BASIC Tokenizer
colonel32
BASIC Tokenizer
Post by colonel32 » Thu Feb 07, 2019 3:25 am
Is there an easy way to tokenize plain text BASIC files?
Something like a windows or linux command line tool.
Re: BASIC Tokenizer
Post by richardtoohey » Thu Feb 07, 2019 5:55 am
Do you mean using an 8-bit machine or an Acorn machine?
Or definitely something on Windows/Linux?
You could run a BBC emulator (on Windows or Linux) and slurp in the code and save it tokenised (but don't think that counts as easy) but that would be using 8-bit software.
EDIT: e.g. this in Beebem ...
*BUILD TEST
0001 10 PRINT "THIS IS UNTOKENISED"
0002 20 PRINT 2+2
0003 30 REM SOMETHING
0004 40 END
0005
Escape
*EXEC TEST
L.
   20 PRINT 2+2
   30 REM SOMETHING
   40 END
SA."TESTBAS"
*INFO *
$.TESTBAS     FF1900 FF8023 00003E 003
$.TEST        000000 000000 000044 002
I've just used *BUILD to make a non-tokenised file as an example. The key thing is using *EXEC to tokenise it.
Don't think this is what you meant, but it's under 8 bit software so it's a 8 bit software solution! :D
Get the untokenised source file(s) onto an SSD, run them through an emulator and job done.
cmorley
Re: BASIC Tokenizer
Post by cmorley » Thu Feb 07, 2019 7:46 am
BeebASM will with the PUTBASIC command.
Richard Russell
Re: BASIC Tokenizer
Post by Richard Russell » Thu Feb 07, 2019 9:16 am
You can call the built-in tokeniser (in all versions of BBC BASIC except Brandy) using a cheat involving EVAL. Jonathan has a BASIC library which incorporates this code and will run on 6502, Z80, 32000, RISC OS, MS-DOS or Windows BBC BASIC. If you want a Windows executable you could very easily combine it with a file reading/writing wrapper and create an EXE using BB4W or BBCSDL.
sweh
Re: BASIC Tokenizer
Post by sweh » Thu Feb 07, 2019 2:07 pm
Maybe http://www.retrosoftware.co.uk/wiki/ind ... niser_in_C would help?
BASIC Tokeniser/Detokeniser
Some C++ (but trivial to convert into C) routines that convert to/from a memory dump of any Acorn machine running the BASIC II ROM and an ASCII file of the BASIC program. Originally taken from my ElectrEm emulator.
Routines of interest are bool ImportBASIC(char *Filename, Uint8 *Mem) and bool ExportBASIC(char *Filename, Uint8 *Memory). SetupBASICTables() must be called once before either routine is used.
I was able to use that as a library, an put a simple wrapper around it.
$ cat xyz
10 PRINT "Hello THERE"
15 PRINT TIME
20 END
$ ./tokenzier xyz > foo
$ hdump foo
00000000  0D 00 0A 14 20 F1 20 22 48 65 6C 6C 6F 20 54 48   .... . "Hello TH
00000010  45 52 45 22 0D 00 0F 08 20 F1 20 91 0D 00 14 06   ERE".... . .....
00000020  20 E0 0D FF                                        ...
$ beeb list foo
   15 PRINT TIME
   20 END
FWIW, the changes I made to use it:
< #include "BASIC.h"
> typedef unsigned char Uint8;
> typedef unsigned short Uint16;
> #include <string.h>
> #include <stdlib.h>
683a688
>               printf("Bad PAGE %x\n",Addr);
694a700
>               printf("Bad Top %x\n",TOPAddr-2);
And the wrapper routine (which is a complete hack'n'slash)
#include <stdio.h>
void SetupBASICTables();
bool ImportBASIC(char *, Uint8 *);
int main(int argc,char *argv[])
  char *name=argv[1];
  if (!name) name="xyz";
  SetupBASICTables();
  Uint8 foo[32768];
  foo[0x18]=14;
  foo[0x12]=2; foo[0x13]=14;
  foo[0xe00]=13; foo[0xe01]=255;
  ImportBASIC(name,foo);
  int t=foo[0x13]*256+foo[0x12];
  int i;
  for(i=0xe00;i<t;i++) { printf("%c",foo[i]); }
  return(0);
Basically, set's page to &E00, TOP to &E02, puts an empty program (OD FF) in, calls the "tokenize" function, and then outputs from &E00->TOP to stdout. Hacky :-)
Rgds
Stephen
ThomasHarte
Re: BASIC Tokenizer
Post by ThomasHarte » Thu Feb 07, 2019 4:26 pm
Oh, I'm the original author of that tokeniser — it originates from ElectrEm. Apologies for the kooky types, they're the SDL names for what would eventually be standardised stdint.h, but the code predates C99 support in the compilers I had access to way back when.
Apologies being made, I should probably modernise it and chuck it on Github. I'll try to take a look at that. Off the top of my head: lots of things should probably be const, the 'private' functions should be static, I'm unclear why I didn't just use qsort for my sorting step in building QuickTable, and it'd be smart to eliminate all the globals.
Richard Russell
Re: BASIC Tokenizer
Post by Richard Russell » Thu Feb 07, 2019 5:43 pm
Here's a BASIC program to do the job. I have uploaded a Windows executable here, it has not been extensively tested but seems to work.
      REM!Exefile tokenise.exe,signed,encrypt,console
      ON ERROR PRINT REPORT$ : QUIT
      REM Standard console program rubric:
      SYS "GetStdHandle", -10 TO @hfile%(1)
      SYS "GetStdHandle", -11 TO @hfile%(2)
      SYS "SetConsoleMode", @hfile%(1), 0
      *INPUT 13
      *OUTPUT 14
      REM Get and parse command line:
      Cmd$ = @cmd$
      P% = INSTR(Cmd$, """")
      IF P% THEN
        Q% = INSTR(Cmd$, """", P%+1)
        IF Q% = 0 ERROR 100, "Command syntax: tokenise inputfile outputfile"
        srcfile$ = EVAL(Cmd$)
        dstfile$ = EVAL(MID$(Cmd$,Q%+1))
      ELSE
        P% = INSTR(Cmd$, " ")
        IF P% = 0 ERROR 100, "Command syntax: tokenise inputfile outputfile"
        srcfile$ = LEFT$(Cmd$, P%-1)
        dstfile$ = MID$(Cmd$, P%+1)
      ENDIF
      REM Open / create files:
      S% = OPENIN(srcfile$)
      IF S% = 0 ERROR 100, "Couldn't open input file: " + srcfile$
      D% = OPENOUT(dstfile$)
      IF D% = 0 ERROR 100, "Couldn't create output file: " + dstfile$
      REM Tokenise:
      BPUT#D%, &D
      WHILE NOT EOF#S%
        a$ = GET$#S%
        IF a$="" IF PTR#S%>1 THEN PTR#S%=PTR#S%-2 : IF BGET#S%<>BGET#S% a$ = GET$#S%
        BPUT#D%, FNtokenise(a$);
      ENDWHILE
      BPUT#D%, &FF
      CLOSE #S%
      CLOSE #D%
      PRINT "Created Acorn-tokenised file """ + dstfile$ + """"
      QUIT
      DEF FNtokenise(a$)
      LOCAL n
      n = VAL(a$)
      WHILE ASCa$=&20 OR ASCa$>=&30 AND ASCa$<=&39 a$ = MID$(a$,2) : ENDWHILE
      WHILE RIGHT$(a$) = " " a$ = LEFT$(a$) : ENDWHILE
      IF EVAL("1RECTANGLE:"+a$) a$ = $(!332+3)
      IF LENa$ > 251 THEN
        PRINT "Line too long, truncated"
        a$ = LEFT$(a$,251)
      ENDIF
      = CHR$(n DIV256)+CHR$(n MOD256)+CHR$(LENa$+4)+a$+CHR$&D
Last edited by Richard Russell on Thu Feb 07, 2019 6:30 pm, edited 1 time in total.
colonel32
Re: BASIC Tokenizer
Post by colonel32 » Mon Feb 11, 2019 1:11 am
Wow, thank you everyone. Especially Richard!
