MGC MK II Menu Development using BeebEm on Mac : Run out of space
Post by daveejhitchins » Fri May 10, 2019 7:53 am
As the title suggests: I'm developing the MGC MK II Menu on my MacBook using BeebEm4 (Master Mode) and I've run out of room due to the amount of REM text!
I considered using a 2nd CoPro, however, I'm using my BASIC Editor that doesn't work over the Tube :?
Are there any solutions I can use "easily" to continue on my laptop?
Thanks . . . Dave H :D
Re: MGC MK II Menu Development using BeebEm on Mac : Run out of space
Post by Elminster » Fri May 10, 2019 8:22 am
When I ran out of space for Basic Editor, I just carried on writing it on Mac and copying it across, when I ran out of space again I started using the crunch and compress, when I ran out of space again I used the co pro..... not sure what I will do when I run out of space again.
Post by hoglet » Fri May 10, 2019 8:37 am
Is it already using the shadow screen memory?
Post by lurkio » Fri May 10, 2019 8:42 am
I'm developing the MGC MK II Menu on my MacBook using BeebEm4 (Master Mode) and I've run out of room due to the amount of REM text! I considered using a 2nd CoPro, however, I'm using my BASIC Editor that doesn't work over the Tube :? Are there any solutions I can use "easily" to continue on my laptop?
Use a text editor (like TextWrangler or BBEdit) on your Mac to edit the BASIC program, and copy and paste the whole of the listing into BeebEm whenever you want to run it and test it.
To avoid having the REMs take up space in RAM when you paste the listing from the text editor into BeebEm, remove the line number of the line that each REM is on, so that the REMs still appear interleaved in the right places in the text file on your Mac but they’re not actually part of the program per se. This will only work if (a) you’re using line numbers for non-REM lines in the text file and (b) whenever you use a REM it appears at the beginning of the line rather than being appended to a BASIC statement with a colon.
E.g. here’s the sort of thing that would appear in the text editor on your Mac:
REM start of program
REM begin loop
10 REPEAT
REM print text
20 PRINT "Look, ma! No REMs!"
REM loop never ends
30 UNTIL FALSE
REM program ends
Dunno if this approach is compatible with the BASIC editor on the emulated Beeb though. Do you need the BASIC editor on the Beeb any more if you’re going to switch to text-editing on the Mac?
Post by daveejhitchins » Fri May 10, 2019 9:16 am
Yes, I started right at the beginning (original MGC) with shadow memory.
Ah! I didn't know you could 'paste' into BeebEm. That may be an option - Thanks.
But wouldn't I still have the same number of characters?
Another idea I've thought of is to save out individual Procedures. Then I could squash each one before rebuilding and running.
Which ever way I try, it's going to take longer :?
Thanks for the advice . . . I'll let you know how I get on.
Post by lurkio » Fri May 10, 2019 9:46 am
No. Copy and paste the text (including REMs) in the Code panel in my previous post (above) into BeebEm. Then LIST the program in BeebEm... No REMs!
:idea:
LordVaderUK
Post by LordVaderUK » Fri May 10, 2019 10:45 am
That's a nice idea (not numbering the REMs)... I am having a problem with a fairly simple and straightforward Blackjack game, works a treat in BBC Basic / SDLIDE but won't fit on BeebEm (and presumably a real Beeb). Unfortunately SDLIDE can either number everything, or only number 'necessary' lines, which in practice means it will number DATA statements.
I've done the best I can - offloaded all the instructions into a file which is loaded and displayed if needed, cut down on the number of PROCs, changed all the variables to integers, drastically reduced the number of arrays, etc. but it's still too big. Any other suggestions?
Post by Elminster » Fri May 10, 2019 11:29 am
And I posted a BBC Basic BBEdit Language Post around here somewhere, so BBEDIT will highlight BBBC BASIC properly.
Edit: Here viewtopic.php?f=7&t=3953&hilit=bbedit#p110804
Edit2: Then I remembered I put them all on github https://github.com/elminster/BBEdit-LMs
Post by tricky » Fri May 10, 2019 1:02 pm
BooBip does an OS "shadow RAM" board, I wonder how hard it would be to add that to beebem.
I believe using integers actually takes more memory for individual variables as their names are one character longer and the names are used many times - I could be completely wrong about this!
Could you put the DATA in a file, or have one program to load it into memory and then load the main program that uses it?
Does P. take less space than PRINT?
Richard Russell
Post by Richard Russell » Fri May 10, 2019 2:23 pm
SDLIDE should only number DATA statements if they are referenced in a RESTORE (and hence the numbers are 'necesssary'). Numbering all lines except REMs is not an option it has (!) but since it's written in BBC BASIC you could quite easily add it, or modify the existing renumber code to work that way. Look at how the 'remove%' flag is used in PROCrenumber for guidance.
Post by MartinB » Fri May 10, 2019 2:39 pm
Use a smaller font Dave....? :-k
Post by daveejhitchins » Fri May 10, 2019 3:31 pm
:lol:
If only . . .
Dave H :lol:
Post by daveejhitchins » Sat May 11, 2019 10:19 am
OK, I now have BBEDIT running so I hope to be using this in the near future.
In the meantime I've restructured and have made available a further 2175 bytes - let see how long those will last!
Thanks to all for the advice - Dave H :D
