BBC Font
BBC Font
Post by Prime » Sat Jul 28, 2018 10:16 am
Does anyone know the location in the MOS ROM and the format of the mode 0..6 fonts? Obviously the Mode 7 one is in the SAA chip....
ctr
Re: BBC Font
Post by ctr » Sat Jul 28, 2018 10:28 am
They are right at the start. Try this on a beeb.
   10MODE4
   20S%=&5800
   30C%=&C000
   40FORI%=0TO&2FF
   50S%?I%=C%?I%
   60NEXT
Each char is eight bytes, one byte for each row, eight pixels in each byte. Most significant bit on the left, least significant on the right.
Edit: This is true on a Model B; the Master, etc. may vary.
Re: BBC Font
Post by jgharston » Sat Jul 28, 2018 1:29 pm
It's in different places in different operating systems, and you should never access it directly, that's what OSWORD 10 is for.
Plus:
* loads of 8x8 fonts
* default 8-bit system fonts
Re: BBC Font
Post by tricky » Sat Jul 28, 2018 2:46 pm
In my BasicInvaders game I actually used the OSWORD call for the first time, do I get a lolly pop :lol:
Re: BBC Font
Post by Prime » Sat Jul 28, 2018 4:09 pm
Thanks for the replies, reason I want them is to extract binary data to use on a microcontroller running an LCD display....so will extract from MOS rom.
Re: BBC Font
Post by Coeus » Thu Aug 02, 2018 8:55 pm
Interesting that there comes a point where people have concluded there are now enough dots available to go for a serif font, presumably thinking it will give a "professional" look and since the fashion has gone back to sans-serif fonts.
Re: BBC Font
Post by jgharston » Fri Aug 03, 2018 8:07 pm
Every now and then I *CLOAD merp and happily type away until the minimal difference between upper and lower case starts getting annoying. :)
Bit7Inv is quite useful when examining memory dumps for finding top-bit-set marked strings:
