Setting ARM status flags N and Z together
Related forum: adventures
Post by steve3000 »
My question: is there an ARM instruction (or series of instructions) which could be used to set N and set Z flags at the same time, without explicitly setting them both by modifying CPSR (or PC) directly?
I think the answer is no, but happy to be proved wrong :)
dp11
Re: Setting ARM status flags N and Z together
Post by dp11 »
It is impossible in ARM with out using CPSR ( or PC) , as there is no "minus zero" .
Post by steve3000 »
dp11 wrote:
Wed Sep 15, 2021 8:10 pm
Makes sense, just making sure I hadn't missed something obvious (or not) all these years...!
Rich Talbot-Watkins
Post by Rich Talbot-Watkins »
Same goes for 6502 I think - the two flags are mutually exclusive.
dp11
Post by dp11 »
Not quite, the 6502 BIT instruction can set both flags.
qUE
Post by qUE »
Just my opinion and not really helpful for answering this. I'd really try to avoid manually or logically setting custom states with processor flags, it's something I noticed RISC OS being burned badly by (the whole SWI internals exit point is a mess imo) and I think it gives minimal gain in processing. I took it onboard a long long time ago developing my OS when I discovered the difference in handling between the ARM2 and later variants, in my mind with technology moving like it does you'll quickly find yourself in a rut when moving to newer processors.
But then there maybe some unusual use case, but I can't think of it personally and everything can use an alternative/safer method.
Post by steve3000 »
dp11 wrote:
Fri Sep 17, 2021 10:53 am
I was reading some 6502 code and it was the BIT instruction which got me thinking about this for the ARM.
gfoot
Post by gfoot »
I guess PLP can set both flags too. But I think the equivalent on ARM requires superpowers?
dp11
Post by dp11 »
Yes PLP can but that depends on and previous BIT /PHP or push a special set of flags on to the stack. BIT and PLP make emulators just a bit more tricky.
