Impression Publisher Fonts "Out of Memory"
Post by danielj » Thu Apr 26, 2018 7:42 pm
I've got publisher 4.09 here (from wakefield) - which is SA compatible. Trying to install it on my 3.71 RPC which has 128mb, and it's screaming that it's out of memory everytime I try and use the font program to install the fonts...
Any ideas? :? Most odd...
flibble
Re: Impression Publisher Fonts "Out of Memory"
Post by flibble » Thu Apr 26, 2018 8:05 pm
Have you tried dragging the 'Font cache' slider higher in the task manager? (left click on the Acorn Icon).
Post by danielj » Thu Apr 26, 2018 8:23 pm
Yup - as high as it'll go.
Post by flaxcottage » Thu Apr 26, 2018 9:35 pm
Is your font folder full?
On RISCOS 3.1 there is a limit of 77 files per directory. How many in 3.7?
flibble
Post by flibble » Fri Apr 27, 2018 12:47 am
flaxcottage wrote:Is your font folder full?
Still 77
helpful
Post by helpful » Fri Apr 27, 2018 2:29 am
IIRC this was a number range bug in the installer that caused it to wrap if you had lots of memory. The counterintuitive solution was to reduce your free memory before running it!
RISC OS User Group Of London - http://www.rougol.jellybaby.net/
RISC OS London Show - http://www.riscoslondonshow.co.uk/
Post by danielj » Fri Apr 27, 2018 7:27 am
Brilliant :D :roll:
Ok - so if I just run !PC and give it a metric buttload of RAM, I might get some mileage there :) (unless there's an easier way of taking up memory?)
IanS
Post by IanS » Fri Apr 27, 2018 7:37 am
danielj wrote:Brilliant :D :roll:
Drag the "Next" bar in Task Manager, then start a task window.
Depends if it's seeing how much memory is free, or how much is fitted. You may have to try with a smaller memory stick installed.
Post by danielj » Fri Apr 27, 2018 7:47 am
Will have a twiddle - I think I've given away all my smaller memory sticks :?
Post by danielj » Fri Apr 27, 2018 5:42 pm
Well, that sorted it - once I got free memory down to 16mb! Crumbs, I'm assuming 128mb was ridiculous back when this was produced...
flibble
Post by flibble » Fri Apr 27, 2018 5:47 pm
Probably cost the same as a car :)
