Suggestions for backing up floppies with read errors?
EdVoncken
Post by EdVoncken » Sat Mar 23, 2019 9:58 am
I’m trying to back up all my 5.25” floppies, written on my Beeb with 8271 and Watford DFS 1.43a back in the day.
The discs do not appear to be mouldy; I’m using the DataCentre IMPORT/EXPORT commands to back up to USB .ssd images but it seems some discs have developed read errors.
Is there a method / software that can help recover the readable bits of each floppy? Perhaps ignore the read errors?
Thanks!
BBC-B (my first computer, 1983/1984?), Electron (1985? virtually unused)
BBC-B and BBC Master 128 with DataCentres from Mark@RetroClinic (2018, 2019)
Refurb/upgrade projects: BBC-B (2x), BBC Master 128 from eBay and Marktplaats
Re: Suggestions for backing up floppies with read errors?
Post by CMcDougall » Sat Mar 23, 2019 12:01 pm
one word, UPURS 8)
Post by lurkio » Sat Mar 23, 2019 12:11 pm
Have a look at DiskToUSB too:
:idea:
Post by MartinB » Sat Mar 23, 2019 12:18 pm
As Colin says, UPURS has various old disc recovery options but importantly, unlike most systems it can be commanded to ignore unreadable tracks when it will continue reading the disc but will pad the image of any bad tracks with dummy data. Hence, you often end up with a still fairly complete image if the original has only a few bad tracks.
(Note though that UPURS is DFS only.)
EdVoncken
Post by EdVoncken » Sun Mar 24, 2019 9:16 pm
Thanks for the suggestions,
I will start by looking at UPURS. Interesting to see how much data can be recovered that way; I have some old school reports on those floppies ;-)
Post by danielj » Sun Mar 24, 2019 9:48 pm
The other options are flux-level readers, like the kryoflux, that will dump everything and rely on PC-side software to decode them (and you get an idea from the visualisations as to where the issues lie). These also read through any errors. The kryoflux is expensive, but there is a much much cheaper option here:
http://cowlark.com/fluxengine/
EdVoncken
Post by EdVoncken » Mon Mar 25, 2019 12:06 pm
... The kryoflux is expensive, but there is a much much cheaper option here: http://cowlark.com/fluxengine/
Ooh - this tickles my geek-senses ;-) I may just have to build one of these...
