Acornsoft C
MM5XT
Acornsoft C
Post by MM5XT » Fri Feb 22, 2019 4:21 am
Good day
Anyone know if a copy of Acornsoft C for the BBC exists anywhere online? using Beebug C at the moment, but keen to take a peek.
Cheers!
Michael
Re: Acornsoft C
Post by DutchAcorn » Fri Feb 22, 2019 5:17 am
Good day
Cheers!
Michael
Can’t recall if there is a BBC B version but for the Master version see this post: http://stardot.org.uk/forums/viewtopic.php?t=3361
MM5XT
Re: Acornsoft C
Post by MM5XT » Fri Feb 22, 2019 5:31 am
Oh sweet!
I could swore I did a search of the forum before I posted, ah well.
Michael
Re: Acornsoft C
Post by RobC » Fri Feb 22, 2019 11:31 am
Can’t recall if there is a BBC B version...
I think it'll run on the 6502 co-pro or from sideways RAM on the Master.
Andrew_Waite
Re: Acornsoft C
Post by Andrew_Waite » Fri Feb 22, 2019 2:02 pm
Would BCPL, the forerunner of both the 'B' and 'C' programming languages, be a suitable substitute for these folks who are looking for a C-compiler for the Beeb?
BCPL for the BBC Micro seems to have an excellent pedigree, being marketed by a company set up by the brother of the language's inventor.
https://en.wikipedia.org/wiki/BCPL
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Fri Feb 22, 2019 2:19 pm
Is Acornsoft BCPL, the forerunner of both the 'B' and 'C' programming languages, a suitable substitute for these folks who are looking for a C-compiler for the Beeb?
I guess it depends what they want to do. If they want to write in a structured language that is compiled not interpreted then maybe it will scratch an itch. Obviously it doesn’t compile to produce C code (or machine code either - it compiles to produce an internediate code which needs a BCPL ROM or runtime to process).
I quite like BCPL myself and have written a few simple programs in it. Some discussions here
viewtopic.php?f=2&t=13158&hilit=Bcpl
Atom, issue 5
USA Model B
Re: Acornsoft C
Post by RobC » Fri Feb 22, 2019 3:03 pm
I know I go on about this a fair bit but I think the easiest and best way to get a C compiler on the Beeb is to use a Pi co-pro. There are decent C compilers for most (all?) of the cores (Z80, 6502, 6809, 32016, ARM2, x86 & native ARM). If you use the native ARM core, you can even do graphics/sprites quicker than on the host and you get loads of memory.
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Fri Feb 22, 2019 9:13 pm
Any idea which of these options is best? I gave Beebug C a go but it is rather tricky to configure and slow to compile without a co-proc. Unfortunately I couldn’t find an editor that allowed me to edit the source files and then run them.
By best I mean easiest to set up and use I guess. I have a gotek on a Master so DFS and ADFS based options should be fine. I think I saw some x86 files on there as well. :D
Atom, issue 5
USA Model B
Re: Acornsoft C
Post by RobC » Fri Feb 22, 2019 10:48 pm
Depends whether you want to compile on the BBC or not. If not, the native ARM core is the best as it's the quickest and has the most memory.
If you want to compile on the Beeb, I think the 32016 and ARM2 work well. There are some useful options for the x86 and 6809 too but I haven't used them as much.
I have a DC CF card image with loads of co-pro compilers on it if you want. You can use something like ADFS Explorer to move the files to ADFS floppy images.
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Sat Feb 23, 2019 8:33 am
Thanks. :D
Definitely on beeb for me please!
My ideal scenario would be to have it running on a mode B with a pi co proc and connecting to my econet to build files from and to.
Atom, issue 5
USA Model B
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Thu Mar 07, 2019 10:12 pm
Probably a daft question but on a beeb how do you get the double vertical lines that represent ‘or’ in an if statement in C?
For example
if (key=‘Y’ || key=‘y’){....
Thanks!
Atom, issue 5
USA Model B
Re: Acornsoft C
Post by danielj » Thu Mar 07, 2019 10:13 pm
Above the backslash.
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Thu Mar 07, 2019 10:57 pm
Thanks. I tried that but get a compile error using the Norcroft C compiler on the ARM evaluation co-proc. Which I should have probably mentioned I was using... :oops:
Code snippet:-
Atom, issue 5
USA Model B
Re: Acornsoft C
Post by danielj » Thu Mar 07, 2019 11:17 pm
Crumbs, no idea then... It should be ASCII character 124 which is what that is :?
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Thu Mar 07, 2019 11:22 pm
I’m pretty sure that one worked in Beebug C but not figured this one out yet...
Atom, issue 5
USA Model B
Re: Acornsoft C
Post by BigEd » Fri Mar 08, 2019 7:28 am
You have an = instead of == on the RHS of that expression - might that be confusing the compiler? Is there any more to the error message?
Re: Acornsoft C
Post by danielj » Fri Mar 08, 2019 7:41 am
That'd do it!
Lardo Boffin
Re: Acornsoft C
Post by Lardo Boffin » Fri Mar 08, 2019 10:12 am
That'd do it!
:oops:
Atom, issue 5
USA Model B
