP SCR")+STR$(N)
 NEXT
 *SSAVE ALLSCREENS
joachim
Post by joachim » Sat Oct 13, 2018 7:01 pm
Just in case anyone wants to construct a general solution, the sprite file format is (obliquely) documented in the PRMs at http://www.riscos.com/support/developer ... rites.html. (Note in "Technical Details", the sentence "The format of the file created by a *ScreenSave or *SSave command is the same as a sprite area, save that word 1 of the control block is not saved.")
This means that a sprite file is three 4-byte words of header, followed by blocks of sprite data. So to combine sprite files, just:
  • strip off the first 12 bytes of each file
  • concatenate the files
  • write a new 12-byte header on the beginning of the concatenated file,
where the header format is:
  • number of sprites (4 bytes)
  • header length (always 12) (4 bytes)
  • length of sprite file, including the 12-byte header (4 bytes).
