Drawing a circle in BBC BASIC
Re: Drawing a circle in BBC BASIC
Post by BigEd » Wed Mar 27, 2019 2:07 pm
This in-browser emulator of a CoCo2 has Extended Color Basic 1.1, copyright 1982.
http://www.haplessgenius.com/mocha/
There's a manual for Extended Color Basic here (pdf)
http://www.colorcomputerarchive.com/coc ... ndy%29.pdf
Post by leenew » Wed Mar 27, 2019 2:16 pm
Well we got all of this capability (and more) in 1985 with Acornsoft's "Graphics extension ROM". 🙂
Lee
rmbrowngr
Post by rmbrowngr » Mon Apr 08, 2019 2:30 pm
Came across this article while searching for other things for drawing circles. http://www.acornelectron.co.uk/mags/eu/ ... /s-p38.jpg
Richard B
Acorn Electrons issue 4 and issue 6 with Master RAM Board, Acorn Plus 1, AP6, AP5, Pegasus 400, BeebSCSI, Gotek, Raspberry Pi 2nd Processor, GoSDC MBE with Elk2GoSDC and Cart2GoSDC.
BBC B+ 64K (128K upgraded) with Duel OS
fuzzel
Post by fuzzel » Sun Apr 21, 2019 11:01 am
I've written my own circle drawing program in BBC Basic but would like to attempt the conversion to assembly language.
I think I can work out how to calculate the points of the circle but what are the assembly language equivalents of MOVE (x,y), DRAW (x,y), PLOT (x,y), GCOL (0,x), SIN (x), COS (x) and RAD (x) ?
geraldholdsworth
Post by geraldholdsworth » Sun Apr 21, 2019 11:06 am
MOVE, DRAW, PLOT and GCOL are easy, as they are just VDU commands.
RAD, COS and SIN are BASIC functions inside the BASIC ROM. You might find it easier to convert one of those listed above that doesn't use these...or use a lookup table created by a BASIC program.
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
fuzzel
Post by fuzzel » Sun Apr 21, 2019 12:00 pm
Thanks for the reply Gerald, my main priority is speed, would using VDU commands and BASIC rom functions, albeit within Assembly language, slow the program down ?
0xC0DE
Post by 0xC0DE » Sun Apr 21, 2019 12:02 pm
Definitely
0xC0DE
Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
Post by BigEd » Sun Apr 21, 2019 12:28 pm
If you want speed, you almost certainly need to implement something like a Bresenham algorithm. No trig, and maybe even no multiplies either. See the listings posted upthread by lurkio.
lurkio wrote:
Sat Mar 23, 2019 6:48 pm
... from the December 1984 issue of Practical Computing magazine...
Richard Russell
Post by Richard Russell » Sun Apr 21, 2019 12:55 pm
As far as I can see the 'Graphics extension ROM' provided, for the 6502, only the same functionality that came as standard in RISC OS, and didn't include elliptical arcs and sectors (only circular ones) or Bézier curves. If I'm wrong, and those features were supported, I'd be interested in the details. Otherwise I remain of the view that the graphics features available to BBC BASIC (even now) are seriously limited.
SimonSideburns
Post by SimonSideburns » Sun Apr 21, 2019 1:18 pm
This code:
L.
   10MODE2
   20REPEAT
   30r%=RND(512):h%=RND(1280):v%=RND(1024):c%=RND(8)-1
   40IFRND(2)=1 PROCcircle(h%,v%,r%,c%) ELSE PROCfilledcircle(h%,v%,r%,c%)
   50UNTIL FALSE
  100DEFPROCcircle(h%,v%,r%,c%)
  110VDU 29,h%;v%;:GCOL 0,c%
  120x%=r%:y%=0
  130LET z%=x%/2
  135REPEAT
  140PLOT 69,x%,y%
  150PLOT 69,x%,-y%
  160PLOT 69,-x%,-y%
  170PLOT 69,-x%,y%
  180PLOT 69,y%,x%
  190PLOT 69,y%,-x%
  200PLOT 69,-y%,-x%
  210PLOT 69,-y%,x%
  220LET y%=y%+1
  230LET z%=z%-y%
  240IF z%<0 THEN z%=z%+x%:x%=x%-1
  250UNTIL x%<y%
  260ENDPROC
  300DEFPROCfilledcircle(h%,v%,r%,c%)
  310VDU 29,h%;v%;:GCOL 0,c%
  320x%=r%:y%=0
  330LET z%=x%/2
  340REPEAT
  350MOVE x%,y%:PLOT 5,-x%,y%
  355MOVE y%,x%:PLOT 5,-y%,x%
  360MOVE x%,-y%:PLOT 5,-x%,-y%
  365MOVE y%,-x%:PLOT 5,-y%,-x%
  370LET y%=y%+1
  380LET z%=z%-y%
  390IF z%<0 THEN z%=z%+x%:x%=x%-1
  400UNTIL x%<y%
  410ENDPROC
Provides both filled and unfilled circles in BASIC using only INTEGERS, ADDITION and SUBTRACTION.
I'm sure it would be trivial to convert into machine code if speed was vitally important.
Hope that helps.
Last edited by SimonSideburns on Sun Apr 21, 2019 1:19 pm, edited 2 times in total.
Well, Imogen that!
Post by jgharston » Sun Apr 21, 2019 4:00 pm
The functions available with the graphics extension ROM, or the VDU driver in MOS 3 and later are as in http://mdfs.net/Docs/Books/Manuals/AcornGXR.txt, summerised on page 63, and the only ellipse plotting supported are full outline or filled ellipses. The PLOT numbers that logically would be the ellipse equivalent (&D0-&E0) of the circle plots (&A0-&B0) are listed as reserved. Logically, if anybody implemented ellipse arcs, sectors, and segments, those are the plot numbers that should be used.
Post by jgharston » Sun Apr 21, 2019 4:09 pm
It could be sped up a bit as it plots each physical horizontal line twice, due to using logical pixels instead of scaling for physical pixels. I've got 6502 code for this method somewhere, from memory from the Subset column of Personal Computer World from 1985-ish.
It also doesn't let you do XOR plotting, but that's a bit fiddlier.
Richard Russell
Post by Richard Russell » Sun Apr 21, 2019 4:46 pm
Interesting. Have you given any thought to how elliptical arcs, sectors and segments would be specified using only three points (I presume it's a fundamental characteristic of VDU graphics that any object can be specified as MOVE x1,y1 : MOVE x2,y2 : PLOT code,x3,y3). The most obvious adaptation of the 'circular' commands would be to require that the third point is actually on the ellipse, rather than somewhere on a radial line, but I wonder if it might be computationally tricky to go from that to a more conventional description.
SimonSideburns
Post by SimonSideburns » Sun Apr 21, 2019 5:09 pm
Yes, of course that's right. It was more about the algorithm and I was wondering if the OP was aware of it as it does seem a whole lot simpler.
Well, Imogen that!
Richard Russell
Post by Richard Russell » Mon Apr 22, 2019 9:41 am
Yes, that's a very good point. It can easily be forgotten that in order for XOR plotting to work correctly (specified either with GCOL 3 or 4, or by using an 'inverting' PLOT code) every pixel must be plotted just once. Quite recently I spotted a bug (since fixed) in Matrix Brandy's graphics which arose from this precise cause.
SimonSideburns
Post by SimonSideburns » Wed Apr 24, 2019 1:42 pm
This modified version will happily do GCOL 3 or 4: Oops, just tried it and it doesn't work!
   10MODE2:x%=RND(-TIME)
   20REPEAT
   30r%=RND(512):h%=RND(1280):v%=RND(1024):c%=RND(1024) MOD 8
   50UNTIL FALSE
   60DEFPROCcircle(h%,v%,r%,c%)
   70VDU 29,h%;v%;:GCOL 0,c%
   80x%=r%:y%=0
   90LET z%=x%/2
  100l%=2
  110REPEAT
  120l%=(l%+1) MOD 4
  130IF l%<>0 THEN GOTO 220
  140PLOT 69,x%,y%
  150PLOT 69,x%,-y%
  160PLOT 69,-x%,-y%
  170PLOT 69,-x%,y%
  180PLOT 69,y%,x%
  190PLOT 69,y%,-x%
  200PLOT 69,-y%,-x%
  210PLOT 69,-y%,x%
  220LET y%=y%+1
  230LET z%=z%-y%
  250UNTIL x%<y%
  260ENDPROC
  270DEFPROCfilledcircle(h%,v%,r%,c%)
  280VDU 29,h%;v%;:GCOL 0,c%
  290x%=r%:y%=0
  300LET z%=x%/2
  310l%=2
  320REPEAT
  330l%=(l%+1) MOD 4
  340IF l%<>0 THEN GOTO 390
  360MOVE y%,x%:PLOT 5,-y%,x%
  370MOVE x%,-y%:PLOT 5,-x%,-y%
  380MOVE y%,-x%:PLOT 5,-y%,-x%
  390LET y%=y%+1
  400LET z%=z%-y%
  410IF z%<0 THEN z%=z%+x%:x%=x%-1
  420UNTIL x%<y%
  430ENDPROC
Last edited by SimonSideburns on Wed Apr 24, 2019 1:45 pm, edited 1 time in total.
Well, Imogen that!
joachim
Post by joachim » Wed Apr 24, 2019 7:36 pm
Ooh, this is a fun problem. Requiring the third point to be on the ellipse actually isn't a sufficient specification, because when you go from circles to ellipses you add not one but two degrees of freedom: eccentricity (the shape of the ellipse up to similarity) and tilt (the angle between the semimajor axis and horizontal).
So you have to scrounge up another degree from somewhere, within the constraint that the PLOT syntax only allows six degrees in total. Whole circles have three degrees of freedom; whole ellipses have five, as do circular arcs/sectors/segments; and elliptical arcs/sectors/segments have, er, seven.
A hack you could use to knock off a degree of freedom is to require all arcs to start at the semimajor (or semiminor) axis (but end in an arbitrary place); if you require an arc that starts and ends off axis, plot it in two pieces (additively or subtractively). This also works for filled sectors; for filled segments you'd have to subtract off a triangle. Doesn't work if you're not willing to plot in EOR mode, though.
Richard Russell
Post by Richard Russell » Wed Apr 24, 2019 9:48 pm
I had assumed axis-aligned ellipses, because that's all that are supported by most graphics subsystems (Windows GDI and SDL2_gfx to name but two). Hence BBC BASIC for Windows and BBC BASIC for SDL 2.0 both draw only axis-aligned ellipses, natively, as does Liberty BASIC. To draw tilted ellipses and elliptical arcs on those platforms you must resort to Bézier curves.
Post by jgharston » Thu Apr 25, 2019 10:42 pm
I've been pondering this while fixing my carpet, and here are some notes on generalised ellipses:
To draw an arc/sector/segment as well as defining the closed curve you need to specify the start and end points on the curve. You can see this in going from a closed circle to a part circle, an additional MOVE is required to specify the start point, and the PLOT specifies the end point.
To draw a full ellipse the Acorn VDU driver requires two-and-a-half points to be specified, the centre, the point on the line to the right of the centre, and the top point. It's two-and-a-half points as the Y coord of the second MOVE is ignored.
So I thought the obvious thing be to use that unused Y. But that gives two possible end points, and forces the start point to be on the horizontal. For a generalised elliptical curse four whole points are needed, three MOVEs and a PLOT. Centre, Start Point, Top Point, End Point (or Centre, Start Point, End Point, Top Point).
The Acorn VDU driver only stores the two previous points, so an additional 'previous point' needs to be stored. This could be why the BBC Graphics Extension never did this, as the VDU workspace only had space for two previous points. Not a reason for the RISC OS VDU driver not to do it though.
Later, some thoughts on horizontally-aligned elliptical curves.
Post by jgharston » Thu Apr 25, 2019 11:57 pm
I'm trying to convince myself that those four points specify a unique ellipse, so my Salas Hille & Anderson is tonight's bedtime reading.
Post by BeebMaster » Sat Apr 27, 2019 9:07 pm
There's a discussion on plotting circles and ellipses in the Master Reference Manual part 1 section E:
page0195.tif
page0196.tif
page0197.tif
page0199.tif
page0200.tif
