ABUG EAST MIDLANDS (Leicester) 9-11 November 2018 - BOOKING NOW on THIS THREAD
threads for previous physical ABug events
Re: ABUG EAST MIDLANDS (Leicester) 9-11 November 2018 - BOOKING NOW on THIS THREAD
Post by jgharston » Fri Nov 09, 2018 11:54 am
I'm going to have a cup of tea, then will be setting off.
Post by Prime » Fri Nov 09, 2018 1:07 pm
Just about to leave Coventry see you all in an hour or so......
Phill
Post by 1024MAK » Fri Nov 09, 2018 7:37 pm
The larger room is filling up nicely :D
Post by paulv » Sat Nov 10, 2018 9:17 am
Just loading the car. Should be there around 10.
zolbatar
Post by zolbatar » Sat Nov 10, 2018 10:18 am
I was considering popping down but as I haven't booked a table and relatively new (back) to the Acorn world would it be worth the drive?
I have a Master 128, poorly A4000 and have been doing some coding on my RISC OS Pi.
Master 128 with DataCentre and RPi co-pro.
RPi B+ & 3B+ both running RISC OS.
Poorly A4000 (battery damage, partially repaired).
Post by 1024MAK » Sat Nov 10, 2018 12:16 pm
Come on down and say hello, we will make a space for you :wink:
Don’t forget to bring the entry fee (see first post).
Also you will need a mains extension lead.
Post by 1024MAK » Sat Nov 10, 2018 2:25 pm
Three more photos:
Dave H. working on Elk expansions.
Jonathan working away.
trixster
Post by trixster » Sat Nov 10, 2018 4:42 pm
Can you summarise what’s being worked on I these photos, Mark? And by whom?
Post by CMcDougall » Sat Nov 10, 2018 6:28 pm
1) DaveH fixing a elk AP4 or 5 8)
2) JonathanH wishing he had a electron #-o
3) Cup of tea =D> wanting to buy a beeb to fix!
Post by 1024MAK » Sat Nov 10, 2018 7:37 pm
More...
The main room
Is this the next step after wireless?
Ooh, something interesting going on at the other end... (see later)
Chris’s table
Cake (well what there is after most have had their fill!)
Ian’s table. I think he is working on IDE boards.
Dave’s table. He is working on his new IDE boards
What everyone was rushing to see...
Chris’s Beeb running a BASIC rendering program in a speed test with Sarah’s Arc. The Beeb lost.
The fastest Elk?
Yes that is an ARM co-pro.
Notice the different firmware versions.
Inside with the top memory board removed, showing the processor
Post by BigEd » Sat Nov 10, 2018 7:43 pm
Oh, hang on, who's hooked up a 32016 second processor to an Electron? We need to know more about that!
Post by 1024MAK » Sat Nov 10, 2018 8:00 pm
Please note that I’m adding the comments when I can.
Things that missed the glaze of the camera:
John’s issue 3 Beeb going slow when running some software (reason unknown).
Phill repairing Richard’s Atom.
Chris showing his Bad Apple animation with a sound track on a BBC B via a CRT display. You can however see his You Tube Video here (although it looks better on a CRT).
Post by flaxcottage » Sat Nov 10, 2018 10:21 pm
Yes the Beeb is an issue 3 motherboard. When it boots the tape motor light is permanently on. It was to be upgraded with two of Chris Morley's SWR boards and an EEPROM board. All appeared to be working perfectly except for Interword and the Basic Editor version 1.32.
The Interword issue was solved by moving the SWR to different sockets.
The Basic Editor problem was vexing. The program worked properly when loaded into SWR, any SWR slot. When it was loaded into EEPROM it worked very slowly and then the whole machine slowed down, this behaviour even surviving a Ctrl-Break. Changing the ROM sockets in which the board was placed made no difference. Changing the EEPROM board and SWR boards made no difference.
Moving the EEPROM board which was running slowly in my BBC to another BBC showed the Basic Editor working properly.
Conclusion - the SWR and EEPROM boards are working properly. The issue 3 motherboard is the issue. That is not too worrying as I have a working issue 4 motherboard spare. I'll just swap the motherboards and use the issue 3 for spares. I know that sounds like sacrilege but that is why I had the issue 4 board in the first place. :?
Post by 1024MAK » Sat Nov 10, 2018 10:22 pm
And some more...
An Acorn Pocket Book II trying to connect via via an acoustic coupler held to a mobile phone!
A 6502 badge made from a kit of parts by me.
And yes it can run a version of BASIC, it just needs a serial terminal.
Me building an AP6 (previously supplied by Dave H.).
Post by tricky » Sun Nov 11, 2018 8:33 am
My atom lives with ramrom and mmc. Flappy birds crashes if you make it through the first obstacle. There were a couple of games that were crashing: tetris and w.a.r. but they were fixed by an mmc rom update.
Post by BigEd » Sun Nov 11, 2018 9:17 am
Thanks for the captioning Mark! Much appreciated. I know from experience it's extra work. And of course thanks for the photos.
If you know whose Elk that was, whose ARM copro, and whose 32016 copro, I'd very much like to know! (If you can get a close snap of the 32016 top label, and even the insides, that would be most excellent.)
Ed
Post by hoglet » Sun Nov 11, 2018 9:34 am
Hi Ed,
We have all the components locally here to replicate the 32016 configuration:
- An Electron with Plus One
- An AP5 interface
- ADFS 1.03
- A Beeb SCSI with the Panos Image
- A original 32016 Co Pro
I had this setup running briefly last year for AP5 testing, but with a PiTubeDirect 32016 rather than the real one.
jms2
Post by jms2 » Sun Nov 11, 2018 10:01 am
I tried the same setup on my Elk (ie, the PiTube version). I think it worked ok but I can't quite remember (it certainly worked on the Master and that is clouding my memory) - was it necessary to do anything non-obvious to make it work on the Elk?
Post by BigEd » Sun Nov 11, 2018 10:20 am
(Good point Dave, our own mini-ABUG but without the cluster of appreciative onlookers! I was idly wondering how many 32016 second processors are out there, and who has them, and what their configurations might be.)
Post by 1024MAK » Sun Nov 11, 2018 12:29 pm
Ed, it’s Mark Andrew Smith‘s kit (he lives on the Facebook group).
Post by 1024MAK » Sun Nov 11, 2018 12:44 pm
It’s Sunday morning and busy again - well, some of the photos were taken in the morning!
The main room is still busy :-)
Richard running his Scramble game (modern camera defeated by a CRT, so sorry about the colours being washed out)
Jonathan busy coding.
Good to see Paul at an ABUG. He’s busy producing his video boards for Arcs.
A partly built board that I’m working on (I blame Duncan for getting me interested in RC2014...)
guddler
Post by guddler » Sun Nov 11, 2018 1:16 pm
@Tricky - is the corruption at the bottom of scramble on the agenda for the weekend? Would be great to get that sorted :D
Post by Prime » Sun Nov 11, 2018 3:40 pm
Annnnd home again.
Good weekend as always, and good to see you all again, look forward to the next one.
Post by flaxcottage » Sun Nov 11, 2018 4:41 pm
Yes, this was a great meeting. I loved the Vixen beer. :lol:
Thanks to Alex for organising it. =D> =D> =D>
Managed to get my Beeb working with Chris's Boobip gizmos. I shoved in a new Issue 4 motherboard (well not new but you know what I mean). The board looks for all the world like a model A that has been upgraded to model B standard.
It did not have a disc interface fitted so, after checking that the EEPROM board worked and the SWR boards, the first job was to swap the 8271 DFS interface from the faulty Issue 3 board. I forgot to open S9 :oops: :oops:
Once S9 was open everything worked properly. Even the disk drive worked faster. :D
The faulty Issue 3 I shall now use as a potential donor should I need any chips from it. I have another Issue 3 bare board which is missing several chips. Maybe I can rescue that.
I was so pleased with the 'repair' that I even added Kenneth Kendall so the Beeb can talk to me. :lol: :lol:
Post by 1024MAK » Sun Nov 11, 2018 5:44 pm
Ahh, back home now :D
Thanks as always to Alex for all the arrangements :D =D>
Also, thanks again to Alex for the free gifts 8) =D>
And thank you to everyone who attended =D>
Sorry Ed
He did not bring his 32016 co-pro into the room today. I would have asked, but by the time I had a chance, Mark was packing up to go home :(
Post by BigEd » Sun Nov 11, 2018 5:59 pm
No probs. Evidently a very good event and that's the main thing.
mattyj
Post by mattyj » Sun Nov 11, 2018 8:09 pm
Back home in Bristol, brilliant weekend! Thanks for organising Alex!
Now on with the new workshop!
See you all next time 😀
Matt
Post by tricky » Sun Nov 11, 2018 10:00 pm
I forgot to take the scramble source and to be honest, until I was talking about it on Sunday, I had forgotten about it. It is a simple fix, I just keep forgetting to do it!
pau1ie
Post by pau1ie » Sun Nov 11, 2018 10:02 pm
Im back home too. I made a start on putting in the meanwell power supply but messed up the disc drive power socket. I ordered some terminals but am without a bbc till they arrive, which is sad.
I did some work on vi65 which is taking shape. Made good progress Saturday, but less today.
It feel I made a social faux pas at dinner on Sunday by inaadvertantly being the only person at our table not called Mark!
It was great to meet everyone and see what you are all working on. Chris' Bad Apple was amazing. I really wouldn't have believed it possible! Thanks also to everyone for the advice and help - especially Phil for the phone charger!
Thanks Alex for organising the event.
Return to “past physical ABug events”
