BeebAid and PiTubeDirect on Model B? - Help!
strawberrytau
Post by strawberrytau » Mon Apr 01, 2019 8:49 am
I am trying to set up BeebAid on my BBC B - to enable me to toggle the PiTubeDirect CoPro easily with TAB-BREAK.
I don't have an EEPROM unit yet (ordered and in the post) so am running the BeebAid rom from my Boobip Sideways RAM. It seems to work fine, except I cannot get TAB-BREAK or *TUBEON *TUBEOFF to work properly. :-(
When I try *TUBEOFF - I get the errors:
"Write Access 5"
TUBE already disabled
and when I ctrl-break the CoPro is not disabled
With *TUBEON - I get the errors:
"Write Access 5"
TUBE already active
Interestingly, I get very similar errors on a BBC Model B emulation in MacBeebEm (Write Access 7 - instead of 5). Screenshot attached:
Does anyone on this group have experience with getting BeebAid and PiTubeDirect working together on a Model B?
Any ideas?
Thanks!
Edit: I am using Auto Beebaid 1.01 as that's the only version I have been able to track down. I see references to a version 1.05 online. Does anyone on the forum have the file for this later version?
Last edited by strawberrytau on Mon Apr 01, 2019 9:04 am, edited 2 times in total.
Pernod
Re: BeebAid and PiTubeDirect on Model B? - Help!
Post by Pernod » Mon Apr 01, 2019 10:27 am
The latest I've ever found is 1.02.
Only mention of 1.05 is with Col at viewtopic.php?f=1&t=663&p=2570#p2570, was never shared though.
beebaid.zip
(10.57 KiB) Downloaded 10 times
strawberrytau
Post by strawberrytau » Mon Apr 01, 2019 11:14 am
Thanks Nigel! I’ll try that.
Last edited by strawberrytau on Mon Apr 01, 2019 11:14 am, edited 1 time in total.
