INPUT Magazine Listing / Electron Error ?
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 8:46 pm
Hey guys,
I'm trying to learn Acorn Basic on an Electron and have typed in some programs from the 1st Issue of INPUT Magazine. However i get errors and funny shit happening. I've identified some typing errors but am currently getting error " at line 110" there seems to be a space at the start of the error but no actual word so the error seems incomplete. Can anyone elaborate on this error ?
Re: INPUT Magazine Listing / Electron Error ?
Post by CMcDougall » Sun May 12, 2019 8:50 pm
INPUT Magazine was not the best BITD, always full of errs :roll:
plus it was more for the beeb, NOT the elk, as no Mode7
try The Micro User !
or in your case, Electron User!!
Post by flaxcottage » Sun May 12, 2019 8:52 pm
Can you list lines 80 to 110?
We might be able to spot something from the listing.
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 9:12 pm
I can do better than that :)
Follow this link :- https://archive.org/details/Input_Vol_1 ... B/page/n13
Then look at pages 11 and 12. I'm trying to define a tank. The magazine format means lines are not typed in all at once in sequence but are dealt with section at a time explaining what they do so line 110 is not entered until page 12
0xC0DE
Post by 0xC0DE » Sun May 12, 2019 9:38 pm
Have you been using $0A00 instead of $0E00 throughout the entire program?
0xC0DE
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 9:40 pm
I will but I bought all the input magazines as a kid or first half of them before I even got my first Computer which was an MSX. Which isnt covered by the magazine. So I've held on to them all this time and only got my first Electron a few months ago as i want to learn basic. I could not find any resources for the MSX back in the 80's that really taught the MSX Basic. Oh well ! I will look for the Electron User mags though. Thanks
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 9:44 pm
Im not sure i see that in the listing. I don't have disk drive so stuck with &D00 in preference to &A00 which is for the disk drive ?
0xC0DE
Post by 0xC0DE » Sun May 12, 2019 9:52 pm
The error is almost certainly generated by the CALL &D00 at line 110. It would greatly help if you could paste your actual listing here (not from the magazine but the one you've typed in so far). Even a screenshot of your listing if you don't have a way of easily transferring it out of your Electron :mrgreen:
0xC0DE
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 10:22 pm
Hi, Im not sure if this will work but ive uploaded a photo to Photobucket ! On a side note can anyone recommend a good image hosting service thats free and fast. Photobucket used to be quite good but its currently NFFP Not Fit For Purpose and i need something thats fast and simple as i dont have time to waste and its a complete faf. Anyway the immage is here :-
https://i265.photobucket.com/albums/ii2 ... M_3472.jpg
0xC0DE
Post by 0xC0DE » Sun May 12, 2019 10:37 pm
Is the FramePrint routine loaded and active at address &D00? Otherwise CALL &D00 will definitely not work.
0xC0DE
SimonSideburns
Post by SimonSideburns » Sun May 12, 2019 10:58 pm
You can add pictures to posts in this forum. Ok, they may be size restricted, but a simple resize should be fine for all but the smallest text.
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 10:59 pm
I may be having some issue there ! I've tried saving the frameprint routine and loading it but got bad program error. I've retyped it and changed the filename from FramePrint to MACHCODE as Im guessing that there is a limit on the number of characters you can use in a file name ? Please confirm !
I've saved the MACHCODE on a new tape using the command *SAVE"MACHCODE"0D00+59. This seemed to save it correctly and i then loaded what i call TANKFROG into memory and run it. It seemed to run but displayed only a blank screen and on pressing any of the move keys it crashes. When i run it again i then get the error "at line 110"
Grrr.
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 11:02 pm
Where do i do that ?
SimonSideburns
Post by SimonSideburns » Sun May 12, 2019 11:03 pm
The Attachments area below the text entry area, then you can place them inline into the post at the current cursor position.
SimonSideburns
Post by SimonSideburns » Sun May 12, 2019 11:05 pm
Like this:
BeebMan2018
Post by BeebMan2018 » Sun May 12, 2019 11:10 pm
Like this:
Cool Thx
0xC0DE
Post by 0xC0DE » Mon May 13, 2019 10:54 am
Grrr.
Filename doesn't matter. As long as the machine code part is loaded at &D00 when running the main program.
After *LOAD "MACHCODE" D00, what does the following litte program show on your screen? (screenshot please)
10@%=&020203
20FOR B=0 TO &72
30PRINT ~B":"~B?&D00",";
40NEXT B
0xC0DE
Elk Towers
Post by Elk Towers » Mon May 13, 2019 6:42 pm
do you have a plus 1 attached, if you do Page &d00 is the extended vector area for the plus 1.
try relocating/re compiling the machine code to reside at a different location, obviously changing any "call &d00" to whatever place you put the machine code
Nick
BeebMan2018
Post by BeebMan2018 » Mon May 13, 2019 6:57 pm
Grrr.
10@%=&020203
20FOR B=0 TO &72
40NEXT B
Any idea why when i try to load this program i get the error Bad Program ?
0xC0DE
Post by 0xC0DE » Mon May 13, 2019 6:59 pm
No. It shouldn't. Even after a clean startup of your Electron?
0xC0DE
alex_farlie
Post by alex_farlie » Mon May 13, 2019 8:34 pm
Are you sure the machine code portion is entered correctly? When I keyed it in manually in IDA to see what it was doing , I made a number of typo/confusions between HEX and decimal input modes.. :lol:
The machine code once entered properly should work without concern.
Someone else here will probably eventually post a version that's the full assembler source derived.
0xC0DE
Post by 0xC0DE » Mon May 13, 2019 9:10 pm
This is not true. The machine code as typed in from the magazine seems to make sense. No error occurs when I CALL &D00.
This is what the code looks like after disassembling:
oswrch  = $FFEE
        org     $0D00
        CLC
        LDA     #$E0
        DEX
        BMI     L0D35
        BEQ     L0D0F
        DEX
        BEQ     L0D0D
        ADC     #$09
.L0D0D
        ADC     #$09
.L0D0F
        LDX     #$03
.L0D11
        LDY     #$03
.L0D13
        JSR     oswrch
        CLC
        ADC     #$01
        DEY
        BNE     L0D13
        DEX
        BEQ     L0D34
        PHA
        LDA     #$0A
        JSR     oswrch
        LDA     #$08
        JSR     oswrch
        JSR     oswrch
        JSR     oswrch
        PLA
        JMP     L0D11
.L0D34
        RTS
.L0D35
        LDA     #$20
        LDX     #$03
.L0D39
        LDY     #$03
.L0D3B
        JSR     oswrch
        DEY
        BNE     L0D3B
        DEX
        BEQ     L0D34
        LDA     #$0A
        JSR     oswrch
        LDA     #$08
        JSR     oswrch
        JSR     oswrch
        JSR     oswrch
        LDA     #$20
        JMP     L0D39
In other words, if you haven't made any typing errors then at least the machine code part should work.
And if you inspect the bytes from &D00 in memory (with the little program I gave earlier) its contents should look like this:
Example on my Electron (emulator):
0xC0DE
alex_farlie
Post by alex_farlie » Mon May 13, 2019 9:20 pm
Seems I'd made some typos as well, post amended.
BeebMan2018
Post by BeebMan2018 » Tue May 14, 2019 10:21 am
OK GUYS,
As requested a screenshot of my "MachCode" Listing. I couldn't get it to load so i've typed it in again this morning. I have a few query's.
In line 10 we specify T as &D00 to &D58 In line 40 though we say &D00+59 which is 1 higher than the range we specified in line 10 ?
should there be a question mark before ?T=A in line 20.
In the DATA there appears &D0 appears two times. Should this be the case when everything else is in numbers ? I'm just relearning Machine code and vaguely remember hexadecimal so expect its fine. Just asking.
0xC0DE
Post by 0xC0DE » Tue May 14, 2019 12:32 pm
Before I can help you any further... please compare the output of this little program on your Electron
10@%=&020203
20FOR B=0 TO &72
40NEXT B
with this screenshot from my Electron emulator
They should be the same. Which then means your machine code routine at &D00 will be correct.
0xC0DE
BeebMan2018
Post by BeebMan2018 » Tue May 14, 2019 1:49 pm
10@%=&020203
20FOR B=0 TO &72
40NEXT B
Hi :)
OK sorry but im a novice. Do i have to load the MachCode program first and then type in your program and run it ? My electron is upstairs in the back room and my pc is downstairs in the living room as i can get internet there. Makes the whole process a bit awkward ! Will try to load the MachCode program i typed this morning and then enter your little program to see what happens in the meantime while i wait for your reply. Thanks for your help BTW. Its awesome we can still get support for a machine thats what ? 35 years old ?
BeebMan2018
Post by BeebMan2018 » Tue May 14, 2019 2:04 pm
OK Whatever i was thinking didn't work so i reset the Electron and typed your program in and got this :
Could you explain what we just did please ?
BeebMan2018
Post by BeebMan2018 » Tue May 14, 2019 2:09 pm
OK I spotted my Typo :
BeebMan2018
Post by BeebMan2018 » Tue May 14, 2019 2:12 pm
NEW OUTPUT
:/ Have i done something wrong or is my Electron Faulty ?
0xC0DE
Post by 0xC0DE » Tue May 14, 2019 2:16 pm
I always welcome new users of the Electron :mrgreen: =D> =D>
OK, step by step instructions.
First, load this BASIC program from your tape:
Then RUN it. This will do 2 things. 1, create a small machine code routine at address &D00, and 2, *SAVE that routine to tape. I noticed you have saved both programs as "MachCode" on your tape which should not be confused! One is the BASIC program mentioned above. The other is the little machine code routine to be loaded at address &D00. Two completely different programs!
Next, do NOT restart the Electron or even press BREAK. Just type NEW to start a new BASIC program. And then type in my little test program:
10@%=&020203
20FOR B=0 TO &72
40NEXT B
Save it to tape if you want. Then RUN it. This should PRINT the following numbers on your screen:
It shows the machine code routine at &D00 in hexadecimal numbers.
Please post a screenshot of what your screen looks like after all these steps.
So we can confirm that your machine code at &D00 is indeed correct.
0xC0DE
