E00 DFS for 8271 / 1770 controllers
KenLowe
Post by KenLowe » Tue Sep 17, 2019 10:31 am
Does such a thing exist for the standard Acorn supplied 8271 / 1770 based controllers installed in a model B? Similar to the SWMMFS image?
Pernod
Re: E00 DFS for 8271 / 1770 controllers
Post by Pernod » Tue Sep 17, 2019 10:47 am
For the 8271 there's the MRM E00 DFS, see viewtopic.php?f=4&t=11633&p=224870#p224870.
KenLowe
Post by KenLowe » Tue Sep 17, 2019 10:55 am
Thanks for that info. Do you know if that DFS runs in a standard SWRam bank, or does it rely on its own special private RAM that gets switched in and out by the DFS?
Edit: https://acorn.huininga.nl/pub/unsorted/ ... Guide.html seems to suggest that it can run in a SWRam bank, but I'm still not sure if it needs any further private RAM to work correctly.
Pernod
Post by Pernod » Tue Sep 17, 2019 11:13 am
It's an 8K ROM with 2K RAM mapped above the ROM in the same bank, so should just work from SWR. Attached the ROM for you to try. There was also the STL E00 from Solidisk which was intended for SWR.
mrme00.zip
(6.32 KiB) Downloaded 21 times
KenLowe
Post by KenLowe » Tue Sep 17, 2019 11:28 am
Thanks for that. I'll try it out this evening.
This has got me thinking / wondering if I could perhaps adapt one of the PALPROM based board designs, and use a 32k FRAM to store a modified 8271 DFS / 1770 DFS / DNFS / NFS / ADFS on one of the 16k banks, and use the other bank for workspace. The FRAM would (hopefully) get over the issue of needing an active filing system to load the code into the RAM each time the Beeb is powered up. However, corruption on power cycle may be an issue, so a mixed EPROM / RAM solution may be more appropriate.
Post by CMcDougall » Wed Sep 18, 2019 9:35 pm
I have this :
acpE00 DFSram.rom
rom image
(12.12 KiB) Downloaded 17 times
it's got "Rob Northen" on end, and "DFS1.00(C)1986 ACP LTD" at start
scrn
now I did try this on a actual beeb, but can't mind if it was 1770 or 8271 :?
it worked a little, but then ended up like Solidisk giving Disc Errs, which there was not! :x
Post by CMcDougall » Wed Sep 18, 2019 9:45 pm
here is the buggy Solidisk versions, again always give Disc Errs which is false!
ddfs E00
dfs e
STL0E00.rom
rom image
(8 KiB) Downloaded 17 times
DDFSE00.rom
rom image
(8.25 KiB) Downloaded 16 times
duikkie
Post by duikkie » Thu Sep 19, 2019 7:01 am
the problem i allways have with dfs rom that work on &e00 is not the rom itself
but the software around it
if you make software for a program that use this sort of dfs , it will not work on standaard beeb with normal dfs
it was beter that acorn in 1983 ? did somethink else then raising the page to =&1900 :)
the trick was downloading &e00 software and turn of the dfs.
but yeah 16k was so big in 1980 , that there was not thinkeble there was ram too short :)
but then there game GAMES and trouble :)
KenLowe
Post by KenLowe » Thu Sep 19, 2019 7:37 am
Thank you for the replies. I'll try out the various DFSs at the weekend, when I get a bit more time. I assume the Solidisk and ACP versions are similar to the MRM version, and are using RAM that is directly mapped into a section of its own SWR bank?
Post by sweh » Thu Sep 19, 2019 3:03 pm
Solidisk one, definitely. It's an 8K ROM so I stuck it on the second half of Exmon (which was also 8K) and added a "*E00" command. That would cause the image to get copied to a SWRam bank where it ran happily. Meant I didn't need to *SRLOAD it from disk when I needed E00 :-)
I had two games disks which needed E00 DFS to work properly (eg to save game state). Worked fine for decades (literally) with my STL1770 FDC.
