MEMC and first 512 KB
Related forum: adventures
ericde45
Post by ericde45 »
Hello,
i'm back with my stupid questions :)
for what i have understood, the first 512 KB are the only one reachable by VIDC/DMA and then, the video memory can only be located in the first 512 KB
does anyone know if this can be changed using MEMC parameters/registers ? something like bank switching on old Z80 computers using 128 KB ( Amstrad CPC memories :D )
Re: MEMC and first 512 KB
Post by IanS »
It's a limitation of the MEMC.
MEMC datasheet.
MEMC datasheet.
On the CPC, it relatively easy to modify the address bus before it's fed to the DRAM chips as the dram multiplexers are discrete parts on the PCB, with the multiplexors integrated into the MEMC it would be significantly more difficult to change this limitation.
ericde45
Post by ericde45 »
ok, thanks, the answer is clear :)
it is a very limitative feature, compared to ST or Amigas.
dp11
Post by dp11 »
Can't fix it now. Time to use another platform
gfoot
Post by gfoot »
I'm curious, why do you need the screen to be higher up in physical memory? What would it enable that you can't do already?
Post by steve3000 »
gfoot wrote:
Fri Sep 10, 2021 10:19 pm
I think the idea is to bank switch in a different 512kb…but sadly not possible :(
ericde45
Post by ericde45 »
512 KB is not enough if you want to do a 1 or 2 pixel 256 colors 9 directions scroller ( without copying the whole screen each vbl )
switching bank would have been a way to have more video memory.
for example the game 'enchanted lands' on ST is using so many video screens for its scroller that it does not switch/flip video screen, the sprites are vertically sorted, top sprites are drawn first to be displayed before the electron beam reach this part of the screen.
dp11
Post by dp11 »
Well you know which platform to use then.
ericde45
Post by ericde45 »
if the guy who made this game, enchanted lands, did so, he would have done it on Amiga, because if you read ST's hardware specs, you would say that it is not possible to do what he did :o
gfoot
Post by gfoot »
I'm not an expert on Arc graphics, but in a more general sense I don't see anything there that requires so much video memory. It looks like 320x240 or thereabouts, which is only about 64k per framebuffer. Even triple-buffering would only use about 200k. Just like on PCs well into the 90s, the main challenge is on the software side, writing the code to redraw the screen fast enough for your target frame rate.
Post by steve3000 »
ericde45 wrote:
Fri Sep 10, 2021 10:46 pm
You can hardware scroll left/right with 2 pixel accuracy in 256 colour screen modes on the VIDC (by adjusting border size and screen start position registers :wink:). So you can keep two copies of the screen, with one shifted by a single pixel, to get 1 pixel accuracy in scrolling. So a full multidirectional scroller should fit in 512kb, unless you're going for a very large overscan screen size?
ericde45
Post by ericde45 »
4 screens * 2 to flip * 320*256 = 655 360
i think i need 4 screens to do an unlimited 9 directions scroller.
IanJeffray
Post by IanJeffray »
ericde45 wrote:
Mon Sep 13, 2021 8:15 pm
I can't see how it's useful having all those buffers, but assuming you do for whatever reason, why not just run say 320x200 ? That'd fit.
Even if you had 4 prepared buffers at 320x256, copying one of them to a single shared backbuffer at 50Hz is only 8MB/sec... and VIDC will steal half of that again, leaving you a nominal 13MB/sec (~50%) theoretical bus available even on the lowliest 8MHz-bus Arc. I've long forgotten how long it takes ARM2 to copy 4MB though and I suspect someone will tell me I'm wrong with these figures too...
gfoot
Post by gfoot »
I'll be interested to hear from the experts, but I've done the maths on this before for my own non-Arc ARM2 computer, and for copy operations I think it came to just lower than the double clock rate, in bytes per second. i.e. 8MHz clock => 16MB/s maximum copy rate. We can nearly read or write 4 bytes per clock cycle, so transfer 4 bytes every 2 clock cycles, ignoring some overheads. The overheads depend on how you write the code, but my example lost around 10% of cycles to instruction fetches, loop statements, etc. So for a large block copy operation on an 8MHz machine I'd expect about 14MB/s I think.
I'd love to hear if it's possible to do better though!
The thing I don't understand about the original request is why so much buffer space is required. The game that was linked made heavy use of parallax, and the only way I know to do that - without hardware assists - is to refill the screen from scratch every frame. Hardware scrolling won't help. So like in the early PC graphics days, you need to write smart code to fill the screen efficiently, and maybe target 25Hz instead of 50Hz to get more time to spend on things other than redrawing the screen.
ericde45
Post by ericde45 »
the best way to make a scrolling is to only copy the new tiles, and move the video pointer.
any other way leads to 2 frames or more animation once you add sprites.
ericde45
Post by ericde45 »
enchanted lands does parallax in the title screen and no parallax in game...
gfoot
Post by gfoot »
Ah ok fair enough, I must have only watched the title screen in the video. If the Arc supports some form of wrapping at a configurable maximum address then you'd still only need two single-screen buffers I think. It depends though.
Post by Rich Talbot-Watkins »
Surely you only need 4 banks - two at each pixel offset so that you can double buffer. An R-Type style game which horizontally scrolled continuously would only need 2 banks!
ericde45
Post by ericde45 »
but if i want to do all directions, up down left right i would need 4 screens using video pointer modification
but as you all directly went to copy the whole screen, i made some tests and on a 12 mhz Archimedes, copying the whole screen using ldmia/stmia, with repetead instructions and short loops, seems fine and not taking that much cpu time
for 200 lignes, 256 colors, 416 pixels wide, going from clearing with zero to clearing with a background adds 16 to 20 scan lines. that's very few.
advices above about fast memory copy were completly right !
gfoot
Post by gfoot »
I did some reading on the MEMC video DMA interface, and it sounds like it should support wrapping well enough to not need more buffers for more directions of scrolling. You specify an initial address (top left of the visible screen) and a start and end of video memory address. So you can scroll in any direction by changing that initial address, without changing the other two addresses at all, and redrawing the region that scrolls on, whether it's a vertical strip or a horizontal strip. At the MEMC level this is only with 16-pixel granularity, but I believe you then layer on other techniques at the VIDC level to get finer-grained horizontal scrolling.
Then to prevent the user seeing what's going on, you just need two of these buffers which you use alternately, updating one while you display the other.
Something else I saw in the datasheet is that it prevents the CPU from running more than 3 S-cycles in a row, to avoid starving the video DMA stream, and also pauses the CPU when necessary for video DMA. I think this means that large LMDIA/STMIAs will take a little longer in real-world time than you might expect based purely on the cycle counts and nominal clock frequency. My experience so far is only with ARM2, not the wider Archimedes architecture, so it's hard for me to extrapolate this.
ericde45 wrote:
Tue Sep 14, 2021 10:02 am
Yes, 4 screens - this is what I was saying (you were suggesting 8 earlier on). The only thing you would need to do is to update the strips of new screen in all 4 buffers each time you scroll. Obviously, hardware scrolling would gradually move all the boundaries as new strips would overwrite the beginning/end of adjacent buffers. I think you'd need to leave a small gap between each one.
gfoot wrote:
Tue Sep 14, 2021 11:17 am
Can you specify an end address? I thought the end address was basically fixed (although you could specify a "restart" address). If so, that probably makes life even easier.
ericde45
Post by ericde45 »
yes you can specify an end address but before setting the start address, and before display using this start address is started
