Getting a image on to BBC
andrewvideo
Post by andrewvideo » Fri Apr 12, 2019 11:53 am
I am looking for a easy was to get a picture to load on Screeen on the BBC.
The plan is to auto boot the disc and show the picture.
I can open disc images on my BBC using MMC or GoTek Floppy Drive so thats my path of getting on the BBC. I know little of basic programming like printing hello world lol.
I am doing a Retro gaming night for a some young people with disabilities and would be nice to have the image on screen while they coming in and when i do a short talk about the BBC Miro.
This the file I want to display on the screeen. I made with 3 colors Black,White and Green. Res. 320x256 ( Might be to big ) base on Mode 1
https://www.dropbox.com/s/h6wdemhicsjnv ... E.png?dl=0
Thanks guys
Re: Getting a image on to BBC
Post by danielj » Fri Apr 12, 2019 12:06 pm
You need BBC Micro Image Converter...
http://www.retrosoftware.co.uk/wiki/ind ... _Converter
Post by lurkio » Fri Apr 12, 2019 12:11 pm
You need BBC Micro Image Converter... http://www.retrosoftware.co.uk/wiki/ind ... _Converter
What he said!
  • PHAB2.ssd
    EDIT: Updated to be compatible with coprocessors
    (200 KiB) Downloaded 6 times
:idea:
andrewvideo
Post by andrewvideo » Fri Apr 12, 2019 12:25 pm
Wow that was fast. I well try it right now. Thank you so much.
Post by jgharston » Fri Apr 12, 2019 1:31 pm
There's also BMP and GIF conversion programs at http://mdfs.net/Apps/Graphics/Conversion/
andrewvideo
Post by andrewvideo » Fri Apr 12, 2019 2:56 pm
Only got it to work on in the BBC B+ Mode. Does't really matter I just rember to switch to OS on the night.
Going to play around it. Going to Learn how to use VDU19. Tried to load a other image and colors don't match.
Trying using the Gallary disk so I can load more pictures.
Thank you.
dv8
Post by dv8 » Fri Apr 12, 2019 3:26 pm
Try changing line 40 in the LOADER program to:
40*LOAD PHABGAM FFFF3000
or disable the Pi co-processor with:
*FX151,230,14
If you're going to be playing games you will probably need to disable the co-pro anyway.
Most games won't run properly with the Tube active.
andrewvideo
Post by andrewvideo » Fri Apr 12, 2019 5:16 pm
That worked a treat. Cheers
