ArmBoot (for fileservers)
philpem
Post by philpem » Tue Aug 13, 2019 2:54 am
I've been having a play around with aund recently.
When I mount the fileserver and log in, the RISC OS machine goes hunting for a file called !ArmBoot. I get the impression it's a variant of the normal boot structure.
Where might I find a copy of this? I didn't see it in the L4FS archive, but it's mentioned in the Acorn networking application notes.
Re: ArmBoot (for fileservers)
Post by flaxcottage » Tue Aug 13, 2019 8:51 am
When logging on to an Econet system using Shift-Break a default user called Boot is started. If the autoboot feature is set the OS looks for a file called !BOOT in 8-bit machines and a file called !ARMboot in 32-bit machines.
These files may be RUN or EXECed depending on the boot option set and are used to set up the machine to work on the Econet.
BITD I used these files to start BBCs and Archimedes connected to our Econet to load the default log in wrapper. From there one could log in or run the CAL software without having a personal user name. One ran the CAL menu system as the public user BOOT. The log in wrapper was different for the different machines.
Post by jgharston » Tue Aug 13, 2019 9:48 am
It's a varient of a normal network !Boot, not a system boot structure, controlled by the normal *OPT4. If you don't want !Boot/!ArmBoot looked for, turn it off with *OPT4,0.
For example, my !ArmBoot contains:
Run %.!ArmBoot
net:Disable Library
net:Prot
And :System.ArthurbLib.!ArmBoot contains:
SyncTime
GetStnNum
IfThere &.!Choices Then /&.!Choices Else /net::System.Boot.!Choices Off
IfThere Choices:Logon.!Run Then /Choices:Logon.!Run
philpem
Post by philpem » Tue Aug 13, 2019 5:44 pm
Ahh -- it seems I've been led on a wild goose chase then! Figure 8 on page 11 of Application note 251 (http://chrisacorns.computinghistory.org ... AN/251.pdf) shows a "boot" icon for the !ArmBoot entry, so I figured it was an application.
Thanks for setting the record straight :)
I think one of this week's experiments might be to try and get a RISC PC to netboot without a hard drive. Sadly neither of my other two Acorn machines (an A3000 and an A3010) have any form of network support.
AN228 looks like a good read too, for anyone thinking of setting up an AUN network: http://chrisacorns.computinghistory.org ... AN/228.pdf
I might have to have a play with ShareFS/Access+ too, via David Boddie's "AccessPlusPython" (https://bitbucket.org/dboddie/accessplu ... c/default/)
Post by davidb » Tue Aug 13, 2019 8:57 pm
You should try James Woodcock's fork because he has improved it and made it more robust.
I looked at network booting briefly many years ago but the address order of Access/AUN seemed to be the opposite of conventional IP addresses and I didn't want to deal with that at the time.
Post by flaxcottage » Tue Aug 13, 2019 9:00 pm
The A3000 is great on Econet. The interface is a simple plug-in board - always assuming you can find one at a sensible price, that is.
The A3010 cannot normally have an Econet interface. I say 'normally' because there will be someone here who has connected an A3010 to an Econet or is currently working on doing so. :wink:
philpem
Post by philpem » Wed Aug 14, 2019 2:49 am
Ah, you mean this? https://bitbucket.org/mjwoodcock/access ... c/default/
I'll give that a shot - thanks!
Aye a chap called "MarkYoungIW" pulled it off back in 2012 -- https://groups.google.com/forum/#!topic ... %5B1-25%5D
From a quick skim, it looks like he grafted an Econet interface board onto a HCCS Ultimate and patched the Econet module to access the mini-Podule address. Not bad!
I wonder if there's a way to decode another chip-select or Podule-select out of the address bus (or steal one from the ARM250) and do something like a Raspberry Pi SHIM with an ADLC chip onboard.
Post by davidb » Wed Aug 14, 2019 8:49 pm
That's the one, I think. James is a member of the RISC OS Open forum so you can get in touch with him there if you need to.
cmj6502
Post by cmj6502 » Fri Aug 16, 2019 4:47 am
It can be either, the same as normal !boot can be a file or an application.
That’s with the “run” option anyway. I guess you can’t *exec an application!
