CP/M Hard Disc BIOS
CP/M Hard Disc BIOS
Post by Coeus » Tue Jul 10, 2018 6:31 pm
Questions, probably for JGH: Disc http://mdfs.net/Mirror/Image/AcornCPM/JGHCPM1.zip is a CP/M bootable disc with a hard disc BIOS.
1. Does this make any assumptions about the disc interface, i.e. SCSI or IDE.
2. Does it need reserved tracks on the disc or does it turn an ADFS file into a virtual hard disc?
3. Can CP/M be booted from a hard disc this way?
Re: CP/M Hard Disc BIOS
Post by jgharston » Tue Jul 10, 2018 10:21 pm
No, it just accesses a disk image through the normal OPEN/GBPB/CLOSE interface.
Drive C: is stored as a disk image on the filing system you specify in the file you specify. The linked-to disk image is configured to use adfs:$.CPMFILE. You can change what disk image file to use with the supplied MOUNT.COM utility.
No, Acorn CP/M is hard-wired to boot from drive 0. You need to boot from a system floppy with HDBIOS installed on it, and then the hard drive becomes active. There's a way to right a sideways ROM to supply the boot BIOS, but I've never got it working properly.
See also CPM/Acorn/HardDrive.
