ROM image disassembly (not on a Beeb).
stephen_usher
Post by stephen_usher » Fri May 10, 2019 6:24 pm
I've a BBC ROM containing software I'd like to archive (the University College London terminal emulator). I know it's got a little corruption as the machine just hangs when you type *TERM but I'd like to try to discover the damage, hopefully fix it and then create a new image.
I've now got an EEPROM programmer which should be able to read the contents onto a Windows machine so what I need to do is find some software which will take the ROM image, decode it and try to disassemble the program, preferably generating labels. This may at least show me where the damage might be and maybe, possibly even allow me to detemine what the data should be.
So, basically the question is, does anyone know of any software on Windows, Linux or MacOS which can read a BBC ROM image, interpret it and disassemble the code?
0xC0DE
Re: ROM image disassembly (not on a Beeb).
Post by 0xC0DE » Fri May 10, 2019 7:13 pm
I use BeebDis https://github.com/prime6809/BeebDis. An emulator with a debugger built in might help also.
Some people here have used Ghidra https://ghidra-sre.org/. I have no experience with that yet.
Other useful support tools: a Hex editor like HxD https://mh-nexus.de/en/hxd/.
Old but still useful: dis6502 https://www.atarimax.com/dis6502/
Perhaps a little warning in advance: disassembly takes a lot of effort even with excellent tools like this.
Good luck! :D
0xC0DE
Post by BigEd » Fri May 10, 2019 7:16 pm
Might be worth trying WFDis:
https://www.white-flame.com/wfdis/
tautology
Post by tautology » Fri May 10, 2019 7:42 pm
Ghidra's good (used it in anger a couple of times) with one main problem: it tries to guess the value of X or Y when used in indexed or indirect mode an places the label there.
This makes some loops get the label in the wrong place.
Post by jgharston » Fri May 10, 2019 7:50 pm
If you have BBC BASIC for (insert platform here), then my Disassembly suite, which include MkSrc* programs that scan for and generate labels.
http://mdfs.net/Software/Assembler/
stephen_usher
Post by stephen_usher » Fri May 10, 2019 8:13 pm
The documentation for BeebDis is awful isn't it? It's seemingly written from the point of view of someone who already has in depth knowledge of how the thing works. It mentions being able to create a file containing definitions of things such as OSBYTE but then fails to tell you how or what it should be called.
Reading the source doesn't help as it's in Pascal with almost zero comments.
If it had that information in the documentation it seems that it would be an excellent utility.
Post by hoglet » Fri May 10, 2019 8:31 pm
There's a example here - look at the .sym file.
https://github.com/hoglet67/BBCBasic4r3 ... isassembly
stephen_usher
Post by stephen_usher » Fri May 10, 2019 9:35 pm
Excellent. Thank-you.
Post by Elminster » Fri May 10, 2019 10:22 pm
Prime is the author of beebdis and is on this board so you could always ask him so do a beginners guide, or some extra help.
Post by Prime » Sat May 11, 2019 4:25 pm
That's exactly how it's written, BeebDis started out as a tool for me and I wrote the docs as I went along mostly as a mnemonic for me. This is the reason I had someone else write the documentation for the DragonMMC board, I wanted it to explain things from the point of view of someone not involved with the creation of the code / device. Alas I can't do that for every project.....
Depending on how old the documentation you have is, it is there, use the SYMBOLS keyword followed by the symbols filename in the control file.
Which is miles better than some of the uncommented 'C' I've seen over the years, I try to make the code easy enough to follow e.g. meaningful variable names, good code layout, and spacing (the one everyone always forgets). But I guess that doesn't help much if you are not familliar with Pascal :)
Glad you think so, thanks :)
Anyway the critisizims of the documentation are in places valid, I have just pushed an updated version that should help clear things up a little, e.g. describing the format of the control file. Perhaps I should include a couple of example disassembilies to illustrate the use. Also if anyone wants to have a crack at updating / making the docs more 'user friendly' feel free, I'm willing to accept updates as writing docs is deffo not my forte :) :) :)
