Designer Castles..
alex_farlie
Designer Castles..
Post by alex_farlie » Wed Aug 15, 2018 12:01 pm
Does anyone recall this?
And a long shot, does anyone have any notes on the save file format of the Castle/Village / Environment data ?
It would be nice to be able to (copyrights permitting) print old designs on modern systems.
Re: Designer Castles..
Post by lurkio » Wed Aug 15, 2018 4:40 pm
No, I've never heard of it -- but it sounds intriguing!
It's possible that the only way the file format will be analysed is if you can upload the disc-image and the ROM-image here and see if someone is willing and able to dissect them.
It would be nice to be able to (copyrights permittg) print old designs on modern systems.
Indeed! Copyright can sometimes be an issue, but given that all we're trying to do is preserve thirty-year-old software that would otherwise be lost forever, it's likely that we'll be spared the wrath of the intellectual property lawyers -- or at least, that's usually the case (with one or two notable exceptions).
See Daniel's previous reply to you.
:idea:
billcarr2005
Post by billcarr2005 » Wed Aug 15, 2018 4:43 pm
I *think* i recently acquired this.
I'll image and upload it later, unless somebody beats me to it, or it turns out I don't have it :lol:
Post by lurkio » Wed Aug 15, 2018 4:49 pm
I *think* i recently acquired this. I'll image and upload it later
Please do! You might also want to compare your copy with the one uploaded here -- which I think is missing the ROM:
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 5:29 pm
The original package was a Disc+ROM
The ROM had the WIMP/ and Support functions , whereas the DISC had the Software and resources ( such as the model sections. and Icon sets.).
The ROM was physcially a single ROM, no complex banking as far as I could tell, so it should be image-able with SWR tools like any other ROM. My experience of how it operated suggests it was largely written for a BBC B type environment, but only used legal instructions as it ran on a BBC Master without issue.
There was also a version for RISC OS around the A3000 era but I've only seen that in a review...
Post by lurkio » Wed Aug 15, 2018 5:32 pm
Are you able to image the ROM yourself, alex?
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 5:33 pm
Not currently, No monitor I know have can go down to the scan rates used by an old school RGB output, and the drives I have aren't reliable...
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 5:39 pm
I asked because in an off forum discussion, someone mentioned potentially coming across some "documents" created with the package. Given that people have preserved 'document' files from old systems on some other platforms...
Post by lurkio » Wed Aug 15, 2018 5:48 pm
Not currently
Would you be willing to post the ROM to a Stardotter who could save the data off for you?
It would be good to get a copy of those files or "documents" (not sure why the scare-quotes!) and preserve them.
:idea:
dp11
Post by dp11 » Wed Aug 15, 2018 5:52 pm
IIRC there is something funny about the ROM ( e.g. 32K ). I have memories of moding it to run from SWR.
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 6:43 pm
My last efforts to track down the authors (in 2007) led me to a web design firm called Wonkey Monkey in Huddersfield, where one of the authors had responded, expressing they still had an IPR interest in Designer Castles, which is partly why I am reluctant to just upload an image on a public forum like Stardot.
I sent a much longer follow-up e-mail to them , but didn't get any further replies (and my then ISP's mail service had issues at the same time IIRC).
If there are Star Dot contributors in the Huddersfield area that want to try and track down any further information....
Data Design itself become a firm called TelePresence systems based on a correspondence I had with them (1999 or so)... given the time elapsed since I am not sure they'd still be an active concern...
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 6:49 pm
BAnked?
I seem to recall some other BBC roms like Quest Paint had additional logic on their chips, Not sure if this is something current emulators can handle.
dp11
Post by dp11 » Wed Aug 15, 2018 6:57 pm
I don't recall any extra logic . I was using a Master at the time and Masters can take 32K ROMs.
alex_farlie
Post by alex_farlie » Wed Aug 15, 2018 7:20 pm
How does that work?
I thought ROMS were 16K because of the upper 16K of ROM being the OS? You mean 32K Roms that appear in the Memory map as 2 16K slots?
In using the Printware ROM on a Master128 I don't recall it's image appearing in more than one ROM slot, so I am sure it's a 16K ROM, unless I am not understanding how the memory layout works..
dp11
Post by dp11 » Wed Aug 15, 2018 7:43 pm
A master can have a rom which takes two banks 16K banks.
It was a long time ago so I may have bits wrong.
alex_farlie
Post by alex_farlie » Thu Aug 16, 2018 4:53 pm
You still have the image, or at the very least the patch code you wrote?
billcarr2005
Post by billcarr2005 » Thu Aug 16, 2018 7:17 pm
... In using the Printware ROM on a Master128 I don't recall it's image appearing in more than one ROM slot, so I am sure it's a 16K ROM ...
It is indeed a 16K ROM :)
alex_farlie
Post by alex_farlie » Thu Aug 16, 2018 7:21 pm
So no problems in imaging, the issue is tracking down the ownership so it can be archived properly (or the user data format looked into. :)
dp11
Post by dp11 » Thu Aug 16, 2018 9:19 pm
I wonder, does it have protection to prevent in running in SWR ? there was something I had to do to get it to work. I'm pretty sure I had to load multiple swr banks. Was there a later version with a bigger rom ?
alex_farlie
Post by alex_farlie » Thu Aug 16, 2018 10:13 pm
The Disc needed a serial number IIRC
billcarr2005
Post by billcarr2005 » Fri Sep 14, 2018 2:42 pm
Better late than never!
I've removed the old / original registration and replaced it with stardot. An 8 digit serial number is required, but this is only requested if registration hasn't already occurred.
The "design" is stored / saved from &95F to &CFF, length &3A0. In theory, I guess the memory could be inspected when each item is added to check what changes and the format dissected.
The ROM is 16K, couldn't find any copy protection, unless it appears later. "PRINTWARE.ROM" can be installed on the emulator of your choice, or *RUN PSR on the disk image will load it into sideways RAM.
Designer Castles.zip
Designer Castles
(48.59 KiB) Downloaded 14 times
Post by klintworth » Fri Sep 14, 2018 3:14 pm
Here's a pdf of my Designer Castles manual. Paul :D
Designer Castles.pdf
(2.79 MiB) Downloaded 20 times
BBC B Issue 4, BBC B UNB09 Issue1 (USA), Electron, BBC Master Compact, A7000+(Castle Peak Performer)
Kenelm
Post by Kenelm » Fri Sep 14, 2018 3:25 pm
Many thanks for this! I own the disks, but the ROM had been lost, and I have been curious to have a look at it.
billcarr2005
Post by billcarr2005 » Fri Sep 14, 2018 3:51 pm
Thanks for scanning & uploading this, saves me scanning mine!
